2016-12-03, 01:55
2016-12-03, 02:02
(2016-12-03, 01:55)vdubeau Wrote: [ -> ]Where do I find the naming conventions/folder structure for adding DVD bonus features and extras?
Naming Files
You could also search for old threads on the forum that speak to this. Cheers!
2016-12-03, 10:50
I appreciate the response but the naming conventions doesn't address naming the DVD extras. I have also searched the forums and Google. Everything I find points to this page Add-on:VideoExtras (wiki) which has no information.
2016-12-03, 17:19
(2016-12-03, 10:50)vdubeau Wrote: [ -> ]I appreciate the response but the naming conventions doesn't address naming the DVD extras. I have also searched the forums and Google. Everything I find points to this page Add-on:VideoExtras (wiki) which has no information.
Yeah, unfortunately that addon and it's creator have been banned here.
2016-12-04, 08:40
VideoExtra Add-on is discontinued. Why don'y you consider this simple solution:
Add-on:Extras (wiki)
- You can named sub folder for extra materials as you like.
- Don't forget to exclude that folder from video library scan.
Good luck.
2016-12-04, 18:58
(2016-12-04, 08:40)piodio Wrote: [ -> ]VideoExtra Add-on is discontinued.
No it hasn't. It has simply been banned form discussion on the forums due to "association" with another situation. I still use it.
OP just needs to google the author of the add-on and look at their direct documentation.
2016-12-04, 23:25
Failing that, I just write an NFO for any addon/extras - or even scrape them in as the original movie, then edit the name. Kludgey, but functional.
2016-12-19, 18:07
I have many hundreds of extras all held in a separate folder on a different disc to the TV Shows themselves.
Unfortunately the Extras addon requires the data to be held in a sub-folder of the main TV Series folder so I can't use it.
I have had to create a separate Video Source containing just files and manually go into it that way. I have called each folder the name of the TV Show.
Creating hundreds of NFO files would be very time consuming.
I am also not sure what Kodi would do if I had multiple locations for each TV Show (ie the actual episodes in one path and the extras in another)
It is a pity there isn't a slicker way to do this.
