(2017-04-11, 04:08)Milhouse Wrote: [ -> ]What issue would that be?
Sorry that was a dreadful post with no detail/log at all as got distracted.
The issue I believe is the delay in negotiating a network connection after a reboot.
The issue is no present on official Libreelec 8 or 7.95.x.
If one tries to access a video on an smb share before the network is up (seems to take 20-30 seconds after reboot and at home menu), a hard lock occurs.
A further reboot does not resolve the network connection -at all. Resulting in "invalid argument" for accessing the shares directly.
Only way to "fix" issues is to power down and disconnect from network by removing power cord then back on again.
Issue appears again after reboot.
Basically the network many times longer to be negotiated after a reboot.
This is on an intel nuc6cays so would expect it's being witnessed by anyone on a kaby lake/apollo lake nuc.
You still miss all sort of logfiles ...
New LibreELEC.tv Leia build #0411:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.9 #1 SMP Tue Apr 11 21:37:51 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170411213632-#0411-g4f4faea [Build #0411]
# Kodi version
(18.0-ALPHA1 Git:78cce57). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (4f4faeae,
changelog) and tip of
XBMC master (5fe865b1,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (1052ba94, ahead +58)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f23ba39c, +1), inputstream.rtmp (6c1af46a), peripheral.joystick (3c7ea594, +4), pvr.argustv (7135b279), pvr.demo (1606b612), pvr.dvblink (2634f6fb, +3), pvr.dvbviewer (13c6e5e7), pvr.filmon (e026519d), pvr.hdhomerun (98cb8d40), pvr.hts (2993f43d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (d4dad613), pvr.mythtv (08d609b2), pvr.nextpvr (bb21826b), pvr.njoy (1ce9aba1), pvr.octonet (8549a31c), pvr.pctv (e3b2b845), pvr.stalker (0466af9d), pvr.vbox (4215450f), pvr.vdr.vnsi (9ede401c), pvr.vuplus (d7fdd1ea, +2), pvr.wmc (5aa3b1ca)
- Exclude [env] ffmpeg-99.1010-tls-1.2.patch: upstream ffmpeg-3.3
- Include [env] compare: tvheadend42: update (pngquant)
- Include [env] patch: ffmpeg: update to ffmpeg-3.3
- Include [env] patch: rapidjson: update to rapidjson-1.1.0
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:1320: lirc cleanup: switch to upstream fixes and configuration
- Include [env] PR:1469: samba: update to samba-4.6.1
- Include [env] PR:1508: Update to RTL8192DU-efc8508
- Include [env] PR:1512: Update RTL8192EU to a7fd035
- Include [env] PR:1518: iana-etc: update to 17.04
- Include [env] PR:1519: timezone-data: update to 2017b
- Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
- Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:63: lircd: settings changes required for LE PR 1320 (service.libreelec.settings)
Build Highlights:
- ffmpeg: update to ffmpeg-3.3
Build Details:
- LibreELEC.tv:
- Update WeTek proprietary DVB modules to wetekdvb-20170404 (PR:1522, 1 commit, 1 file changed)
- linux: update to linux-4.10.9 (PR:1521, 6 commits, 7 files changed)
- busybox: cleanup unused config (PR:1517, 1 commit, 2 files changed)
- XBMC:
- [cmake] Spring cleanup aka OCD (PR:11834, 4 commits, 6 files changed)
- CHG: [droid] use native interface for mediacodec (PR:11931, 2 commits, 3 files changed)
Same problem on my intel nuc. Went back to #0331 and everything works again.
(2017-04-11, 09:51)robo989 Wrote: [ -> ] (2017-04-11, 04:08)Milhouse Wrote: [ -> ]What issue would that be?
(2017-04-12, 20:32)Soulplayer Wrote: [ -> ]Same problem on my intel nuc. Went back to #0331 and everything works again.
I have a Intel NUC NUC5i5RYH too and I have similar issue, sometimes at startup, network seem not available, scan of my mysql library is pending, my SMB share on Kodi are not available (and Kodi freeze when I try to enter to a share) but SMB share to access to Kodi on my MAC is working. I need to reboot to have it. This issue appears since many builds.
Is it normal LibreELEC Add-ons repository is not available ?
Why #0331? That is also using Samba4 so if it's a Samba4 issue you should still have it in #0331. Unless you're suggesting it's a kernel issue?
I have seen some sort of race condition where the GUI will lock up while accessing a Samba share for the first time (often in a home screen widget, (for example, if you have an smb:// based source). Not sure what's causing it, whether it's a Kodi issue or a Samba4 issue. Fairly rare though.
