Full Version: Play 4k media
hi I am looking to play some 4k films on my server to kodi on my smart TV, do I need an add on or something any advice appreciated thanks vall
No.
And please don't use large font sizes etc - is not good etiquette nor is it needed.
The board isn't a10ft interface Wink
I really don't get questions like these. Why not just try and play the files?!
Kodi doesn't see the file to play it, but if I don't use kodi the TV sees it and I can play it ta
(2016-12-14, 22:11)Val-Blackpool Wrote: [ -> ]Kodi doesn't see the file to play it, but if I don't use kodi the TV sees it and I can play it ta
Right. This is what you should have started your thread with Smile
What format / container is the file in?
Does Kodi see the shared directory the file is in?
Hi yes it found the shared directory but sees only 1 file in it, so added that folder separate and found it, file type mkv tried to play it and says cache full before... and doesn't play also same message when I try to play on Android tablet kodi
