Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
New LibreELEC.tv Leia build #0516: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.11.1 #1 SMP Tue May 16 21:22:38 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170516210641-#0516-g3175ca9 [Build #0516]
# Kodi version
(18.0-ALPHA1 Git:61e98fd). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (3175ca9d, changelog) and tip of XBMC master (db1c544e, changelog) with the following modifications: Build Highlights:
  1. [cmake][addons] automate addon.xml version set
  2. linux: enable fq_codel for all projects
  3. Bump smaba to 4.6.3
Build Details:
  1. LibreELEC.tv:
    • build system: verify package downloads using sha256 checksum (PR:1597, 2 commits, 3 files changed)
    • Update RTL8192EU to c23c613 (PR:1625, 1 commit, 2 files changed)
  2. XBMC:
    • [cmake][addons] automate addon.xml version set (PR:12029, 1 commit, 36 files changed)
    • [addons] fix a wrong #if on versions.h (PR:12106, 1 commit, 1 file changed)
    • [addons] fix not defined cmake values (PR:12108, 1 commit, 1 file changed)
    • [fix] amlogic: 4k resolutions after f9d8ab7 (PR:12098, 1 commit, 1 file changed)
    • [infomanager] add skin.font infolabel (PR:12076, 1 commit, 2 files changed)
    • [cmake][addons][windows] mingw: fix x64 (PR:12104, 1 commit, 1 file changed)
    • [gui] no need to store/restore modeless dialogs while unload/load skin (PR:12105, 3 commits, 3 files changed)
  3. inputstream.rtmp:
    • change to automatic depends set on addon.xml (PR:19, 1 commit, 1 file changed)
  4. peripheral.joystick:
    • change to automatic depends set on addon.xml (PR:105, 1 commit, 2 files changed)
  5. pvr.argustv:
    • change to automatic depends set on addon.xml (PR:67, 1 commit, 3 files changed)
  6. pvr.demo:
    • change to automatic depends set on addon.xml (PR:45, 1 commit, 2 files changed)
  7. pvr.dvblink:
    • change to automatic depends set on addon.xml (PR:87, 1 commit, 3 files changed)
  8. pvr.dvbviewer:
    • change to automatic depends set on addon.xml (PR:60, 1 commit, 5 files changed)
  9. pvr.filmon:
    • change to automatic depends set on addon.xml (PR:70, 1 commit, 3 files changed)
  10. pvr.hdhomerun:
    • change to automatic depends set on addon.xml (PR:44, 1 commit, 3 files changed)
  11. pvr.hts:
    • change to automatic depends set on addon.xml (PR:302, 1 commit, 3 files changed)
  12. pvr.iptvsimple:
    • change to automatic depends set on addon.xml (PR:127, 1 commit, 3 files changed)
  13. pvr.mediaportal.tvserver:
    • change to automatic depends set on addon.xml (PR:65, 1 commit, 5 files changed)
  14. pvr.nextpvr:
    • change to automatic depends set on addon.xml (PR:60, 1 commit, 3 files changed)
  15. pvr.njoy:
    • change to automatic depends set on addon.xml (PR:38, 1 commit, 3 files changed)
  16. pvr.pctv:
    • change to automatic depends set on addon.xml (PR:47, 1 commit, 3 files changed)
  17. pvr.stalker:
    • [windows] include windows.h if something from it is needed (PR:88, 0 commits, 0 files changed)
    • change to automatic depends set on addon.xml (PR:94, 1 commit, 3 files changed)
  18. pvr.vbox:
    • change to automatic depends set on addon.xml (PR:193, 1 commit, 3 files changed)
  19. pvr.vdr.vnsi:
    • change to automatic depends set on addon.xml (PR:5, 1 commit, 2 files changed)
  20. pvr.vuplus:
    • change to automatic depends set on addon.xml (PR:62, 1 commit, 3 files changed)
  21. pvr.wmc:
    • change to automatic depends set on addon.xml (PR:53, 1 commit, 3 files changed)
  22. vfs.rar:
    • change to automatic depends set on addon.xml (PR:6, 1 commit, 2 files changed)
  23. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [env] PR:1469: samba: update to samba-4.6.3
    • Added: [env] PR:713: linux: enable fq_codel for all projects
    • Added: [pkg] patch: imagedecoder.raw: fix addon requires (imagedecoder.raw)
    • Added: [pkg] patch: inputstream.adaptive: fix addon requires (inputstream.adaptive)
    • Added: [pkg] patch: pvr.mythtv: fix addon requires (pvr.mythtv)
    • Added: [pkg] PR:12110: smbclient: cleanup smbclient configuration
(2017-05-17, 01:44)atoulmin Wrote: [ -> ]So until this gets put back in, I'm assuming H/W acceleration is broken for VAAPI users.
