Full Version: Can't access Customize Home Screen
I'm using the current stable release of Titan on SPMC 16.4.2. I had a power surge yesterday and now I can not get in to customize my home screen buttons. I highlight the gear button selection but it just will not enter the customize menu. I've tried changing to confluence and back to titan but still no go. I also had an error with the skin helper background service so I reinstalled all the skin helper services I could find and that error seems to have gone away.
Should I just remove the skin and reinstall it?
I think your menu shortcuts are blown now. Typically happens at a pwer surge indeed.
Only option is to reset the shortcuts to defaults or to restore a skinbackup.
(2016-12-02, 22:43)marcelveldt Wrote: [ -> ]Only option is to reset the shortcuts to defaults or to restore a skinbackup.
I tried a restore but that didn't work. I'll try the reset and give it a try. Thanks.