Are you using WiFi or wired?
(2017-04-12, 20:52)Guilouz Wrote: [ -> ]This issue appears since many builds.
Then it's unlikely to be due to a recent kernel or samba. Identifying when it started could help.
(2017-04-12, 20:52)Guilouz Wrote: [ -> ]Is it normal LibreELEC Add-ons repository is not available ?
It's out of my control. I probably will not build LE10 until the add-on repo is available in future, so won't make this mistake again.
(2017-04-12, 21:35)Milhouse Wrote: [ -> ] (2017-04-12, 20:32)Soulplayer Wrote: [ -> ]Same problem on my intel nuc. Went back to #0331 and everything works again.
I'm using wired. Perhaps the bug is still there. Just kept downgrading until it worked again. That was #0331.
Some home screen widgets worked on the latest version but some did not. If I did it via the share (NFS btw) it always works.
Verzonden vanaf mijn iPhone met Tapatalk
(2017-04-12, 21:40)Milhouse Wrote: [ -> ] (2017-04-12, 20:52)Guilouz Wrote: [ -> ]This issue appears since many builds.
I will test previous builds to see but the problem does not appear all the time
Have you any idea how I can install visualisation ? Or where I can find them for LibreELEC (zip files) ?
Before I installed the visualizations via repo but it's not working.
(2017-04-12, 21:51)Guilouz Wrote: [ -> ]Have you any idea how I can install visualisation ? Or where I can find them for LibreELEC (zip files) ?
I provided some addon zips here:
http://milhouse.libreelec.tv/builds/addons/Generic/
This includes projectm and shadertoy visualisations.
New LibreELEC.tv Leia build #0412:
Generic
# uname -a
Linux NUC 4.10.9 #1 SMP Wed Apr 12 21:04:21 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170412210302-#0412-g4f4faea [Build #0412]
# Kodi version
Based on tip of
XBMC master (478d3064,
- Include [env] patch: vfs.rar: new kodi-binary-addon
- Include [env] PR:1526: firmwares: use upstream repo [RFC]
Build Highlights:
- Add vfs.rar binary add-on (initially disabled, enable this if needed, although it's not working for me - rar files no longer appear in listing, can't be played)
- Add latest Intel Bluetooth and DSP firmware
Build Details:
- XBMC:
- [win32] Bye bye Windows Vista (PR:11953, 1 commit, 1 file changed)
- Added: [env] patch: vfs.rar: new kodi-binary-addon
- Added: [env] PR:1526: firmwares: use upstream repo [RFC]
Hello,
I try to update daily to the latest build using your update channel and discovered, LibreELEC settings is not automatically searching for new available versions when running since yesterday.
After a reboot the newest version shows up. I guess it discovers available versions only at boot.
Maybe this can get modified if it is worth the work.
Tried new build but error is still there
http://sprunge.us/MHJJ => log.
Has something changed with how NFS is handled?
(2017-04-13, 10:28)Soulplayer Wrote: [ -> ]Tried new build but error is still there
Not recently, so I can't think what is causing your NFS errors if it only happens with recent builds. I use nfs:// and don't have any problems.
RAR support has been dropped since #0409, in case anyone is using RAR files. You now need the vfs.rar addon, which I included in the last #0412 build (default state: disabled). However it doesn't appear to be working as expected as rar files can't be played and no longer appear in file listings.
New LibreELEC.tv Leia build #0413:
Generic
# uname -a
Linux NUC 4.10.10 #1 SMP Thu Apr 13 21:04:13 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170413210252-#0413-g4f4faea [Build #0413]
# Kodi version
Based on tip of
XBMC master (a279a874,
- Include [env] compare: linux: update to linux-4.10.10
- Include [env] PR:1528: linux configs: cleanup
Build Highlights:
- New 4.10.10 kernel
- Kernel options cleanup
Build Details:
- XBMC:
- Fix for UI not showing both extractflags and extractthumb (PR:6441, 1 commit, 2 files changed)
- [windows] drop FindFirstFileExW(...) workaround for Vista (PR:11960, 1 commit, 5 files changed)
- [android] update libandroidjni (PR:11961, 1 commit, 1 file changed)
- [android] Change Leanback suggestion (PR:11963, 1 commit, 1 file changed)
- Added build instructions for rapidjson OpenSuse. (#11943) (fa6a58a0)
- Corrected spacing in readme (8c662d87)
- Added: [env] compare: linux: update to linux-4.10.10
- Added: [env] PR:1528: linux configs: cleanup