I'm afraid so. Cherry-picking video-related commits is not going to happen, so if master is broken it stays broken until it is fixed.
Milhouse - does this version (18) has the Kaby Lake (Intel 7th Gen CPU with HDMI 2.0) DTS-HD/Dolby True-HD Support or still the same issue as Kodi 17.1 ?
(2017-05-17, 06:53)guandms Wrote: [ -> ]Milhouse - does this version (18) has the Kaby Lake (Intel 7th Gen CPU with HDMI 2.0) DTS-HD/Dolby True-HD Support or still the same issue as Kodi 17.1 ?
Not entirely sure, to be honest - I know there are a number of problems (seemingly firmware) with Intel audio so my suspicion is that it might not yet be working.
Why Microsoft only fixed the Windows drivers and not Linux is beyond me ... Sad
(2017-05-17, 09:23)Milhouse Wrote: [ -> ]
This issue has zero (0) to do with kodi.
I know Kodi is not to blame, it's Microsoft Smile But it's ruing the experience of Kodi Smile
(2017-05-18, 07:07)guandms Wrote: [ -> ]I know Kodi is not to blame, it's Microsoft Smile But it's ruing the experience of Kodi Smile
Microsoft has nothing to do with the linux firmware and driver. It's and Intel and Linux kernel issue.
EDIT: And Microsoft did not fix the driver, Intel did.
New LibreELEC.tv Leia build #0517: Generic
# uname -a
Linux NUC 4.11.1 #1 SMP Wed May 17 21:07:12 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170517210512-#0517-g3175ca9 [Build #0517]
# Kodi version
Based on tip of LibreELEC.tv master (3175ca9d, changelog) and tip of XBMC master (bfae7ccf, changelog) with the following modifications: Build Highlights:
  1. Kodi: more addon updates
  2. Update SMB GUI settings patch (add optional overwrite; remove optimisation that caused a crash)
Build Details:
  1. XBMC:
    • [Windows] Let's actually package the available add-ons in the installer (PR:12112, 1 commit, 2 files changed)
    • [addons] Remove not needed parts (PR:12109, 3 commits, 32 files changed)
    • [pvr] rename addon callbacks to a "C" name (PR:12115, 1 commit, 2 files changed)
    • [cmake][addons] change binary addon includes cmake install way (PR:12114, 2 commits, 13 files changed)
    • [pvr] change to new addon to kodi callback way (PR:12116, 1 commit, 13 files changed)
    • [Music]Fix Cue sheet regression and improve handling (PR:12082, 2 commits, 13 files changed)
  2. peripheral.joystick:
    • remove no more needed version functions (PR:106, 1 commit, 2 files changed)
    • update debian control (PR:107, 1 commit, 1 file changed)
  3. pvr.argustv:
    • remove no more needed version functions (PR:68, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:69, 2 commits, 3 files changed)
  4. pvr.demo:
    • remove no more needed version functions (PR:46, 1 commit, 2 files changed)
    • Update addon Version related to Kodi changes (PR:47, 2 commits, 2 files changed)
  5. pvr.dvblink:
    • remove no more needed version functions (PR:88, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:89, 2 commits, 3 files changed)
  6. pvr.dvbviewer:
    • remove no more needed version functions (PR:61, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:62, 2 commits, 3 files changed)
  7. pvr.filmon:
    • remove no more needed version functions (PR:71, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:72, 2 commits, 3 files changed)
  8. pvr.hdhomerun:
    • remove no more needed version functions (PR:45, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:46, 2 commits, 3 files changed)
  9. pvr.hts:
    • remove no more needed version functions (PR:303, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:304, 2 commits, 3 files changed)
  10. pvr.iptvsimple:
    • remove no more needed version functions (PR:128, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:130, 2 commits, 3 files changed)
  11. pvr.mediaportal.tvserver:
    • remove no more needed version functions (PR:66, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:67, 2 commits, 3 files changed)
  12. pvr.nextpvr:
  13. pvr.njoy:
    • remove no more needed version functions (PR:39, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:40, 2 commits, 3 files changed)
  14. pvr.pctv:
    • remove no more needed version functions (PR:48, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:49, 2 commits, 3 files changed)
  15. pvr.stalker:
    • remove no more needed version functions (PR:95, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:96, 2 commits, 3 files changed)
