(2017-06-02, 02:02)atoulmin Wrote: [ -> ] (2017-06-02, 00:17)Milhouse Wrote: [ -> ] (2017-06-01, 15:06)atoulmin Wrote: [ -> ]I tried the new screensaver.shadertoy with the latest build but I just get a blank screen
debug log?
Sorry about that ;-)
https://paste.ubuntu.com/24742568/
Cheers
I don't see any evidence in your log that screensaver.shadertoy is even installed. I do see you testing a couple of other screensavers (screensaver.asteroids, screensaver.rsxs.solarwinds) that are currently broken - I'll try rebuilding them this evening.
New LibreELEC.tv Leia build #0602:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.11.3 #1 SMP Fri Jun 2 21:05:26 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170602210407-#0602-gc6a4377 [Build #0602]
# Kodi version
(18.0-ALPHA1 Git:423072a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (c6a43777,
changelog) and tip of
XBMC master (c8da3706,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (128ac2f7, ahead +97)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (f1f5539d), inputstream.rtmp (d93d32d4), peripheral.joystick (d6cbf198), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (3f05af60), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (7f998e0f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (f2da22ca), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (9bbd7cf3, +9), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (40dc17d0), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
- Exclude [env] kodi-999.99.libmicrohttpd-use-internal-polling.patch: merged upstream
- Include [env] compare: kodi18a1 latest updates
- Include [env] compare: linux: update to linux-4.11.3
- Include [env] patch: libmicrohttpd: update to libmicrohttpd-0.9.55
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.4
- Include [env] PR:1655: add intel_nuc_led control
- Revert [env] PR:12207: Stop application on SIGINT and SIGTERM (reason: need to test/accomodate LE version)
- Include [pkg] patch: drm/i915: add param to disable auto color range detection (linux)
- Include [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
- Include [pkg] PR:352: Fix: set wrong variable (libcec)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
Build Highlights:
- [addons] next binary addon gui interface step
- Revert SIGTERM change (for now)
Build Details:
- XBMC:
- [addons] next binary addon gui interface step (PR:12208, 1 commit, 10 files changed)
- Stop application on SIGINT and SIGTERM (PR:12207, 1 commit, 1 file changed)
- X11 Cleanup (PR:12196, 5 commits, 22 files changed)
- [TexturePacker] Silence warnings (PR:12201, 1 commit, 2 files changed)
- [cleanup] silence compiler warnings (PR:12194, 2 commits, 4 files changed)
- [Fix]Merge album type and label correctly (PR:12216, 1 commit, 1 file changed)
- fix in-tree add-on build environment (PR:12218, 1 commit, 1 file changed)
- Reverted: [env] PR:12207: Stop application on SIGINT and SIGTERM (reason: need to test/accomodate LE version)
(2017-06-02, 12:55)Milhouse Wrote: [ -> ]I don't see any evidence in your log that screensaver.shadertoy is even installed. I do see you testing a couple of other screensavers (screensaver.asteroids, screensaver.rsxs.solarwinds) that are currently broken - I'll try rebuilding them this evening.
I've spoken with @
popcornmix about screensaver.shadertoy (which currently crashes kodi:
http://sprunge.us/PXSL) and it's not a quick fix but something he'll look at and I'll post an update when there is a working version.
I've posted an update for screensaver.asteroids, this is confirmed working with #0602.
I've also posted updates for screensaver.rsxs - Solarwinds is working, Euphoria is working, but Hyperspace and Skyrocket do not work:
00:00:30.096 T:139928765511744 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
00:00:30.098 T:139928765511744 DEBUG: ------ Window Init () ------
00:00:30.098 T:139928765511744 DEBUG: ADDON: Dll Initializing - Hyperspace
00:00:30.098 T:139928765511744 DEBUG: SECTION:LoadDLL(/storage/.kodi/addons/screensaver.rsxs.hyperspace/screensaver.rsxs.hyperspace.so.2.0.0)
00:00:30.099 T:139928765511744 DEBUG: Loading: /storage/.kodi/addons/screensaver.rsxs.hyperspace/screensaver.rsxs.hyperspace.so.2.0.0
00:00:30.111 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'stars'
00:00:30.112 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'size'
00:00:30.113 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'depth'
00:00:30.113 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'fov'
00:00:30.114 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'speed'
00:00:30.114 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'resolution'
00:00:30.115 T:139928765511744 DEBUG: kodi::General::get_setting - add-on 'Hyperspace' requests setting 'shaders'
00:00:30.115 T:139928765511744 FATAL: Screensaver: failed to create instance for 'screensaver.rsxs.hyperspace' and not usable!
