Full Version: Xonfluence and adding / modifying view types
Hi, very much a novice Kodi user but love the Xonfluence skin as enables me to create a very user friendly and customised menu based around my own needs
One question I do have is it possible to add, for movies, different / new view types or modify existing ones to show more info ?
What I would very much like is for the standard list menu to be used, with the poster as is now, but under the poster I would like the movie info such as sound format, video type and ideally running time
Is this at all possible to do ?
Dunk
I found the options under each one of my video plugins. If you change the view and open the context menu it'll say save view. Some others have a setting item within their main menu, and you can cycle through to setup a different view for the different sections. For example: Movies & TV shows etc
