Full Version: Kodi 16.1 not playing video only "Ambilight"
Hi everyone
I am using KODI on a Raspberry, Android and on a Windows Machine. With the Windows installation I now have a problem.
When trying to play a video (regardless of Streaming or playing a local file) the Screen just flickers in different colours sort of like what I imagine what an Ambilight would do
Please check the Video here:
https://www.youtube.com/watch?v=exo4Dm8i6Ms
This is a recording of what happens when I try to play movies with my Windows 16.1 Kodi Installation. It used to work fine before, I may have accidentally changed something but cannot figure out what.
I have changed every available setting on Video back an forth (including Hardware Acceleration), updated the Video Drivers reinstalled the Codecs and uninstalled and reinstalled Kodi several times without any success.
All search on this problem ended without success.
I am close to taking the burden of reinstalling Windows but of course would like to prevent that.
Please help.
Logs
23:31:43 T:2460 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:31:43 T:2460 NOTICE: -----------------------------------------------------------------------
23:31:43 T:2460 NOTICE: Starting Kodi (16.1 Git:20160424-c327c53). Platform: Windows NT x86 32-bit
23:31:43 T:2460 NOTICE: Using Release Kodi x32 build
23:31:43 T:2460 NOTICE: Kodi compiled Apr 24 2016 by MSVC 180040629 for Windows NT x86 32-bit version 6.0 (0x06000000)
23:31:43 T:2460 NOTICE: Running on MICRO-STAR INTERNATIONAL CO., LTD U90/U100 with Windows 7 SP1, kernel: Windows NT x86 32-bit version 6.1
23:31:43 T:2460 NOTICE: Host CPU: Intel® Atom™ CPU N270 @ 1.60GHz, 2 cores available
23:31:43 T:2460 NOTICE: Desktop Resolution: 1024x600 32Bit at 60Hz
23:31:43 T:2460 NOTICE: Running with restricted rights
23:31:43 T:2460 NOTICE: Aero is enabled
23:31:43 T:2460 NOTICE: special://xbmc/ is mapped to: C:\Program Files\Kodi
23:31:43 T:2460 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\Kodi
23:31:43 T:2460 NOTICE: special://masterprofile/ is mapped to: C:\Users\Medion\AppData\Roaming\Kodi\userdata
23:31:43 T:2460 NOTICE: special://home/ is mapped to: C:\Users\Medion\AppData\Roaming\Kodi\
23:31:43 T:2460 NOTICE: special://temp/ is mapped to: C:\Users\Medion\AppData\Roaming\Kodi\cache
23:31:43 T:2460 NOTICE: The executable running is: C:\Program Files\Kodi\Kodi.exe
23:31:43 T:2460 NOTICE: Local hostname: Medion-PC
23:31:43 T:2460 NOTICE: Log File is located: C:\Users\Medion\AppData\Roaming\Kodi\kodi.log
23:31:43 T:2460 NOTICE: load settings...
23:31:43 T:2460 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
23:31:43 T:2460 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
23:31:43 T:2460 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
23:31:43 T:2460 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
23:31:43 T:2460 NOTICE: Default DVD Player: dvdplayer
23:31:43 T:2460 NOTICE: Default Video Player: dvdplayer
23:31:43 T:2460 NOTICE: Default Audio Player: paplayer
23:31:43 T:2460 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:31:43 T:2460 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
23:31:43 T:2460 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
23:31:43 T:2460 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:31:43 T:2460 NOTICE: Loaded playercorefactory configuration
23:31:43 T:2460 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:31:43 T:2460 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:31:45 T:2160 NOTICE: Found 2 Lists of Devices
23:31:45 T:2160 NOTICE: Enumerated DIRECTSOUND devices:
23:31:45 T:2160 NOTICE: Device 1
23:31:45 T:2160 NOTICE: m_deviceName : {5FE76B71-BC1D-4461-BEE9-D36FAED91359}
23:31:45 T:2160 NOTICE: m_displayName : Speakers - Lautsprecher (High Definition Audio-Gerät)
23:31:45 T:2160 NOTICE: m_displayNameExtra: DIRECTSOUND: Lautsprecher (High Definition Audio-Gerät)
23:31:45 T:2160 NOTICE: m_deviceType : AE_DEVTYPE_PCM
23:31:45 T:2160 NOTICE: m_channels : FL,FR
23:31:45 T:2160 NOTICE: m_sampleRates : 44100
23:31:45 T:2160 NOTICE: m_dataFormats : AE_FMT_FLOAT
23:31:45 T:2160 NOTICE: Device 2
23:31:45 T:2160 NOTICE: m_deviceName : default
23:31:45 T:2160 NOTICE: m_displayName : default
23:31:45 T:2160 NOTICE: Enumerated WASAPI devices:
23:31:45 T:2160 NOTICE: m_displayNameExtra: WASAPI: Lautsprecher (High Definition Audio-Gerät)
23:31:45 T:2160 NOTICE: m_sampleRates : 192000,96000,48000,44100
23:31:45 T:2160 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
23:31:45 T:2460 NOTICE: Running database version Addons20
23:31:45 T:2460 NOTICE: ADDONS: Using repository repository.xbmc.org
23:31:45 T:2460 NOTICE: Found screen: PnP-Monitor (Standard) on Mobile Intel® 945 Express Chipset Family, adapter 0.
