2016-12-14, 09:40
Hi, I use Kodi to watch UHD H.264 files. As my TV Sony Bravia 65" supports H.265 files and I know Kodi 17 reads H.265 files, I have just installed Nightly build: ARMv7a (32bit) in my TV (latest version of Android). I have just made a test. With HandBrake I get an UHD H.265 file but Kodi neither see that file. It is as the hard disk with that file is empty.
Why do I have this problem?
I attach the HandBrake log:
HandBrake 0.10.5.0 - 64bit Version
OS: Microsoft Windows NT 6.2.9200.0 - 64bit
CPU: Intel® Core i7 CPU X 980 @ 3.33GHz
Ram: 12279 MB,
GPU Information:
NVIDIA GeForce GTX 660 - 21.21.13.7290
Screen: 1920x1200
Temp Dir: C:\Users\ExploringWorldFogar\AppData\Local\Temp\
Install Dir: C:\Program Files\Handbrake
Data Dir: C:\Users\ExploringWorldFogar\AppData\Roaming\HandBrake Team\HandBrake\0.10.5.0
CLI Query: -i "E:\PROVA H.265 SC.avi" -t 1 --angle 1 -c 1 -o "D:\PROVA H.265" -f mp4 --crop 0:0:0:0 --modulus 8 -e x265 -q 20 --cfr -a none --audio-fallback ac3 --markers="C:\Users\ExploringWorldFogar\AppData\Local\Temp\PROVA H-1-chapters.csv" --encoder-preset=veryfast --verbose=1
[21:51:09] hb_init: starting libhb thread
HandBrake 0.10.5 (2016021100) - MinGW x86_64 - https://handbrake.fr
12 CPUs detected
Opening E:\PROVA H.265 SC.avi...
[21:51:09] CPU: Intel® Core i7 CPU X 980 @ 3.33GHz
[21:51:09] - logical processor count: 12
[21:51:09] OpenCL device #1: NVIDIA Corporation GeForce GTX 660
[21:51:09] - OpenCL version: 1.2 CUDA
[21:51:09] - driver version: 372.90
[21:51:09] - device type: GPU
[21:51:09] - supported: no
[21:51:09] Intel Quick Sync Video support: no
[21:51:09] hb_scan: path=E:\PROVA H.265 SC.avi, title_index=1
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening E:\PROVA H.265 SC.avi/BDMV/index.bdmv
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening E:\PROVA H.265 SC.avi/BDMV/BACKUP/index.bdmv
libbluray/bluray.c:2182: nav_get_title_list(E:\PROVA H.265 SC.avi) failed
[21:51:09] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 5.0.1
libdvdread: Encrypted DVD support unavailable.
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[21:51:09] dvd: not a dvd - trying as a stream/file instead
Input #0, avi, from 'E:\PROVA H.265 SC.avi':
Duration: 00:01:07.60, start: 0.000000, bitrate: 1264360 kb/s
Stream #0.0: Video: cllc, yuv422p, 3840x2160, 25 tbn
Stream #0.1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[21:51:09] dxva2xFindVideoServiceConversion failed
[21:51:09] scan: decoding previews for title 1
Scanning title 1 of 1, preview 1, 0.00 %
Scanning title 1 of 1, preview 1, 10.00 %[21:51:10] scan: audio 0x1: pcm_s16le, rate=48000Hz, bitrate=1536000 Unknown (pcm_s16le) (2.0 ch)
Scanning title 1 of 1, preview 2, 20.00 %
Scanning title 1 of 1, preview 3, 30.00 %
Scanning title 1 of 1, preview 4, 40.00 %
Scanning title 1 of 1, preview 5, 50.00 %
Scanning title 1 of 1, preview 6, 60.00 %
Scanning title 1 of 1, preview 7, 70.00 %
Scanning title 1 of 1, preview 8, 80.00 %
Scanning title 1 of 1, preview 9, 90.00 %
Scanning title 1 of 1, preview 10, 100.00 %
Scanning title 1 of 1, preview 10, 100.00 %[21:51:14] scan: 10 previews, 3840x2160, 25.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[21:51:14] libhb: scan thread found 1 valid title(s)