  16. pvr.vbox:
    • remove no more needed version functions (PR:194, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:195, 2 commits, 3 files changed)
  17. pvr.vdr.vnsi:
    • remove no more needed version functions (PR:6, 1 commit, 2 files changed)
    • Update addon Version related to Kodi changes (PR:7, 2 commits, 2 files changed)
  18. pvr.vuplus:
    • remove no more needed version functions (PR:63, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:64, 2 commits, 3 files changed)
  19. pvr.wmc:
    • remove no more needed version functions (PR:54, 1 commit, 3 files changed)
    • Update addon Version related to Kodi changes (PR:55, 2 commits, 3 files changed)
  20. Additional commits/pull requests/changes not yet merged upstream:
    • Updated [pkg] PR:12110: smbclient: cleanup smbclient configuration
    • Added: [pkg] PR:9: pvr.octonet: fix addon requires (pvr.octonet)
    • Added: [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
    • Added: [pkg] PR:74: pvr.mythtv: fix addon requires (pvr.mythtv)
(2017-05-15, 19:54)Soulplayer Wrote: [ -> ]Hello,
I have a new bug: I updated to the latest build and now there are subtitles that do not play anymore. I went back to LibreELEC-Generic.x86_64-9.0-Milhouse-20170514084713-#0513b-g24c5892 and it worked again. Is there something wrong on my side? I'm using Kodi -> Mysql -> Synology NFS
http://sprunge.us/jLRR
Thanks for all the hard work!
Soul
Still have this bug with the new builds. Any idea's? New debug: http://sprunge.us/OXcP
New LibreELEC.tv Leia build #0518: Generic
# uname -a
Linux NUC 4.11.1 #1 SMP Thu May 18 21:04:25 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170518210305-#0518-g3175ca9 [Build #0518]
# Kodi version
Based on tip of LibreELEC.tv master (3175ca9d, changelog) and tip of XBMC master (bacb134a, changelog) with the following modifications: Build Highlights:
  1. [gui][refactor] rework custom window's visible condition and modality handling
Build Details:
  1. XBMC:
    • [buildsteps][windows] postfix setup filename with architecture (PR:12118, 1 commit, 2 files changed)
    • [cmake] bump required vaapi version to 0.39 (libva 1.7.3) (PR:12107, 1 commit, 1 file changed)
    • [gui][refactor] rework custom window's visible condition and modality handling (PR:12096, 1 commit, 7 files changed)
    • [gui] refactor methods involved in loading windows (PR:12121, 2 commits, 5 files changed)
    • [adsp] change to new addon to kodi callback way (PR:12124, 1 commit, 11 files changed)
    • [peripheral] change to new addon to kodi callback way (PR:12117, 1 commit, 12 files changed)
  2. inputstream.adaptive:
    • update debian control (PR:20, 1 commit, 1 file changed)
  4. pvr.octonet:
    • change to automatic depends set on addon.xml (cd774b6e)
    • remove no more needed version functions (1ced6b3f)
    • update debian control (ff41fc9a)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1630: libva-utils: initial package
Weekly Linux 4.12-rc1 build #0518x: Generic
Same as #0518 but without the following packages:
xf86-video-nvidia-legacy (340.102)
media_build
Anyone know if its possible to get Thunderbolt 3 to work?
New LibreELEC.tv Leia build #0519: Generic
# uname -a
Linux NUC 4.11.1 #1 SMP Fri May 19 22:23:51 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170519222226-#0519-g16c93af [Build #0519]
# Kodi version
Based on tip of LibreELEC.tv master (16c93afc, changelog) and tip of XBMC master (7a55b336, changelog) with the following modifications: Build Highlights:
  1. CVideoDatabase: fix setting named seasons when updating tvshow details
Build Details:
  1. LibreELEC.tv:
    • libva-utils: initial package (PR:1630, 2 commits, 2 files changed)
  2. XBMC:
    • silence stat errors in texture cache job (PR:12123, 1 commit, 1 file changed)
    • CVideoDatabase: fix setting named seasons when updating tvshow details (PR:12099, 1 commit, 2 files changed)
    • [inputstream] change to new addon to kodi callback way (PR:12126, 1 commit, 12 files changed)
    • [cleanup] silence compiler warnings (PR:12094, 7 commits, 11 files changed)
    • [cmake] move ifdef conditions to cmake (PR:12131, 1 commit, 20 files changed)
  3. peripheral.joystick:
    • version increase after API way change (PR:108, 1 commit, 1 file changed)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:12128: detect and delete zero-byte database files
