2017-02-24, 15:08
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355
2017-02-24, 21:52
this problem I've always had both the 16.1 version and 17 is 18. I have installed in many PCs starting from 0
2017-02-25, 00:07
New LibreELEC.tv Leia build #0224: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (0d24524c, changelog) and tip of XBMC master (e1c28e2f, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.0 #1 SMP Fri Feb 24 21:05:44 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170224210424-#0224-g0d24524 [Build #0224]
# Kodi version
(18.0-ALPHA1 Git:4c792db). Platform: Linux x86 64-bit
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (0a97062d, ahead +22)
- Includes latest libnfs master (2e0a67fc, ahead +49)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (69c9e5fe, +1), pvr.argustv (5a36c586), pvr.demo (8243935f), pvr.dvblink (0015079e), pvr.dvbviewer (9fb34b3c), pvr.filmon (315e5034), pvr.hdhomerun (98cb8d40), pvr.hts (1caa390d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (019c7e99), pvr.mythtv (18fe56e4, +11), pvr.nextpvr (cb1b5415), pvr.njoy (080cd321), pvr.octonet (8549a31c), pvr.pctv (e67e9695), pvr.stalker (a609149c), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Exclude [env] kodi-999.99-PR11662.patch: kodi: merged upstream
- Include [env] afbd134f: linux: Enable Fair Queue packet scheduling (TEST)
- Include [env] e533a8be: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
- Include [env] patch: ffmpeg: add extra RPi lib required when building ffmpeg command line with gpu service hevc patches
- Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1121: linux: update to linux-4.10.0
- Include [env] PR:1287: virtio-gpu support (qemu/kvm)
- Include [env] PR:1326: Build system scripts cleanup
- Include [env] PR:1329: imagedecoder.raw: add add-on
- Include [env] PR:1355: xorg-server: clean package when nvidia drivers are bumped
- Include [env] PR:1379: projectM: remove glew [LE9]
- Include [env] PR:1387: buildsystem: Create unpack stamps for packages without sources
- Include [pkg] patch: alsa-lib: conf: Add card config for Intel HDMI/DP LPE audio (alsa-lib)
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11734: [estuary] sync pt2
- [estuary] sync pt2
2017-02-25, 00:12
(2017-02-24, 21:52)flaflasat Wrote: [ -> ]this problem I've always had both the 16.1 version and 17 is 18. I have installed in many PCs starting from 0
You've had the mark-as-watched problem since 16.1?
There's really nothing unusual in these builds that I can think of that would cause this issue. What add-ons are you testing with, what database (MySQL or SQLite) are you using for MyVideos, can you share a debug log (wiki) that includes the point at which the video should marked as watched (ie. towards the end of whatever it is you are viewing).
2017-02-25, 00:13
(2017-02-24, 01:19)Milhouse Wrote: [ -> ](2017-02-23, 02:37)khaoohs Wrote: [ -> ](2017-02-23, 00:55)Milhouse Wrote: [ -> ]Please try #0222 - hopefully that restores functionality.
Yes, my remote works again.
How is it with #0223?
Harmony button repeat is fine for me with this version of media_build.
@khaoohs ?
2017-02-26, 00:35
New LibreELEC.tv Leia build #0225: Generic
Based on tip of LibreELEC.tv master (0d24524c, changelog) and tip of XBMC master (4bdddb31, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.0 #1 SMP Sat Feb 25 21:41:18 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170225213958-#0225-g0d24524 [Build #0225]
# Kodi version
- Include [env] patch: llvm: update llvm-3.9.1
- Include [env] patch: mesa: update mesa-17.0.0
- bump mesa 17.0.0 and llvm 3.9.1
- Estuary PVR fixes
- AE: use iec pause bursts only for audio sync
- XBMC:
- [estuary] sync pt2 (PR:11734, 1 commit, 27 files changed)
- [estuary] re-add PVRChannelNumberInput to fullscreenvideo (PR:11743, 1 commit, 1 file changed)
- musicinfotag - fix recordlabel (PR:11742, 1 commit, 1 file changed)
- changes for Windows x64 (PR:11739, 4 commits, 4 files changed)
- [estuary] hide seekbar when pvr osd channels is visible (PR:11745, 1 commit, 1 file changed)
- [PVR] Trac 17311: timer rules windows/settings dialog fixes (PR:11736, 2 commits, 2 files changed)
- [PVR] Trac 17339: Remove non-working recording settings defaults. (PR:11746, 1 commit, 7 files changed)
- AE: use iec pause bursts only for audio sync (PR:11751, 1 commit, 3 files changed)
2017-02-27, 01:04
New LibreELEC.tv Leia build #0226: Generic
Based on tip of LibreELEC.tv master (feb4c4ef, changelog) and tip of XBMC master (a077d7b9, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.0 #1 SMP Sun Feb 26 22:28:58 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170226222738-#0226-gfeb4c4e [Build #0226]
# Kodi version
- Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (110ddb71, +2), pvr.argustv (5a36c586), pvr.demo (f2075086, +1), pvr.dvblink (a669273e, +1), pvr.dvbviewer (9fb34b3c), pvr.filmon (5c6432db, +1), pvr.hdhomerun (98cb8d40), pvr.hts (1caa390d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (76ae28f6, +1), pvr.mythtv (18fe56e4, +11), pvr.nextpvr (cb1b5415), pvr.njoy (3d097117, +1), pvr.octonet (8549a31c), pvr.pctv (e0d9f175, +1), pvr.stalker (ea970851, +1), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
- Include [env] patch: kodi: fix PR:1348
- Include [env] PR:1348: kodi: adjust cputemp/gputemp script
- Include [env] PR:1391: mesa: update to mesa-17.0.0 with llvm-3.9.1 bump
- Fix rumble always enabled
- [addons] fix InstallUpdatesAndWait
- PR:1348: kodi: adjust cputemp/gputemp script
Quote:Please check CPU/GPU temp in System information (or cputemp/gputemp with ssh).
