Full Version: sound sync
Hi
Kodi is fantastic Smile so thank you
But it can be so har to synchronize the sound to match the movies... at least on my 2 intel NUC's.
I wish that you would integrate a feature, like the sound settings on NVIDIA SHIELD TV.
Where you have a bouncing ball that makes a sound when it hits the surface, and have a sound offset time slider to adjust the time.
Thank you
Sry... No i know that there is an offset slider.
I don't think you actually read my post :0)
More a too for example l to actually see a ball hit a surface so that you can calibrate the sound accurate
I did read your post. Perhaps I'm missing something?
That's what the offset slider does. You sync it to the particular video you are playing.
What's the point of syncing a GUI ball if you're not playing a video? If your video is slightly out of sync you can only adjust it on the fly.
