2016-12-08, 16:23
(2016-12-08, 14:44)ironic_monkey Wrote: [ -> ]definitely. i'm sure that's being taken into consideration - the archive.org rom add-on has been working with retroplayer for a while i know so there should be lines of communication open already. afaik for now it's integrated in the 'other' way around - you use your add-on just as before, but instead of launching an external emu it launches with the internal ones.
All good. Currently AEL does not support Retroplayer. Is there any piece of documentation about how to use it? Also, can a Python plugin get a list of installed cores so user can choose which one to use a launcher?