Tested OK on RPi/RPi2, Intel NUC (Skylake) and nvidia ION2, but please report any issues here, or on PR:1348 (which includes a test script for debugging purposes).
- LibreELEC.tv:
- Python: use -j1 for makeinstall_host (PR:1392, 1 commit, 1 file changed)
- amlogic: remove kodi patch and instead disable suspend via systemd (PR:1377, 1 commit, 4 files changed)
- Addon stripping improvements (PR:1370, 3 commits, 2 files changed)
- xorg-server: clean package when nvidia drivers are bumped (PR:1355, 1 commit, 1 file changed)
- Changed links inside README.md to 'https://...' if possible (PR:1353, 1 commit, 1 file changed)
- odroid-c2: linux add meson_pwm support (PR:1339, 1 commit, 1 file changed)
- imagedecoder.raw: add add-on (PR:1329, 2 commits, 2 files changed)
- scripts/image: print depmod errors (PR:1371, 1 commit, 1 file changed)
- Build system scripts cleanup (PR:1326, 4 commits, 3 files changed)
- Amlogic: Disable POST_PROCESS_MANAGER_3D_PROCESS in kernel config (PR:1175, 1 commit, 3 files changed)
- linux: update to linux-4.10.0 (PR:1121, 9 commits, 14 files changed)
- XBMC:
- peripheral.joystick:
- Peripheral API v1.3.1 - Report rumble and power-off capabilities (PR:86, 1 commit, 10 files changed)
- pvr.demo:
- fix install path (PR:39, 1 commit, 1 file changed)
- pvr.dvblink:
- fix install path (PR:67, 1 commit, 1 file changed)
- pvr.filmon:
- fix install path (PR:63, 1 commit, 1 file changed)
- pvr.mediaportal.tvserver:
- fix install path (PR:59, 1 commit, 1 file changed)
- pvr.njoy:
- fix install path (PR:32, 1 commit, 1 file changed)
- pvr.pctv:
- fix install path (PR:41, 1 commit, 1 file changed)
- pvr.stalker:
- fix install path (PR:84, 1 commit, 1 file changed)
2017-02-27, 01:27
I upgraded to #0225 and the watched state is no longer indicated in file lists in Estuary. The videos are apparently being marked as watched in the DB (the context menu switches between "Mark as watched" and "Mark as unwatched") but the tick indicator doesn't show in either state.
First version without the problem is #0223, so it looks like it was broken by the Estuary sync part 2.
2017-02-27, 01:51
@magao thanks for the report. Noticed this myself earlier today so thanks for identifying the break (saved me doing it!)
2017-02-28, 01:02
New LibreELEC.tv Leia build #0227: Generic
Based on tip of LibreELEC.tv master (ed1a60dd, changelog) and tip of XBMC master (85ec9751, changelog) with the following modifications:
# uname -a
Linux NUC 4.10.0 #1 SMP Mon Feb 27 21:29:39 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170227212650-#0227-ged1a60d [Build #0227]
# Kodi version
- Includes latest libnfs master (f95fa8ef, ahead +51)
- Include [env] patch: RBP: Add support for Dion Audio LOCO-V2 DAC-AMP
- Minors
- LibreELEC.tv:
- XBMC:
- [PVR] Fix inconsistent TimerSettings 'Enable/Disable' (PR:11769, 1 commit, 1 file changed)
- [PVR] Trac 17359: Fix crash in CPVRTimers::GetTimerRule(const CFileItem *item). (PR:11748, 1 commit, 1 file changed)
- [xbmc] Start work on getting rid of our emulated GetDiskFreeSpaceEx method (PR:11741, 3 commits, 9 files changed)
- libnfs:
- Here are some changes to resolve some conflicts with MinGW and fuse_dokan (PR:174, 2 commits, 4 files changed)
- Added: [env] patch: RBP: Add support for Dion Audio LOCO-V2 DAC-AMP
2017-02-28, 01:47
Sorry for the delay.
With 0223, there is no button repeat issues.
2017-02-28, 17:30
Does the LibreELEC Dev Updater work for everyone around here? It doesn't even start on my system using #0221.
OpenELEC Dev Updater turned buggy a while ago (build infos can't be brought up anymore, can't be closed anymore) but is at least providing an overview of the new releases. Installation of new releases also still works.
2017-02-28, 17:35
LibreELEC Dev Updater 0.0.5 just as good as before here.
2017-02-28, 17:38
(2017-02-28, 17:30)kekomat Wrote: [ -> ]Does the LibreELEC Dev Updater work for everyone around here? It doesn't even start on my system using #0221.
Same here, with window can't be closed.
2017-02-28, 21:15
hi guys
I have tis trouble: ow can I see te tv guide for live tv ?
how can I set my harmony to view tv guide ?
