Hello,
I'm a newbie here, but just recently installed Kodi 16.1 on OSX. I'm trying to install some new add-ons, but I'm just getting the error "Could not connect to repository", then "Couldn't connect to network server"
I'm at a loss as to what to do next, any advice gratefully received.
Thread moved to OSX section
(2016-12-12, 08:34)Memphiz Wrote: [ -> ]debug log (wiki)
Thanks. I figured there'd be a debug log somewhere.
Looking at said log, there are a lot of lines similar to this:
10:16:54 T:140735222067968 ERROR: SQL: [Addons20.db] The database disk image is malformed
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='metadata.common.imdb.com'
10:16:54 T:140735222067968 ERROR: GetAvailableVersions failed on addon metadata.common.imdb.com
Query: SELECT addon.version, repo.addonID AS repoID FROM addon JOIN addonlinkrepo ON addonlinkrepo.idAddon=addon.id JOIN repo ON repo.id=addonlinkrepo.idRepo WHERE NOT EXISTS (SELECT * FROM disabled WHERE disabled.addonID=repoID) AND NOT EXISTS (SELECT * FROM broken WHERE broken.addonID=addon.addonID) AND addon.addonID='visualization.waveform'
10:16:54 T:140735222067968 ERROR: GetAvailableVersions failed on addon visualization.waveform
It looks like the addons DB might have become corrupted somehow. A little concerning since I've only just installed Kodi.