+ title 1:
+ stream: E:\PROVA H.265 SC.avi
+ duration: 00:01:07
+ size: 3840x2160, pixel aspect: 1/1, display aspect: 1.78, 25.000 fps
+ autocrop: 0/0/0/0
+ support opencl: no
+ support hwd: no
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:01:07
+ audio tracks:
+ 1, Unknown (pcm_s16le) (2.0 ch) (iso639-2: und)
+ subtitle tracks:
Reading chapter markers from file C:\Users\ExploringWorldFogar\AppData\Local\Temp\PROVA H-1-chapters.csv
[21:51:14] 1 job(s) to process
[21:51:14] starting job
[21:51:14] sync: expecting 1690 video frames
[21:51:14] work: only 1 chapter, disabling chapter markers
[21:51:14] job configuration:
[21:51:14] * source
[21:51:14] + E:\PROVA H.265 SC.avi
[21:51:14] + title 1, chapter(s) 1 to 1
[21:51:14] + container: avi
[21:51:14] + data rate: 1264360 kbps
[21:51:14] * destination
[21:51:14] + D:\PROVA H.265
[21:51:14] + container: MPEG-4 (libavformat)
[21:51:14] * video track
[21:51:14] + decoder: cllc
[21:51:14] + filters
[21:51:14] + Framerate Shaper (1:27000000:1080000)
[21:51:14] + frame rate: 25.000 fps -> constant 25.000 fps
[21:51:14] + Crop and Scale (3840:2160:0:0:0:0)
[21:51:14] + source: 3840 * 2160, crop (0/0/0/0): 3840 * 2160, scale: 3840 * 2160
[21:51:14] + dimensions: 3840 * 2160, mod 8
[21:51:14] + encoder: H.265 (libx265)
[21:51:14] + preset: veryfast
[21:51:14] + quality: 20.00 (RF)
x265 [info]: HEVC encoder version 1.9
x265 [info]: build info [Windows][GCC 4.9.0][64 bit] 8bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
x265 [info]: Main profile, Level-5 (Main tier)
x265 [info]: Thread pool created using 12 threads
x265 [info]: frame threads / pool features : 3 / wpp(34 rows)
[21:51:15] reader: first SCR 0 id 0x0 DTS 0
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : hex / 57 / 1 / 2
x265 [info]: Keyframe min / max / scenecut : 25 / 250 / 40
x265 [info]: Lookahead / bframes / badapt : 15 / 4 / 0
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 2 / 1 / 1
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-20.0 / 0.60
x265 [info]: tools: rd=2 psy-rd=2.00 early-skip signhide tmvp fast-intra
x265 [info]: tools: strong-intra-smoothing lslices=8 deblock sao
[21:58:11] reader: done. 1 scr changes
[21:58:43] work: average encoding speed for job is 3.957208 fps
[21:58:43] mux: track 0, 1690 frames, 252858734 bytes, 29924.11 kbps, fifo 1024
[21:58:43] sync: got 1690 frames, 1690 expected
[21:58:43] render: 1690 frames output, 0 dropped and 0 duped for CFR/PFR
[21:58:43] render: lost time: 0 (0 frames)
[21:58:43] render: gained time: 0 (0 frames) (0 not accounted for)
[21:58:43] cllc-decoder done: 1690 frames, 0 decoder errors, 0 drops
x265 [info]: frame I: 13, Avg QP:19.42 kb/s: 184553.00
x265 [info]: frame P: 337, Avg QP:22.61 kb/s: 81984.80
x265 [info]: frame B: 1340, Avg QP:26.75 kb/s: 15330.10
x265 [info]: Weighted P-Frames: Y:13.4% UV:9.5%
x265 [info]: consecutive B-frames: 3.1% 0.6% 1.1% 0.6% 94.6%
encoded 1690 frames in 448.32s (3.77 fps), 29923.31 kb/s, Avg QP:25.87
[21:58:43] libhb: work result = 0
Encode done!
HandBrake has exited.
Ram: 12279 MB,
GPU Information:
Screen: 1920x1200
12 CPUs detected
+ title 1:
+ autocrop: 0/0/0/0
+ support hwd: no
+ chapters:
+ audio tracks:
+ subtitle tracks:
[21:51:14] * source
Encode done!
