Full Version: How to disable "first run help" dialog box at first run
Howdy,
Anyone know where the first run help dialog boxes are keep? Like xml? I am wanting to disable the dialog boxes. Ive tried removing the text and box from strings.po but an empty box appears. Confluence skin. Any ideas?
There is a setting in the skin's settings.xml (/userdata/addon_data/skin.confluence/settings.xml) - '<setting id="FirstTimeRun" type="bool">true</setting>'. Setting that to false before starting Kodi should do it.
Thanks Black eagle!
