New LibreELEC.tv Leia build #0302:
Generic
(Supercedes previous build)
SHA256 Checksum:
c9243f891eb174dc2e0a080e8ff8eff60b81c3d4a2741a44c73b27dde18bcfb7
(Generic)
text:
# uname -a
Linux NUC 4.19.26 #1 SMP Sun Mar 3 05:01:59 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190303045138-#0302-g0111c1d [Build #0302]
# Kodi version
Kodi (18.2-RC1 Git:f43abaf). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (0111c1d,
changelog) and tip of
XBMC master (f43abaf,
- Includes latest kodi-platform master (e8574b8)
- Includes latest libcec master (3bbd432)
- Includes latest libnfs master (0308145)
- Includes latest p8-platform master (1eb12b1)
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (b636726, +2), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (045d3a4, +14), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] compare (perma): TESTING: increase timeout to ensure OS is able to create core dump/crash log
- Include [env] patch: Add http2 support for curl
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: kodi: use upstream repo for Milhouse RPi builds
- Include [env] patch: kodi: remove annoying, excessively repetitive addon logging
- Include [env] patch: rev hack for kodi
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, peripheral.joystick/xarcade, other)
- Include [env] PR:2471 (perma): openssl: update to 1.1.1b
- Include [env] PR:3238 (perma): kodi/openssl: fix crash using vfs.sftp
- Include [env] PR:3316 (perma): openssh: drop support for ssh-dss keys
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/26
- Include [env] PR:3329 (perma): [RFC] add safe_remove to notify if a file doesn't exist
- Include [env] PR:3334 (perma): xf86-video-nvidia: update to xf86-video-nvidia-410.104
- Include [env] PR:3336 (perma): gcc: update to gcc-8.3.0
- Include [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Include [env] PR:3348 (perma): packages/{x11,print,devel}: bump packages
- Include [env] PR:3349 (perma): Packages: Miscellaneous package bumps to new minor versions
- Include [env] PR:3351 (perma): config/options: ban spaces in paths
- Revert [env] PR:8ad229b70f70c4811ccda9c81d5df8929d5babc1 ([url=]perma[/url]): openssl: revert minor bump
- Include [pkg] patch: kodi: fix addon platform_tag (kodi)
- Include [pkg] PR:14571 (perma): Remove ARB postfix from GL functions
- Include [pkg] PR:15164 (perma): TexturePacker: Fix memory / resource leak the ugly way
- Include [pkg] PR:15356 (perma): Optimize locking in ApplicationMessenger
- Include [pkg] PR:15591 (perma): Fix TCP buffer parsing to find JSON statements to correctly
- Include [pkg] PR:15621 (perma): [cmake] microhttpd: only link with libraries
Build Highlights:
- openssl: update to 1.1.1b - this may break some addons
Build Details:
- XBMC:
- [cleanup] remove include guards (PR:15646, 1 commit, 6 files changed)
- [Android] Fix monoscopic/2D viewrect calcuation (PR:15649, 1 commit, 1 file changed)
- peripheral.xarcade:
- [cosmetic] use correct provider name (d218f0d)
- Added: [env] PR:2471 (perma): openssl: update to 1.1.1b
- Updated: [env] PR:3342 (perma): scripts/build: fix broken sym link after #3328
- Added: [env] PR:3351 (perma): config/options: ban spaces in paths
(2019-03-03, 02:07)Milhouse Wrote: [ -> ] (2019-03-03, 00:52)Matt Devo Wrote: [ -> ]I just spot checked a handful of @Milhouse 's nightly builds going all the way back to 2018/12/01, and all have snd_soc_skl included, whereas none of the official LE builds (going back to 8.90.003) do. So must be a kernel config difference there.
I see snd-soc-skl.ko in 8.90.003:
text:
LibreELEC-Generic.x86_64-8.90.003/target/
LibreELEC-Generic.x86_64-8.90.003/target/SYSTEM.md5
LibreELEC-Generic.x86_64-8.90.003/target/KERNEL
LibreELEC-Generic.x86_64-8.90.003/target/KERNEL.md5
neil@nm-linux:~/projects$ find extract/SYS -name snd-soc-skl.ko
extract/SYS/usr/lib/kernel-overlays/base/lib/modules/4.17.6/kernel/sound/soc/intel/skylake/snd-soc-skl.ko
I also went back through my own builds and it's present in all of them, as far back as #0210 (2018) which is the older version I have available:
text:
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/target/
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/target/SYSTEM
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/target/SYSTEM.md5
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/target/KERNEL
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/target/KERNEL.md5
LibreELEC-Generic.x86_64-9.0-devel-20180210233631-#0210-g0946c0d/milhouse.build.0210.tar.gz
extract/SYS/usr/lib/kernel-overlays/base/lib/modules/4.14.18/kernel/sound/soc/intel/skylake/snd-soc-skl.ko
It's not in 8.2.5, so would have been introduced somewhere between 4.11.12 (8.2.5) and 4.14.18 (#0210, as 8.90.003 is based on 4.17.6).
