Milhouse,
It's not only one server or computer but the entire workgroup doesn't appear ("workgroup" doesn't show). It got 2 rpi's with the latest build (should be using smb3?) and windows 10 pc's (smb3) and an updated Synology DS216+ II where smb3 is enabled in the network settings. Shouldn't it at least show "workgroup" with itself as it's using smb3? Could it be that it doesn't work in a mixed envoirement (got some Enigma2 sat and cable receivers that use smb1)?
Why do both problems work when connecting via ip adress? Isn't this more a problem with name resolving?
But yes, adding: client max protocol = SMB1 solves it!
(2017-03-31, 16:31)rudrood Wrote: [ -> ]@Milhouse,
Are you using the stock smb config, ie. you do NOT have a custom config in /storage/.config/samba.conf, as this would dictate how the LE clients appear on your network and it's where you configure their workgroup etc. (default is WORKGROUP).
I suppose it might be possible that one of the machines on your network has become the master browser and it's this machine that says it can talk SMB2/SMB3, but not reliably. Perhaps try testing with different machines turned off until the problem goes away. Or try with only the LE clients, then introduce other machines (although given the nature of Samba and the browser election process, this process could be very hit & miss needing all machines to be rebooted etc.).
You can prevent a server from being elected a master browser by adding the following in smb.conf on the server:
[global]
local master = no
With "client max protocol = SMB3" and no custom configurations all of my LE clients show WORKGROUP in the Add Source dialog, and in that workgroup are listed all my LE clients (RPi1, RPi3, NUC) and all of my Samba servers (FreeNAS 8.3, Windows7, Ubuntu 16.04), so yes it should appear and should list all your clients, unless Samba is broken on your network, which frankly doesn't take much.
I have tried to change the smb.conf in /storage/.smb
I've tired with :
[global]
preferred master = no
local master = no
domain master = no
client lanman auth = yes
lanman auth = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
lock directory = /storage/.smb/
name resolve order = bcast host
but libreelec crash when I try to start a film (network film)
#0305 version works great also wit samba3
(2017-03-31, 17:25)conca Wrote: [ -> ]but libreelec crash when I try to start a film (network film)
If LE is crashing, you should post a link to your crashlog.
(2017-03-31, 17:27)conca Wrote: [ -> ]#0305 version works great also wit samba3
Can you identify the first build that is crashing? It's entirely possible this has nothing to do with Samba3/Samba4.
Milhouse,
You're right, it seems that the local master browser is running on samba 1 machine.
Forced my Synology master browser to use samba 2 (can't force 3) but then nothing shows up in my Windows 10 network neighbourhood.
Seems to be a regular problem with Windows 10:
https://www.tenforums.com/network-sharin...twork.html
Tried to enable local master browser on the Libreelec PC in /storage/.config/samba.conf:
local master = yes
preferred master = auto
domain master = auto
os level = 20
but for some reason it doesn't start.
C:\Users\Optiplex 9020>nbtstat -a 192.168.1.235
Ethernet:
Node IpAddress: [192.168.1.47] Scope Id: []
NetBIOS Remote Machine Name Table
Name Type Status
LIBREELEC <00> UNIQUE Registered
LIBREELEC <03> UNIQUE Registered
LIBREELEC <20> UNIQUE Registered
WORKGROUP <00> GROUP Registered
WORKGROUP <1E> GROUP Registered
No master browser running there.
Found that /storage/.smb/smb.conf isn't in the Libreelec settings backup, so if you run into problems with smb3 you cannot downgrade by "updating" with an earlier build and restore the backup. The smb.conf stays on smb3.
(2017-03-31, 20:01)rudrood Wrote: [ -> ]No master browser running there.
An election takes place to select the master browser on a network so it could be any of your machines - setting "local master = yes" simply means that machine can take part in the election and it _may_ become the master browser if there is no "better" alternative.
The default is for Samba to participate in browser elections, so setting "local master = yes" isn't necessary - it's the default.
"os level = 20" is also the default, which means it will only "beat" (in the election) any Windows system less than a Windows NT/2000 primary domain controller - see
https://www.samba.org/samba/docs/using_s...l#INDEX-57 for more details. If you want LE to become the master browser you'll most likely need to set "os level = 33" in order to "beat" more recent Windows systems (7, 8, 10 etc.).
If you absolutely want to make sure your LE machine becomes the master browser, you'll need something like:
[global]
local master = yes
os level = 255
preferred master = yes
New LibreELEC.tv Leia build #0331:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.8 #1 SMP Fri Mar 31 21:05:32 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170331210411-#0331-g8cd9fa5 [Build #0331]
# Kodi version
(18.0-ALPHA1 Git:78cce57). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (8cd9fa57,
changelog) and tip of
XBMC master (e6b9fa0d,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (8563411d, ahead +11)
- Includes latest libnfs master (9d2e13c0, ahead +57)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (aa0d5113), inputstream.rtmp (6c1af46a), peripheral.joystick (b9217a8b, +1), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (819129d5), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (bb679013, +1), pvr.wmc (5aa3b1ca)
- Include [env] compare: linux: update to linux-4.10.8
- Include [env] patch: tvheadend42: fix ffmpeg
- Include [env] patch: rapidjson: update to rapidjson-1.1.0
- Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1469: samba: update to samba-4.6.1
- Include [env] PR:1491: linux: cp project and device device tree, silence errors
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:62: #change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:11668: FFmpegImage: Document and change alignment
- Include [pkg] PR:11911: [cmake] fix package names that find_package is equal to find_package_handle_standard_args
- Include [pkg] PR:11921: estuary fix watched status for videos
Build Highlights:
- New 4.10.8 kernel
Build Details:
- XBMC:
- [depends] samba-gplv3: use non versioned so on android (PR:11922, 1 commit, 1 file changed)
- AE: updates (PR:11765, 28 commits, 68 files changed)
- Added: [env] compare: linux: update to linux-4.10.8
New LibreELEC.tv Leia build #0401:
Generic
# uname -a
Linux NUC 4.10.8 #1 SMP Sat Apr 1 21:04:13 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170401210251-#0401-g8cd9fa5 [Build #0401]
# Kodi version
Based on tip of
XBMC master (09f0104a,
- Include [pkg] PR:11923: [rbpi] Make sure we strip binaries in Release build
Build Highlights:
- Minors
Build Details:
- XBMC:
- More code modernization for dialogVideoInfo (PR:10889, 3 commits, 2 files changed)
- [guilib] CGUIWindowManager: Fix destruction of windows on Kodi exit (PR:11918, 1 commit, 2 files changed)
- Added: [pkg] PR:11923: [rbpi] Make sure we strip binaries in Release build
New LibreELEC.tv Leia build #0402:
Generic
# uname -a
Linux NUC 4.10.8 #1 SMP Sun Apr 2 21:04:30 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170402210247-#0402-g8cd9fa5 [Build #0402]
# Kodi version
Based on tip of
XBMC master (fcfa9bcc,
- Include [env] PR:1469: samba: update to samba-4.x
- Include [pkg] PR:11929: [filesystem][dialogs] Add context menus for favourites home screen widget
Build Highlights:
- [filesystem][dialogs] Add context menus for favourites home screen widget
- samba: update to 4.6.2 (fix for regression introduced in 4.6.1)
Build Details:
- XBMC:
- CGUIWindowManager: Protect against null window access (PR:11927, 1 commit, 1 file changed)
- Added: [pkg] PR:11929: [filesystem][dialogs] Add context menus for favourites home screen widget
Milhouse
any news on anonymous smb access to windows?
Also with build #0402 samba server doesn't work with anonymous access to windows
