(2017-05-02, 12:54)HiassofT Wrote: [ -> ] (2017-05-02, 03:03)khaoohs Wrote: [ -> ]0417 remote working logs
LibreELEC:~ # pastebinit .kodi/temp/kodi.log
http://sprunge.us/aKAD
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/HXTc
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/LgKf
Thanks for the logs! Could you try disabling lirc in LE settings and report back if that works?
so long,
Hias
Yes, thank you for the assistance. Didn't realize there was a change to the remote service that would require this change.
Milhouse both me previosly reported bugs are still present in #0502. Did you have a chance to look at the logs?
_Spook_ I'm afraid I'm not a Kodi developer - I provide these builds so that Kodi developers can investigate when such issues are raised. Your other option is to open a trac ticket.
Quote:Have you tried a clean install from LibreELEC 8.0.1 disk image, then upgrading to the latest test build? Make a backup of your data first.
Can you also upload a logfile zip from #0417 when using only the Intel GPU, ie. the logfiles from a working system.
I really do not know Linux, can you give me all the files in one archive?
New LibreELEC.tv Leia build #0503:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.13 #1 SMP Wed May 3 21:06:57 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170503210537-#0503-g33a82f9 [Build #0503]
# Kodi version
(18.0-ALPHA1 Git:91a9066). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (33a82f91,
changelog) and tip of
XBMC master (80fc2616,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (64f7e73d, ahead +61)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f23ba39c), inputstream.rtmp (1052cd37, +2), peripheral.joystick (07aa1fe8, +1), pvr.argustv (8f898149, +2), pvr.demo (978f4289, +2), pvr.dvblink (b7d887c1, +2), pvr.dvbviewer (d099cfad, +2), pvr.filmon (0f1d34d4, +2), pvr.hdhomerun (ab911693, +2), pvr.hts (3911c7fe, +2), pvr.iptvsimple (f83990a4, +4), pvr.mediaportal.tvserver (367b1284, +2), pvr.mythtv (30cc7e23, +1), pvr.nextpvr (e6ece9fa, +2), pvr.njoy (296f558f, +2), pvr.octonet (2a63777b, +2), pvr.pctv (eab5f856, +2), pvr.stalker (62b7908d, +2), pvr.vbox (60017353, +2), pvr.vdr.vnsi (b7c3f3b0, +2), pvr.vuplus (78df0306, +2), pvr.wmc (27a88ca2, +2), vfs.rar (26800ebe, +1)
- Exclude [env] ffmpeg-99.1010-tls-1.2.patch: upstream ffmpeg-3.3
- Include [env] compare: linux: update to linux-4.10.13
- Include [env] patch: vfs addons: add vfs.rar, vfs.sacd and vfs.sftp kodi-binary-addons
- Include [env] patch: imagedecoder.raw: update imagedecoder.raw
- Include [env] patch: screensaver.shadertoy: bump screensaver.shadertoy to 434f5ce
- Include [env] patch: visualization.projectm: bump visualization.projectm to 7489e4a
- Include [env] patch: visualization.shadertoy: bump visualization.shadertoy to ae677ac
- Include [env] patch: ffmpeg: update to ffmpeg-3.3
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.2
- Include [env] PR:1582: tvheadend42: update addon
- Include [pkg] PR:2: Update b43 firmware (wlan-firmware)
- Include [pkg] PR:24: Remove not used part (inputstream.adaptive)
- Include [pkg] PR:62: change smbd and nmbd location (service.libreelec.settings)
- Include [pkg] PR:65: update language from transifex (service.libreelec.settings)
- Include [pkg] PR:72: Remove not used part (pvr.mythtv)
- Include [pkg] PR:73: libXBMC_codec.h removed and changed to libXBMC_pvr.h (pvr.mythtv)
- Include [pkg] PR:12034: KODI: Update NEON support
Build Highlights:
- [PVR] Another round of code cleanup
- libnfs: Fix bug in nfs_link when using the wrong(invalid) handle when dropping cache
Build Details:
- XBMC:
- [cmake] copy_files_from_filelist_to_buildtree: evaluate all variables (PR:12043, 1 commit, 1 file changed)
- [PVR] Another round of code cleanup (PR:12044, 17 commits, 41 files changed)
- libnfs:
- Add example util for nfs_link() (24064e96)
- Fix bug in nfs_link when using the wrong(invalid) handle when dropping cache (64f7e73d)
- pvr.octonet:
- Remove not used part (e9f0d6bf)
- libXBMC_codec.h removed and changed to libXBMC_pvr.h also fix compile fault after last request (2a63777b)
(2017-05-03, 22:41)sboa Wrote: [ -> ]Quote:Have you tried a clean install from LibreELEC 8.0.1 disk image, then upgrading to the latest test build? Make a backup of your data first.
