Full Version: Youtube does not work
Hi
I have the: Kodi 16 jarvis installed on the android in my android tv box
And I do not change it because it works optimally well
More:
My youtube addon does not work
I installed it by Kodi itself and the zip file
Every time I'm going to use the youtube addon it asks for those two passwords to type in the address: youtube.com/active
Before it was not like that
What can I do to solve this problem?
Already tried to customize the API Keys and did not solve
thank you so much
(2016-12-07, 21:19)bilico Wrote: [ -> ]Every time I'm going to use the youtube addon it asks for those two passwords to type in the address: youtube.com/active
Huh
Follow the instructions and it will work. Use a web browser, go to the address and watch the magic happen.
(2016-12-07, 21:35)Dangelus Wrote: [ -> ]
Huh
I did not understand
What do I have to do?
1) Enter the Youtube add-on on Kodi
2) On your laptop or phone or tablet go to youtube.com/activate
3) follow the instructions
(2016-12-07, 21:47)Dangelus Wrote: [ -> ]1) Enter the Youtube add-on on Kodi
This I already did
Only that the addon asks to do this process whenever I enter it
(2016-12-07, 21:51)bilico Wrote: [ -> ]
This I already did
I see. That's very strange. Has it always done this or just recently? If so have you installed anything else recently?
Can you produce and provide a link to your http://kodi.wiki/view/Debug_log after replicating the issue?
Always did this
Debug_log , não da , eu não estou em frente a maquina
(2016-12-07, 22:14)bilico Wrote: [ -> ]Always did this
Is the add-on up to date? There used to be this problem in an older version.
When you get back to your machine, get the log and share the link in the Youtube support thread:
http://forum.kodi.tv/showthread.php?tid=267160
As a wild guess this seems like maybe an outdated version of the addon, and/or incorrectly entered API Keys.
But please post in the YouTube support thread here.
Version 5.3.6
How do I do the: Debug_log?
Do you have a tutorial?
If you have v5.3.6, and you are doing the activation process correctly, then possibly your API keys are entered incorrectly.
Please double check them, and also check my instructions on page 1 here: http://forum.kodi.tv/showthread.php?tid=267160
(2016-12-07, 22:25)bilico Wrote: [ -> ]Version 5.3.6
Check your keys as jmh2002 suggests first but the instructions for the log is in the link: http://kodi.wiki/view/Debug_log
(2016-12-07, 22:33)jmh2002 Wrote: [ -> ]If you have v5.3.6, and you are doing the activation process correctly, then possibly your API keys are entered incorrectly.
How do I trim processes to create an API key?
Just delete the ones I've created?
Another user recently had this issue as well, he reported his solution. http://forum.kodi.tv/showthread.php?tid=...pid2469984
You can manage your connected apps @ https://security.google.com/settings/sec...ermissions
Might be worth a try as well
I refined the key layout and it worked.
I messed up when I tried the other time
Thank you all for your help
If it's more trouble, I'll come back.
