(2017-06-28, 14:09)lusephur Wrote: [ -> ]Issue still exists,.
Do I have to contact the developer of this addon see if they'll be able to correct whatever it is that's causing the issue, or is this still something to be fixed this end?
Can you pls. provide the full log (most interesting the backtraces on the beginning)
(2017-06-28, 14:12)peak3d Wrote: [ -> ] (2017-06-28, 14:09)lusephur Wrote: [ -> ]Issue still exists,.
Will do,
give me a few minutes to update and grab the crashlog
Updated to lastest via libreelec dev updater
Update ran well, device loaded, no crashes.
Then realised VPN manager was disabled
Enabled it, and kodi.bin crashed.
Full crash.log at
Quote:https://pastebin.com/uEcFRShG
(2017-06-28, 15:25)lusephur Wrote: [ -> ]Full crash.log at
That's not a crashlog, that's your normal kodi log. The crashlog can be uploaded with "cat /storage/.kodi/temp/kodi_crash.log | pastebinit"
New LibreELEC.tv Leia build #0628:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.11.7 #1 SMP Wed Jun 28 23:55:31 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170628235411-#0628-g1196fc5 [Build #0628]
# Kodi version
(18.0-ALPHA1 Git:423072a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (1196fc52,
changelog) and tip of
XBMC master (8f3dcfbc,
- Includes latest kodi-platform master (36fb4937)
- Includes latest libcec master (3953f8dc, ahead +12)
- Includes latest libnfs master (12a27fd8, ahead +114)
- Includes latest p8-platform master (2d90f986)
- Includes latest addons: inputstream.adaptive (0d403961, +2), inputstream.rtmp (6db3697a), peripheral.joystick (3ae0aee3, +3), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (a5db9ddb), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (2651886f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (fbb7e561), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (9bbd7cf3), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (3c4b1f84, +6), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7), vfs.rar (4ce78b0f)
- Include [env] compare: kodi18a1 latest updates
- Include [env] compare: linux: update to linux-4.11.7
- Include [env] patch: inputstream.rtmp: disable outdated addons that no longer build
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:1469: samba: update to samba-4.6.4
- Include [env] PR:1690: Enable -fPIC for some packages
- Include [env] PR:1726: [WIP] lirc: update to 0.10.0
- Include [pkg] PR:67: Revert "Revert "change smbd and nmbd location"" (service.libreelec.settings)
- Include [pkg] PR:352: Fix: set wrong variable (libcec)
- Include [pkg] PR:12110: smbclient: cleanup smbclient configuration
- Include [pkg] PR:12311: FIX: ensure real filename from videodb in playlists
Build Highlights:
- Addon updates
Build Details:
- XBMC:
- [cmake] AddonHelpers: fix install directory exclude syntax (PR:12381, 1 commit, 1 file changed)
- [addons] add help for load of shared library and allow use of own addon temp folder (PR:12379, 2 commits, 6 files changed)
- Joystick improvements for Game OSD (PR:12365, 11 commits, 48 files changed)
- Updated windows .bat names (PR:12384, 1 commit, 1 file changed)
- [addons] change CreateInstance function to return ADDON_STATUS (PR:12388, 1 commit, 11 files changed)
- inputstream.adaptive:
- peripheral.joystick:
- [fix] windows build failures (PR:115, 2 commits, 5 files changed)
- pvr.vdr.vnsi:
- generate 2 read-only child timers for manual repeating, allows wakeup by kodi facilities (131be107)
- fix compile error due to strlen (c352a431)
- fix episode name on recordings (37d484b1)
- drop KODI_GUILIB_API_VERSION (848c0c80)
- change default skin to estuary (45ccc3c7)
- recordings: set plotOutline to episodeName (3c4b1f84)
Weekly Linux 4.12-rc7 build #0628x:
Generic
Same as #0628 but does not include:
xf86-video-nvidia-legacy (340.102)
(2017-06-28, 13:13)Milhouse Wrote: [ -> ]@E92M3:
On the LibreELEC client, run:
systemctl stop nmbd
nmbd -iFd3 >/tmp/log
Wait 30 seconds, then...
cat /tmp/log | pastebinit
systemctl stop nmbd
Then paste the link. What is the IP address of your Windows 7 PC?
Thanks for following up sorry for the delay here is the log
this is stock LE install
http://sprunge.us/cUTR
this is tonight's build:
http://sprunge.us/CIgA
spinning wheel then drops me back to ".." with nothing listed.
w7 machine with shares is the 192.168.1.105 addresss which is listed as the master browser for workgroup.
@E92M3:
OK, so having established your master browser is a Windows 7 machine, what is the output from "smbtree -n" on LE 8.0.2 (with Samba3) and a test build (with Samba4)?
Att Milhouse,
Many thanks for your hard work here, have issue with the latest versions (i.e. 0627 & 0628)
Have reverted back to 0626 and works fine.