Please upload the requested #0417 logfile (when using only the Intel GPU) before you blow your system away.
Follow the following instructions to perform a clean install, but first remove your Geforce card before proceeding as that's only going to confuse matters.
1) To perform a clean install, download the USB-SD Creator tool from
https://libreelec.tv/downloads/ then select the "Generic AMD/Intel" build (currently LibreELEC 8.0.1). Follow the prompts and it will write a bootable image to your USB memory stick.
2) Boot the USB memory stick to install LibreELEC 8.0.1 to your HTPC. Note that
IT WILL WIPE YOUR HARD DRIVE so backup any data you want to keep before attempting this clean install - use the LibreELEC Settings addon in Kodi, there's a "Backup" option.
3) Once your PC is booting into LibreELEC 8.0.1 (with working i915/Intel HDMI), copy the tar file of the latest test build into your Update folder (on the LibreELEC client) and reboot - you'll now be running the latest test build, which hopefully works as expected, with working i915 HDMI.
Milhouse
Are there any changes regarding the problem with a non-working mce remote after suspend and resuming to last tuned channel on live-tv between versions #0426 and #0430?
I did an update to #0430 but did not test that scenario again.
Did today and it works.
I did not change anything except updating to #0430.
*edit*
Forget everything.
After a complete reboot, remote does not work anymore.
This is strange...
New LibreELEC.tv Leia build #0504:
Generic
# uname -a
Linux NUC 4.10.13 #1 SMP Thu May 4 21:04:32 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170504210311-#0504-g33a82f9 [Build #0504]
# Kodi version
Based on tip of
XBMC master (b8ad238a,
- Includes latest libnfs master (7b34b940, ahead +62)
- Include [env] patch: visualization.spectrum: bump visualization.spectrum to d7d9c14
- Include [env] PR:1595: xf86-video-nvidia: update to 375.66
Build Highlights:
- xf86-video-nvidia: update to 375.66
Build Details:
- XBMC:
- [estuary] Fix channel osd recording indicator visibility. (PR:12051, 1 commit, 1 file changed)
- [addons] libKODI_guilib.h: Refactor (PR:12052, 2 commits, 1 file changed)
- [music] Fix CGUIWindowMusicBase::ShowSongInfo regression (PR:12055, 1 commit, 1 file changed)
- libnfs:
- Added: [env] patch: visualization.spectrum: bump visualization.spectrum to d7d9c14
- Added: [env] PR:1595: xf86-video-nvidia: update to 375.66
Hello Milhouse
Can you see hardware support for nvidia geforxe 10xx series on the horizon?
(2017-05-04, 23:40)kowalmisiek Wrote: [ -> ]Hello Milhouse
What's wrong with the current support?
One of the (many) bugs fixed in the
xf86-video-nvidia 375.66 driver:
Quote:Fixed a bug that caused the system to become unresponsive after resuming from power management suspend/hibernate.
Anyone forced to use the legacy driver might want to test this new driver.
Does hardware support for 4k hevc work for geforce 10xx??
(2017-05-05, 09:06)kowalmisiek Wrote: [ -> ]Does hardware support for 4k hevc work for geforce 10xx??
fritsch replied to you on this a few weeks ago and I don't think the situation has changed since then:
(2017-04-19, 18:19)fritsch Wrote: [ -> ] (2017-04-19, 17:35)kowalmisiek Wrote: [ -> ]Hello milhouse
Is there any chance to support geforce 1050 in new builds? (Hevc 10bit)
No single chance. VDPAU is not developed anymore by nvidia, so it's stagnating with 8 bit hevc only. It has no future anyways as it's bound to X11 which is slowly dieing ...
So yes it should do 8bit HEVC (but not 10bit), however I don't know about 4K HEVC support - maybe someone with a Geforce 10-series card and 4K display can chime in?
If you're in the market for a new HTPC video card you might want to avoid Nvidia GPUs based on @fritsch's comments. Go with Intel or AMD as they both support VAAPI.
I do not know what to do? At first I bought a radeon rx 460 graphics card. At the LibreELEC forum I was told that AMD is not supported by LibreELEC and I would replace the Nvidia graphics card. I replaced the geforce 1050 and now I'm going to find out again that AMD and intel graphics are working. I'm confused.
Heard that the intel card is again a problem with HD audio?
I don't know who told you that AMD is not supported, but they're wrong.
Yes Intel has it's problems but they're likely to solve them eventually.
AMD cards should be working (not aware of any critical issues), although they've got a new architecture (Vega) coming out at the end of the month so goodness knows what issues that might bring.
As for Nvidia, the situation with VDPAU makes it a lot less attractive (IMHO) due to uncertainty over whether there will be continued VDPAU support in Kodi going forward.
To be totally honest, I'd recommend a Raspberry Pi/OdroidC2 and wait for things to settle down...