OK, I'll have to look into it more, I just did a cursory check of whether the HDMI audio output existed or not, and it always does on the official builds
(2019-03-03, 01:07)whysoserious Wrote: [ -> ] (2019-03-03, 01:01)UrushibaraRuka Wrote: [ -> ]Is it just me or is the download speed a bit slow lately? Maybe 2 or 3 weeks.
I have a 150mbps line so I'm used to see something like 18000kb/s (sometimes even 20000kb/s) but it tops out at about 4600kb/s lately.
Speedtest says that my line is fine.
Well, I just this minute downloaded build #301 and it pegged my Spectrum 100 Mb/s line at 115 Mb/s (slightly over-provisioned, it seems).
(2019-03-03, 02:11)Milhouse Wrote: [ -> ] (2019-03-03, 01:01)UrushibaraRuka Wrote: [ -> ]Is it just me or is the download speed a bit slow lately? Maybe 2 or 3 weeks.
Downloading at 106MB/s here...
Hmm...guess I have an issue with my installation then.
Just downloaded the latest build on my desktop and got full speed as well.
Guess I might do a clean install again pretty soon.
Anyway, thanks for the replies guys.
New LibreELEC.tv Leia build #0303:
Generic
SHA256 Checksum:
5313738f151468db8b0f41d8ff6d982a6991f68acc574d12bc2170573c656543
(Generic)
text:
# uname -a
Linux NUC 4.19.26 #1 SMP Sun Mar 3 21:04:53 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190303210320-#0303-g0111c1d [Build #0303]
# Kodi version
Kodi (18.2-RC1 Git:847f1e8). Platform: Linux x86 64-bit
Based on tip of
XBMC master (847f1e8,
Build Highlights:
- Minors
Build Details:
- XBMC:
- [music] format album rating (PR:15653, 1 commit, 1 file changed)
- [Android] generate keypress for mediasession actions (PR:15654, 1 commit, 1 file changed)
(2019-03-03, 02:07)Milhouse Wrote: [ -> ]It's not in 8.2.5, so would have been introduced somewhere between 4.11.12 (8.2.5) and 4.14.18 (#0210, as 8.90.003 is based on 4.17.6).
so upon closer inspection, snd_soc_skl being loaded isn't the issue, since it is present/loaded on the official builds as well. But for some reason, on the official builds, snd_hda_intel is what attaches to the audio device (per lspci -vnn), whereas on Milhouse's builds it's snd_soc_skl that attaches. Moreover, the subsystem ID is reported differently (Google vs Intel, different vendor/device IDs):
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
Subsystem: Google, Inc. Sunrise Point-LP HD Audio [1ae0:006b]
Flags: bus master, fast devsel, latency 64, IRQ 126
Memory at d122c000 (64-bit, non-prefetchable)
Memory at d1210000 (64-bit, non-prefetchable)
Capabilities: [50] Power Management version 3
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
vs
Subsystem: Intel Corporation Sunrise Point-LP HD Audio [8086:7270]
Flags: bus master, fast devsel, latency 64, IRQ 16
Capabilities: [60] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_soc_skl
Kernel modules: snd_soc_skl, snd_hda_intel
(2019-03-04, 05:19)Matt Devo Wrote: [ -> ] so upon closer inspection, snd_soc_skl being loaded isn't the issue, since it is present/loaded on the official builds as well. But for some reason, on the official builds, snd_hda_intel is what attaches to the audio device (per lspci -vnn), whereas on Milhouse's builds it's snd_soc_skl that attaches. Moreover, the subsystem ID is reported differently (Google vs Intel, different vendor/device IDs):
The only kernel difference between official 9.0.1 and my latest release is
PR3324 which bumps the kernel from 4.19.23 to 4.19.26 (I've been including this PR for about 2 weeks, since #0221).