23:31:45 T:2460 NOTICE: Primary mode: [email protected] 60.00 - Full Screen
23:31:45 T:2460 NOTICE: Additional mode: [email protected] 60.00 - Full Screen
23:31:45 T:2460 NOTICE: Previous line repeats 1 times.
23:31:45 T:2460 NOTICE: Checking resolution 16
23:31:47 T:2460 NOTICE: Running database version Addons20
23:31:47 T:2460 NOTICE: Running database version ViewModes6
23:31:47 T:2460 NOTICE: Running database version Textures13
23:31:47 T:2460 NOTICE: Running database version MyMusic56
23:31:47 T:2460 NOTICE: Running database version MyVideos99
23:31:47 T:2460 NOTICE: Running database version TV29
23:31:47 T:2460 NOTICE: Running database version Epg11
23:31:48 T:2460 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
23:31:48 T:2460 NOTICE: ActiveAE DSP - starting
23:31:48 T:2460 NOTICE: initialize done
23:31:48 T:2460 NOTICE: Running the application...
23:31:49 T:2460 NOTICE: starting upnp client
23:31:49 T:3336 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
23:31:49 T:3336 NOTICE: UDP: Listening on port 9777
23:32:06 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\Medion\AppData\Roaming\Kodi\media\Fonts\
23:32:06 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
23:32:25 T:2804 WARNING: CWin32DirectSound::GetSpace - buffer underrun - W:2688, P:50000, O:63456.
23:32:33 T:2460 ERROR: Unable to activate the previous window
23:32:39 T:2460 NOTICE: DVDPlayer: Opening: C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:32:39 T:2460 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
23:32:39 T:952 NOTICE: Creating InputStream
23:32:39 T:952 NOTICE: Creating Demuxer
23:32:40 T:952 NOTICE: Opening stream: 0 source: 256
23:32:40 T:952 NOTICE: Creating video codec with codec id: 13
23:32:40 T:952 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:32:40 T:952 NOTICE: Creating video thread
23:32:40 T:952 NOTICE: Opening stream: 1 source: 256
23:32:40 T:952 NOTICE: Finding audio codec for: 86019
23:32:40 T:1392 NOTICE: running thread: video_thread
23:32:40 T:952 NOTICE: Creating audio thread
23:32:40 T:1392 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:32:40 T:3972 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
23:32:40 T:3972 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
23:32:40 T:1392 NOTICE: fps: 25.000000, pwidth: 576, pheight: 432, dwidth: 576, dheight: 432
23:32:40 T:1392 NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
23:32:40 T:3972 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
23:32:47 T:2460 NOTICE: Previous line repeats 4 times.
23:32:47 T:2460 NOTICE: CDVDPlayer::CloseFile()
23:32:47 T:2460 NOTICE: DVDPlayer: waiting for threads to exit
23:32:47 T:952 NOTICE: CDVDPlayer::OnExit()
23:32:47 T:952 NOTICE: Closing stream player 1
23:32:47 T:952 NOTICE: Waiting for audio thread to exit
23:32:47 T:3972 NOTICE: thread end: CDVDPlayerAudio::OnExit()
23:32:47 T:952 NOTICE: Closing audio device
23:32:47 T:952 NOTICE: Deleting audio codec
23:32:47 T:952 NOTICE: Closing stream player 2
23:32:47 T:952 NOTICE: waiting for video thread to exit
23:32:47 T:1392 NOTICE: thread end: video_thread
23:32:47 T:952 NOTICE: deleting video codec
23:32:47 T:2460 NOTICE: DVDPlayer: finished waiting
23:34:10 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\Medion\AppData\Roaming\Kodi\media\Fonts\
23:34:10 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
23:34:27 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Users\Medion\AppData\Roaming\Kodi\media\Fonts\
23:34:27 T:2460 ERROR: XFILE::CDirectory::GetDirectory - Error getting special://home/media/Fonts/
23:39:49 T:2460 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
23:39:49 T:2460 NOTICE: Enabled debug logging due to GUI setting. Level 2.
