I have a problem, system is "busy" & it can't be quit normally.
In System / Information / Network i have :
Link: Connected
MAC addredd: Busy
IP address: 192.168.14
Subnet mask: 255.255.255.0
Gateway: 192.168.1.1
Primary 192.168.1.1
Secondary DNS: 192.168.1.1
Internet: Busy
Here is the
log.
Nemrod
Anything i can add ?
Nemrod
Nemrod, i cant find anyting really wrong in the log
14:23:56 T:140735167189760 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
14:23:56 T:140735167189760 WARNING: CSettingString: unknown options filler "timezones
> Could you Check if the country / timezone is causing the problem ?
14:25:19 T:4659343360 WARNING: Process directory 'nfs://192.168.1.2/volume1/films/'
> Is your network connected ?
> or is gatekeeper / firewall preventing Kodi from accessing the internet ? Please Check.
Thanks Waltman,
Where can i check it ? I see Country but time zone is automatic.
Edit #1:
I've checked on my Mac, i "was" in the US. I tried :
- To change it but to keep automatic settings
- To force my city
No change
Edit #2:
I can't access to internet from Kodi
So i reinstall OS, without formatting, X & Kodi. Now i can access internet from Kodi, i DL a skin, but i can't access to my NAS (NFS or SMB).
Any idea ?
Nemrod
Since i reinstalled both OS X, with formatting, & Kodi everything was ok until today
Time zone is ok.
I did not install anything on OS X, neither on Kodi since yesterday. Any idea ?
Here is the last
log.
Nemrod
i don't know how to interpret logs but i saw the following warnings :
Time Zone
21:40:30 T:140735227814656 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
Time zone is ok :
Network
21:45:39 T:4638035968 WARNING: Process directory 'nfs://192.168.1.6/volume1/series/' does not exist - skipping scan.
Files are stored on my NAS, connection is based on NFS :
Anything i can do to get some help ?
Nemrod
No one
Nemrod
Nemrod,
posted NFS settings are okay.
but this can't be okay
21:41:52 T:4638035968 WARNING: Process directory 'nfs://192.168.1.6/volume1/films/' does not exist - skipping scan.
are you sure this share adres is correct ? i would share it as nfs://192.1681.6/volume1/video/films...
Thanks for your answer.
No, so i deleted it and created new one.
If i do what you recommend this will mix movies, TV who's & concerts.
Nemrod
I did a clean install few weeks ago, it was ok since today, without any new software on OS X or add-on on Kodi.
I can see the following warning in the
log :
17:26:13 T:140735138181888 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:26:13 T:140735138181888 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
It is ok on OS X.
I don't understand the following warnings :
17:26:15 T:4557271040 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
17:26:16 T:140735138181888 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
And there are others ...
Is there any support from devs ?
Nemrod
I dont think those setings timezone country and timezone can be edited.
I dont think those setings timezone country and timezone can be edited. Kodi gets them from osx.
Is your region set correct ?
Is osx firewall somehow blocking kodi from internet acces ?