Issue "seems" to be with Nvidia driver? Issue - blank screen with mouse pointer but nothing else
Pastebin of crash log, core dumps ->
https://pastebin.com/ej2XdwUy
Pastebin of reverted 0626 ->
https://pastebin.com/ERftCyWg
Many thanks again
paulski999 the issue is with the vfs.rar addon, which I will no longer include in future builds (starting with #0629). That will stop the crashes, but if you need RAR support you'll have to stick on #0625 (and wait until the vfs.rar addon is added to the LE 9.0 repository - no eta on a repository push given how unstable the addon API is right now), or go back to an official LE 8.0.2 release.
(2017-06-29, 20:49)Milhouse Wrote: [ -> ]@paulski999 the issue is with the vfs.rar addon, which I will no longer include in future builds (starting with #0629). That will stop the crashes, but if you need RAR support you'll have to stick on #0625 (and wait until the vfs.rar addon is added to the LE 9.0 repository - no eta on a repository push given how unstable the addon API is right now), or go back to an official LE 8.0.2 release.
Much obliged, thanks again..
New LibreELEC.tv Leia build #0629:
Generic
# uname -a
Linux NUC 4.11.7 #1 SMP Thu Jun 29 21:22:21 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170629212100-#0629-g1196fc5 [Build #0629]
# Kodi version
Based on tip of
XBMC master (4461f46f,
Build Highlights:
- No longer build and include vfs.rar
Build Details:
- XBMC:
- Include "fmt/printf.h" if using libfmt 4 or later (PR:12389, 1 commit, 1 file changed)
- [settings] fix seq fault if addon use same setting in different groups (PR:12387, 1 commit, 1 file changed)
- Added: [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
(2017-06-29, 13:20)Milhouse Wrote: [ -> ]@E92M3:
LibreELEC (official) Version: 8.0.2
LibreELEC:~ # smbtree -n
-sh: smbtree: not found
Nightly build at least includes the utility, but doesn't list anything
LibreELEC (community) Version: devel-20170629212100-#0629-g1196fc5
LibreELEC git: 1196fc5205a0e24eaafb7c0f372967471a92ebde
LibreELEC:~ #
(2017-06-30, 06:28)E92M3 Wrote: [ -> ]Nightly build at least includes the utility, but doesn't list anything
LibreELEC:~ #
Thanks. So that confirms this is a core Samba4 issue, rather than a Kodi issue - Samba4 simply doesn't return any usable browse information. It's difficult to know why, considering how flakey Samba is as a technology.
There's something in your network, or it might be how your master browser is configured (have you changed anything in regedit?) that causes Samba4 to fail to return any browse information. It's difficult to know what this might be as Samba4 (when using default settings on LE) will work in other networks (provided the master browser supports NT1).
I'd just add the smb:// source manually to sources.xml and be done with it.
New LibreELEC.tv Leia build #0630:
Generic
# uname -a
Linux NUC 4.11.8 #1 SMP Fri Jun 30 21:05:16 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170630210356-#0630-g1196fc5 [Build #0630]
# Kodi version
Based on tip of
XBMC master (89afd116,
- Includes latest libnfs master (a0f187d9, ahead +119)
- Includes latest addons: inputstream.adaptive (0d403961, +2), inputstream.rtmp (6db3697a), peripheral.joystick (3ae0aee3, +3), pvr.argustv (b281e04f), pvr.demo (ffee02b8), pvr.dvblink (6d42eae1), pvr.dvbviewer (a5db9ddb), pvr.filmon (300c595e), pvr.hdhomerun (9073b99b), pvr.hts (2651886f), pvr.iptvsimple (dbf6011e), pvr.mediaportal.tvserver (07d73f3a), pvr.mythtv (fbb7e561), pvr.nextpvr (239dbef3), pvr.njoy (4785afd2), pvr.octonet (9bbd7cf3), pvr.pctv (f61e2541), pvr.stalker (151e3d3f), pvr.vbox (df9efea4), pvr.vdr.vnsi (89e85a00, +7), pvr.vuplus (83a729ea), pvr.wmc (93cebfc7)
- Include [env] compare: linux: update to linux-4.11.8
Build Highlights:
- Minor libnfs update
Build Details:
- XBMC:
- service addons: replace synchronous add-on hooks with event handlers (PR:12370, 2 commits, 13 files changed)
- [modernize][cleanup] Prefer 'override' usage (PR:12374, 42 commits, 687 files changed)
- [fix] coverity issues (PR:12375, 9 commits, 7 files changed)
- [cmake] fix FindSndio module (PR:12392, 1 commit, 1 file changed)
- libnfs:
- Fix compiler warning (c030d82d)
- TESTS: Verify we fail on RPC timeouts (04cdb72b)
- TESTS: Verify we do not leak memory on timeouts (659874b1)
- libnfs-raw.h: Reformat the file and remove EXTERN (55144f23)
- Remove the leading emacs-comment in nfs4.x as rpcgen does not like it. (a0f187d9)
- pvr.vdr.vnsi:
- When calling Login() sometimes vresp is set, but invalid. (PR:1, 0 commits, 0 files changed)