I'm not sure what would cause the IDs to be reported differently, unless there's some sort of race situation with one driver loading before the other - if you reboot the official release does it always load the driver in the same order?
(2019-03-04, 08:02)Milhouse Wrote: [ -> ]The only kernel difference between official 9.0.1 and my latest release is PR3324 which bumps the kernel from 4.19.23 to 4.19.26 (I've been including this PR for about 2 weeks, since #0221).
it's definitely not a kernel version issue - as I mentioned before, I had to blacklist snd_soc_skl starting back when I first started running your 9.0 nightly/test builds (probably last summer?), which is why I was surprised when others reporting it wasn't needed with the official 9.0 alpha/beta/release builds (which I've subsequently verified myself). so this has been an issue that's persisted across many major and minor kernel versions.
The release builds reliably load the correct driver (snd_hda_intel), and your builds reliably load the incorrect one. I started looking at how to debug the HD-audio driver, and might need to do a debug build with additional options enabled to get more info, since right now I get absolutely nothing in dmesg when the incorrect driver loads/attaches
(2019-03-03, 17:33)UrushibaraRuka Wrote: [ -> ] (2019-03-03, 01:07)whysoserious Wrote: [ -> ] (2019-03-03, 01:01)UrushibaraRuka Wrote: [ -> ]Is it just me or is the download speed a bit slow lately? Maybe 2 or 3 weeks.
Just did a fresh clean install and the download still caps at these low 4600 kb/s.
Tested my connection again to make sure that the whole 150mbps are there and of course they are.
Changed the LAN cable from my router to my HTPC to see if there's any issue but no, nothing changed.
I mean, it's not that big of a deal really as everything else seems to work normally (apart from my persisting Amazon issue where I only get sub-720p streams and 1080p only on some shows).
Maybe I should enable debug-logging, restart, start any amazon video and stop it after a while and post that log? Would that help in any way if it's an issue on my end?
(2019-03-04, 22:45)UrushibaraRuka Wrote: [ -> ]I mean, it's not that big of a deal really as everything else seems to work normally (apart from my persisting Amazon issue where I only get sub-720p streams and 1080p only on some shows).
It could be a peering issue, the server is in Frankfurt, Germany. I wouldn't worry about it too much, these things normally clear themselves up over time.
New LibreELEC.tv Leia build #0304:
Generic
SHA256 Checksum:
daed463aa6313db382a7d08d5f1b1a3b8f315626059ef83845b51e89bd03cad5
(Generic)
text:
# uname -a
Linux NUC 4.19.26 #1 SMP Mon Mar 4 21:04:49 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190304210323-#0304-g0111c1d [Build #0304]
# Kodi version
Kodi (18.2-RC1 Git:1a261cf). Platform: Linux x86 64-bit
Based on tip of
XBMC master (1a261cf,
- Include [env] PR:3354 (perma): brcmfmac_sdio-firmware-rpi: fix race between service and /dev/serial1
- Include [pkg] PR:193 (perma): Async connection (pvr.vuplus)
- Include [pkg] PR:15644 (perma): [curl] Accept all supported content encodings by default
Build Highlights:
- Async connection (pvr.vuplus)
- [curl] Accept all supported content encodings by default
Build Details:
- XBMC:
- fixed: always update stream details from player (fixes #15584) (PR:15589, 1 commit, 1 file changed)
- [cmake] microhttpd: only link with libraries (PR:15621, 2 commits, 2 files changed)
- [Android] Prevent HDMI_AUDIO_PLUG intent on TV (PR:15661, 1 commit, 2 files changed)
- Fix TCP buffer parsing to find JSON statements to correctly (PR:15591, 1 commit, 1 file changed)
- Added: [pkg] PR:193 (perma): Async connection (pvr.vuplus)
- Added: [pkg] PR:15644 (perma): [curl] Accept all supported content encodings by default
(2019-03-04, 23:42)Milhouse Wrote: [ -> ] (2019-03-04, 22:45)UrushibaraRuka Wrote: [ -> ]I mean, it's not that big of a deal really as everything else seems to work normally (apart from my persisting Amazon issue where I only get sub-720p streams and 1080p only on some shows).
So the server is pretty much across the street for me (I'm from Frankfurt).
Anyway, I had another issue with my old installation (which was the reason for the clean install) and I hope that's gone now as I haven't tested it yet.