and
00:09:00.091 T:139848792676416 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
00:09:00.092 T:139848792676416 DEBUG: ------ Window Init () ------
00:09:00.093 T:139848792676416 DEBUG: ADDON: Dll Initializing - Skyrocket
00:09:00.093 T:139848792676416 DEBUG: SECTION:LoadDLL(/storage/.kodi/addons/screensaver.rsxs.skyrocket/screensaver.rsxs.skyrocket.so.2.0.0)
00:09:00.093 T:139848792676416 DEBUG: Loading: /storage/.kodi/addons/screensaver.rsxs.skyrocket/screensaver.rsxs.skyrocket.so.2.0.0
00:09:00.111 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'rockets'
00:09:00.111 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'smoke'
00:09:00.111 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'esmoke'
00:09:00.112 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'moon'
00:09:00.112 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'clouds'
00:09:00.113 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'earth'
00:09:00.113 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'glow'
00:09:00.113 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'stars'
00:09:00.114 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'halo'
00:09:00.114 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'ambient'
00:09:00.114 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'wind'
00:09:00.114 T:139848792676416 DEBUG: kodi::General::get_setting - add-on 'Skyrocket' requests setting 'flares'
00:09:00.115 T:139848792676416 FATAL: Screensaver: failed to create instance for 'screensaver.rsxs.skyrocket' and not usable!
In both cases Kodi quits without a crashlog.
I haven't checked any of the other screensaver.rsxs addons, so they may or may not work.
please, open tickets on the add-ons as i cannot monitor these threads all the time. i will try to fix them faster than upstream breaks em but it's hard to keep up these days
edit: both skyrocket and hyperspace seems to still work at my box. i do see the same failure in the log but it loads the screensaver fine. the faulty logging is just a silly missing not condition.
so there seems there is a le specific angle to this...
Since samba updates you can not connect anymore to the mediacenter (libreelec) from computer. Even if you set the samba share in libre elec config and set user and pass or. even without you are always being asked for username and pass and you can not connect to it.
Also the mediacenter is not being listed under network so you have to call it directly with ip or dns name if you have it.
I have tried all smb versions (1,2,3) and none is working.
illiac4 are you using a custom /storage/.config/samba.conf, or stock? I'm pretty sure stock is working fine.
(2017-06-03, 02:00)ironic_monkey Wrote: [ -> ]so there seems there is a le specific angle to this...
Yep, thanks (argh!) - the real error is in the system log:
Jun 03 00:00:30 NUC kodi.sh[2740]: /usr/lib/kodi/kodi.bin: symbol lookup error: /storage/.kodi/addons/screensaver.rsxs.hyperspace/screensaver.rsxs.hyperspace.so.2.0.0: undefined symbol: png_sig_cmp
Jun 03 00:06:49 NUC kodi.sh[2824]: /usr/lib/kodi/kodi.bin: symbol lookup error: /storage/.kodi/addons/screensaver.rsxs.skyrocket/screensaver.rsxs.skyrocket.so.2.0.0: undefined symbol: png_sig_cmp
I wonder if these particular screensavers have ever worked in recent versions of LE... it's rather annoying finding stuff that doesn't work for some reason totally unrelated to why they were broken in the first place!
I guess there's some libpng dependency that now needs fixing/adding - sorry for the noise.
(2017-06-03, 05:35)illiac4 Wrote: [ -> ]This one:
https://pastebin.com/qHhk9f1d
That's the Samba server config from Samba 3 days, which isn't compatible with Samba 4. Since the
switch to Samba 4 you should "re do" any custom configuration using the latest /storage/.config/samba.conf.sample as the basis of your configuration (that post references /etc/samba/smb.conf because at the time we were not updating /storage/.config/samba.conf.sample as we do now).
Aha ok, I did not know that. Will check and fix. TNX for help.
Update:
Edited with new file and it works.
(2017-06-03, 05:20)Milhouse Wrote: [ -> ] (2017-06-03, 02:00)ironic_monkey Wrote: [ -> ]so there seems there is a le specific angle to this...
They haven't been working for sometime in the latest LE builds. I should have mentioned it sooner
(2017-06-03, 06:30)atoulmin Wrote: [ -> ]They haven't been working for sometime in the latest LE builds. I should have mentioned it sooner
Do you know if they work with LibreELEC 8.0.2 (you'll need the version of the add-on from the LE repository)? I'd check myself but I've run out of time and need to get some zzz.
