Full Version: LibreELEC Testbuilds for x86_64 (Kodi 18.0)
@Devil-Strike one last thing - when filing the bug report, can you use the piotrasd build since this is based on the drm-intel-next kernel, not 4.9.0.
@Milhouse, ye no problem will use the piotrasd build for the test @fritsch, Thanks wont forget Smile
Thanks for helping.
Ok filled a bug report.
https://bugs.freedesktop.org/show_bug.cgi?id=99132
Hope its good.
Also please provide them:
cat ./devices/system/cpu/cpufreq/policy*/*
please.
(2016-12-17, 20:16)fritsch Wrote: [ -> ]Also please provide them:
please.
Wont work
LibreELEC:~ # cat ./devices/system/cpu/cpufreq/policy*/*
cat: can't open './devices/system/cpu/cpufreq/policy*/*': No such file or directory
Hi Milhouse
I'm seeing a curious behaviour with every testbuild after version #1212b (ie: 1212b does not have this issue).
It occurs using my chosen skin - Xonfluence - but does not manifest when using Estuary. The point of asking here is to narrow down what changes should be considered by the skin author, so that compatibility can be restored.
The issue is when playing a video: the pop-up seekbar graphic is displayed - and remains on-screen for the full duration of playback (even during the boot-up INTRO video):
I've confirmed this with every release since #1212b, so it seems logical that something in #1213 is throwing off the skin.
Any suggestion I can pass along to the author would be much appreciated.
Thanks - again - for all the superb work you do pushing the Kodi Frontier forward !
The Xconfluence skin maintainer needs to make changes to the skin after PR11058 removed the infobools from Kodi 18 that were flagged as deprecated here.
Currently the skin is broken in Kodi 18 as the infobools it uses are no longer supported in Kodi 18. If the maintainer adds the new infobools then the skin should work correctly in both Kodi 17 and Kodi 18.
New LibreELEC.tv Krypton build #1217: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.0 #1 SMP Sat Dec 17 21:37:35 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161217213612-#1217-gf119807 [Build #1217]
# Kodi version
(18.0-ALPHA1 Git:17.0-beta7-7581c4a). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (f119807a, changelog) and tip of XBMC master (a182513e, changelog) with the following modifications: Build Highlights:
  1. remove the use of IAddonInterface class
  2. remove the use of template's from add-on interface
  3. Fix nvidia-legacy with 4.9.0 kernel
  4. Experimental: HEVC 10-bit support (Apollo Lake etc.)
Build Details:
  1. LibreELEC.tv:
    • kodi: update to 17.0-beta7-7581c4a (PR:1063, 4 commits, 28 files changed)
    • remove virtualbox support (PR:1064, 2 commits, 12 files changed)
    • linux: fixed Geniatech T230C patch (PR:1065, 1 commit, 3 files changed)
    • dvb-firmware: update to 1.2.0 (PR:1066, 1 commit, 1 file changed)
    • xf86-video-nvidia-legacy: linux 4.9 fix (PR:1068, 1 commit, 1 file changed)
  2. XBMC:
    • CMake: Fix TexturePacker installation directory (PR:11144, 1 commit, 1 file changed)
    • [depends] libjpg-turbo 1.5.1 (PR:11103, 1 commit, 2 files changed)
    • [addons] remove the use of IAddonInterface class (PR:11198, 1 commit, 22 files changed)
    • [PVR][video] Consolidate implementation of "Play", "Mark watched", "Mark unwatched", "Resume from" context menu items (PR:11115, 9 commits, 42 files changed)
    • [PVR] trac17040: fix crashes on pvr manager deinit/reinit. (PR:11143, 6 commits, 19 files changed)
    • [addons] remove the use of template's from add-on interface (PR:11182, 6 commits, 71 files changed)
  3. pvr.dvbviewer:
    • Implement support for transcoding (51c92983)
  4. pvr.iptvsimple:
    • add channel number tag (PR:92, 2 commits, 1 file changed)
  5. pvr.mythtv:
    • 5.0.5 (PR:96, 2 commits, 3 files changed)
  6. Additional commits/pull requests/changes not yet merged upstream:
(2016-12-18, 00:51)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #1217: Generic
# uname -a
# lsb_release
# Kodi version
Build Details:
  1. LibreELEC.tv:
  2. XBMC:
  3. pvr.dvbviewer:
  4. pvr.iptvsimple:
  5. pvr.mythtv:
ThanX Milhouse this version is running fine on my grumpy ION2 [emoji106]
Keep up the good work..
Verzonden vanaf mijn iPad met Tapatalk
(2016-12-17, 20:31)Devil-Strike Wrote: [ -> ]Wont work
Try
cat /sys/devices/system/cpu/cpufreq/policy*/*
(2016-12-18, 02:31)lrusak Wrote: [ -> ]
Try
Thanks that worked.
LibreELEC:~ # cat /sys/devices/system/cpu/cpufreq/policy*/*
0
799926
2000000
800000
4294967295
0
performance powersave
799926
intel_pstate
powersave
2000000
800000
<unsupported>
2
799926
2000000
800000
4294967295
2
799926
intel_pstate
powersave
2000000
800000
<unsupported>
LibreELEC:~ #
Oh nice hevc 10bit support, tested and works Smile
which one is the newer one and has the most benefits for apollo Lake?! #1217 or the piotrasd version from Apollo Lake Threat?!
Don't see any difference other than #1217 have hevc 10bit support and use alpha version of kodi 18.
(2016-12-18, 01:14)blokkie Wrote: [ -> ]
Confirmed, working just fine on my trusty old ION1 system. Thanks a lot!
Also the changelog is being displayed again within Dev Update. Don't know if you changed anything to get this working again but thanks anyway.
(2016-12-18, 11:44)flyingernst Wrote: [ -> ]which one is the newer one and has the most benefits for apollo Lake?! #1217 or the piotrasd version from Apollo Lake Threat?!
As far as I know the piotrasd build is LE master but with an alternative kernel, ie. drm-intel-next which includes intel drm changes that should eventually - if accepted - feed into a mainline Linux release (eg. 4.10). I'm not sure which Kodi version is in the piotrasd build, or which version of any other package - it might be Kodi 17b6/7, or it might be Kodi 18a1. It probably doesn't include built-in addons (inputstream.*, pvr.*, game.*)
My builds are also LE master, but with various upgraded components (as detailed in the changelog). So Kodi 18 not Kodi 17, latest addons built-in, but stable kernel (ie. 4.9.0).
I could start building Generic with drm-intel-next but this has a number of potential issues - none of the changes in drm-intel-next are guaranteed to go to mainline which breaks the ethos of my builds (you should, in theory, be able to switch to a future LE release with no loss of functionality), and being an intel-focused kernel this might cause issues for other vendors (nvidia, amd). So I'll be sticking with mainline kernels for my builds.
So to answer the question - my build is generally "newer" in terms of most components, however in this case piotrasd is "newer" because it uses an in-development kernel (but lacks the other upgraded components so might be "older" for those). If all you are concerned with is having the latest kernel - which is why I suggested it to for the stuck frequency - then the piotrasd build is for you.
(2016-12-18, 14:14)kekomat Wrote: [ -> ]Also the changelog is being displayed again within Dev Update. Don't know if you changed anything to get this working again but thanks anyway.
Not me but Leopold may have pushed a new release (thanks Leopold).