Short description of the issue:
Whenever I started libreelec and went to any streaming service (youtube, amazon, watchbox, tvnow, twitch) the video would "hang" after about 15 minutes for 8-10 seconds and then resume as if nothing happend (or rarly go back into the menu).
This only occured once, after that it wouldn't happen again unless I reboot my HTPC.
In the logs was always a connection error for that exact moment.
Again, it only happend once per boot. Also not that much of a big deal, just a tiny bit annoying.
Then again, it might be my router as it's in service for about 5 years or so. Maybe it wants to retire
(2019-03-05, 02:15)UrushibaraRuka Wrote: [ -> ]So the server is pretty much across the street for me (I'm from Frankfurt).
https://db-ip.com/138.68.75.163
Postal code 60313, apparently
(2019-03-05, 02:15)UrushibaraRuka Wrote: [ -> ]Again, it only happend once per boot. Also not that much of a big deal, just a tiny bit annoying.
Can you post your kernel log using
dmesg | pastebinit
(or click the crash log option in LibreELEC Settings) and then post the link..
New LibreELEC.tv Leia build #0305:
Generic
SHA256 Checksum:
5f2a88d841a330494ae13882906aefa401dc554fbefeb15c5c58b13045be3f85
(Generic)
text:
# uname -a
Linux NUC 4.19.27 #1 SMP Tue Mar 5 22:30:05 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190305221520-#0305-g0111c1d [Build #0305]
# Kodi version
Kodi (18.2-RC1 Git:4de5972). Platform: Linux x86 64-bit
Based on tip of
XBMC master (4de5972,
- Includes latest addons: inputstream.adaptive (b76c81f), inputstream.rtmp (ce68b77, +1), peripheral.joystick (6b2a4dd, +5), peripheral.xarcade (d218f0d, +2), pvr.argustv (83aa1e9), pvr.demo (964686d), pvr.dvblink (ecc9cfd, +4), pvr.dvbviewer (c2c1beb, +2), pvr.filmon (e850633), pvr.hdhomerun (a9d7309), pvr.hts (8dcd62d, +3), pvr.iptvsimple (73feb2f), pvr.mediaportal.tvserver (931afab), pvr.mythtv (c954c7e), pvr.nextpvr (78c6633), pvr.njoy (4467cac), pvr.octonet (203f800), pvr.pctv (b60b971), pvr.stalker (d0170c5), pvr.teleboy (1956113), pvr.vbox (ea20464), pvr.vdr.vnsi (cbb75ab), pvr.vuplus (97c67ae, +23), pvr.wmc (7b28be3), pvr.zattoo (30868ce), vfs.libarchive (2ba1102), vfs.rar (b66c6df, +1), vfs.sftp (ab0dc82, +1)
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/27
Build Highlights:
- New 4.19.27 kernel
Build Details:
- XBMC:
- [Android] implement MediaSession::onMediaButtonEvent (PR:15675, 1 commit, 3 files changed)
- pvr.dvblink:
- Add PVR addon update interval setting (PR:114, 1 commit, 7 files changed)
- Fixed: deleted timers do not remain in the list as disabled (#118); R (PR:119, 1 commit, 3 files changed)
- pvr.vuplus:
- Async connection (PR:193, 9 commits, 36 files changed)
- Updated: [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.25/27
New LibreELEC.tv Leia build #0306:
Generic
SHA256 Checksum:
b607b18c1861ef8e6f0aa3368924d9ac15fe9b3c8dad7e7b71bcd96c68e2315f
(Generic)
text:
# uname -a
Linux NUC 4.19.27 #1 SMP Wed Mar 6 21:08:08 GMT 2019 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20190306210326-#0306-g0111c1d [Build #0306]
# Kodi version
Kodi (18.2-RC1 Git:26ba848). Platform: Linux x86 64-bit
Based on tip of
XBMC master (26ba848,
- Include [env] compare (perma): kodi: fix patch
- Include [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
Build Highlights:
- Minor log changes (kodi)
Build Details:
- XBMC:
- Minor log changes (PR:15678, 1 commit, 4 files changed)
- Added: [env] compare (perma): kodi: fix patch
- Updated: [env] PR:3324 (perma): linux (RPi/Generic): update to linux-4.19.27
Weekly Linux 5.0 build #0306x:
Generic
Known issues:
text:
No dvb-latest or crazycat drivers
