2016-12-03, 23:54
First, let me say I've been a long time fan of the Netgear media server (EVA9150). For years nothing came close to the features and simplicity it had despite being a totally unfinished product Netgear bailed on. Also it's very wife friendly.
But after discovering Kodi and an Amazon Fire TV, I'm a convert. Working on getting the wife converted!
So with Netgear, they used NPL playlist files. Basically WPL slightly modified. I was able to convert the NPL files to WPL and copy them to the Kodi playlist directory. Of my wife's 30+ playlists, most work flawlessly. However I discovered one small issue with any playlist that has an & in the song title or artist name. Kodi seems to remove &. So for example the following line is from the WPL playlist
<media src="nfs://192.168.1.252/c/Music/Karen's Singles/Trisha Yearwood & Don Henley - Inside Out.mp3"/>
However when I actually load the playlist I see:
song1...
song2...
Trisha Yearwood Don Henley - Inside out (no time is listed)
song4...
Of course, selecting it gives the popup message that isn't not able to find the song. I've search for a solution but was not able to find one. Thought maybe you need some absolute character marking like a / or something (similar to absolutes in C#) but nothing I tried worked. I tried replacing & in the WPL with /&, /&/, &&, and even /amp; I've even saved the current playlist (from the WPL) as an m3u and the & appears in the m3u file but the song displays with no &.
Nothing seemed to work. As I have many artists and songs that have & in their names I was hoping there might be an easy solution I wasn't able to find in the forums when I search. I should note that if I go into the Artists list, it does correctly list as Trisha Yearwood & Don Henley, and it will find and play the song. So the issue seems to be only related to playlists.
I hope I've been clear in describing this and posted in the correct sub form. Is this a bug or is there a solution?
Thanks,
Rob
song1...
song2...
song4...
Thanks,
Rob
