2007-12-13, 19:02
Hello all,
I just thought of sharing my (brief) experience with the xbmc linux port, in this case regarding setting up multiple IR remotes.
The system i'm running xbmc in is a Debian Sid, and i have an Hauppauge PVR-250 card with one IR remote. The case holding the system is an Antec Fusion which has a VFD, aka LCD, and a volume knob. That knob is seen by the system as an IR remote itself.
1st i started to configure lircd to understand both remotes (you can use irrecord to build your own lircd.conf file in case you don't find a suitable one for your remote).
my /etc/lircd/lircd.conf file looks like this:
As you can see, there are two remotes defined. Hauppauge_A415 is the remote for the ivtv card and ClickWheel is the volume knob in the case.
Then i had to hack the lircd startup script, since it would only launch one instance of lircd. Since i have two lirc devices, /dev/lirc0 and /dev/lirc1, i replaced the LIRCD_ARGS variable in the /etc/lirc/hardware.conf file with two entries
LIRCD0_ARGS="-d /dev/lirc1 -P /var/run/lircd.hauppauge -l -o /dev/lircd"
LIRCD1_ARGS="-d /dev/lirc0 -P /var/run/lircd.soundgraph -c localhost -o /dev/lircd"
Note the -l (for listen) in the first line and the -c localhost (connect to localhost) in the second line. The 1st instance acts as lirc server and the second acts a client. This happens because applications, like xbmc, use the socket /dev/lircd to read information from. Only one lirc instance as write permission on that socket (write lock).
Then i changed the /etc/init.d/lirc file. In the start clause, i replaced
start-stop-daemon --start --quiet --exec /usr/sbin/lircd -- $LIRCD_ARGS \
< /dev/null
with
/usr/sbin/lircd $LIRCD0_ARGS
/usr/sbin/lircd $LIRCD1_ARGS
Probably the substitution could have been made in a more fashionable way, but i was in a hurry, and it works as good
Then i was able to test both inputs issuing irw.
After this, is just a matter to edit the xbmc Lircmap.xml file and define the actions for both the remotes.
Mine looks like this:
Hope it's helpfull for anyone.
Cheers,
Hugo Monteiro.
--- snip ---
begin remote
name Hauppauge_A415
bits 13
flags RC5|CONST_LENGTH
eps 30
aeps 100
one 969 811
zero 969 811
gap 114605
toggle_bit 2
plead 1097
begin codes
Go 0x17BB
Power 0x17BD
TV 0x179C
Videos 0x1798
Music 0x1799
Pictures 0x179A
Guide 0x179B
Radio 0x178C
Up 0x1794
Left 0x1796
Right 0x1797
Down 0x1795
OK 0x17A5
Back/Exit 0x179F
Menu/i 0x178D
Vol+ 0x1790
Vol- 0x1791
Prev.Ch 0x1792
Mute 0x178F
Ch+ 0x17A0
Ch- 0x17A1
Record 0x17B7
Stop 0x17B6
Rewind 0x17B2
Play 0x17B5
Forward 0x17B4
Replay/SkipBackward 0x17A4
Pause 0x17B0
SkipForward 0x179E
1 0x1781
2 0x1782
3 0x1783
4 0x1784
5 0x1785
6 0x1786
7 0x1787
8 0x1788
9 0x1789
Asterix 0x178A
0 0x1780
# 0x178E
Red 0x178B
Green 0x17AE
Yellow 0x17B8
Blue 0x17A9
end codes
end remote
begin remote
name ClickWheel
bits 24
eps 30
aeps 100
one 0 0
zero 0 0
post_data_bits 8
post_data 0xFF
gap 131993
toggle_bit 0
begin codes
WheelCC 0x010000
WheelCW 0x000100
WheelClick 0x000008
end codes
end remote
--- snip ---
< /dev/null
with
<!-- This file contains the mapping of LIRC keys to XBMC keys used in Keymap.xml -->
<lircmap>
<remote device="Hauppauge_A415">
<play>Play</play>
<pause>Pause</pause>
<stop>Stop</stop>
<forward>Forward</forward>
<reverse>Rewind</reverse>
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
<select>OK</select>
<pageplus>ChanUp</pageplus>
<pageminus>ChanDown</pageminus>
<back>Back</back>
<menu>Back/Exit</menu>
<title>Guide</title>
<info>Menu/i</info>
<skipplus>SkipForward</skipplus>
<skipminus>Replay/SkipBackward</skipminus>
<display>Text</display>
<start>Go</start>
<record>Record</record>
<volumeplus>Vol+</volumeplus>
<volumeminus>Vol-</volumeminus>
<mute>Mute</mute>
<power>Power</power>
<myvideo>Videos</myvideo>
<mymusic>Music</mymusic>
<mypictures>Pictures</mypictures>
<mytv>TV</mytv>
<one>One</one>
<two>Two</two>
<three>Three</three>
<four>Four</four>
<five>Five</five>
<six>Six</six>
<seven>Seven</seven>
<eight>Eight</eight>
<nine>Nine</nine>
<zero>Zero</zero>
<mytv>Red</mytv>
<mymusic>Green</mymusic>
<mypictures>Yellow</mypictures>
<myvideo>Blue</myvideo>
</remote>
<remote device="ClickWheel">
<volumeplus>WheelCW</volumeplus>
<volumeminus>WheelCC</volumeminus>
</remote>
</lircmap>
Cheers,
Hugo Monteiro.