23:39:49 T:2460 DEBUG: ------ Window Init () ------
23:39:54 T:2460 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:40:11 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:40:11 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:40:11 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:40:11 T:2460 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
23:40:11 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:40:11 T:2460 DEBUG: ------ Window Init (Settings.xml) ------
23:40:11 T:3656 DEBUG: Thread JobWorker start, auto delete: true
23:40:11 T:3656 DEBUG: CImageLoader:Big GrinoWork - took 115 ms to load special://skin/backgrounds/settings.jpg
23:40:11 T:2460 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
23:40:12 T:2460 DEBUG: ------ Window Deinit (Settings.xml) ------
23:40:12 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:40:12 T:2460 DEBUG: ------ Window Init (Home.xml) ------
23:40:13 T:2460 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
23:40:13 T:2460 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
23:40:14 T:2460 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
23:40:14 T:2460 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
23:40:14 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:40:14 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:40:15 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:40:15 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:40:15 T:2460 DEBUG: Activating window ID: 10025
23:40:15 T:2460 DEBUG: ------ Window Deinit (Home.xml) ------
23:40:15 T:2460 DEBUG: ------ Window Init (MyVideoNav.xml) ------
23:40:15 T:2460 DEBUG: CGUIMediaWindow::GetDirectory (C:\Videos\Family Guy\Season 8\)
23:40:15 T:2460 DEBUG: ParentPath = [C:\Videos\Family Guy\Season 8\]
23:40:15 T:2460 DEBUG: CVideoDatabase::RunQuery took 1 ms for 10 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=5
23:40:15 T:2604 DEBUG: Thread BackgroundLoader start, auto delete: false
23:40:16 T:2604 DEBUG: Thread BackgroundLoader 2604 terminating
23:40:17 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:40:17 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:40:17 T:2460 DEBUG: CGUIWindowVideoBase::OnPlayMedia C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:40:17 T:2460 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
23:40:17 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
23:40:17 T:2460 DEBUG: CVideoDatabase::GetMovieId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMovie from movie where idFile=4
23:40:17 T:2460 DEBUG: CVideoDatabase::GetEpisodeId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idEpisode from episode where idFile=4
23:40:17 T:2460 DEBUG: CVideoDatabase::GetMusicVideoId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMVideo from musicvideo where idFile=4
23:40:17 T:2460 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
23:40:17 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
23:40:17 T:2460 DEBUG: Loading settings for C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers(C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi)
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
23:40:17 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
23:40:17 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
23:40:17 T:2460 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData::CDVDRadioRDSData
23:40:17 T:2460 NOTICE: DVDPlayer: Opening: C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:40:17 T:2460 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
23:40:17 T:2460 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
23:40:17 T:2480 DEBUG: Thread DVDPlayer start, auto delete: false
23:40:17 T:2480 NOTICE: Creating InputStream
23:40:17 T:2480 DEBUG: CUtil::ScanForExternalSubtitles: Searching for subtitles...
23:40:17 T:2480 DEBUG: CUtil::ScanForExternalSubtitles: END (total time: 2 ms)
23:40:17 T:2480 NOTICE: Creating Demuxer
23:40:17 T:2480 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [avi]
23:40:17 T:2480 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
23:40:17 T:2480 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
23:40:17 T:2480 INFO: ffmpeg[9B0]: Input #0, avi, C:\Videos\Family Guy\Season 8\Family Guy S08E12.av':
23:40:17 T:2480 INFO: ffmpeg[9B0]: Metadata:
23:40:17 T:2480 INFO: ffmpeg[9B0]: encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
23:40:17 T:2480 INFO: ffmpeg[9B0]: Duration: 00:23:06.20, start: 0.000000, bitrate: 1062 kb/s
23:40:17 T:2480 INFO: ffmpeg[9B0]: Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 576x432 [SAR 1:1 DAR 4:3], 604 kb/s, 25 fps, 25 tbr, 25 tbn, 25 tbc
23:40:17 T:2480 INFO: ffmpeg[9B0]: Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 448 kb/s
23:40:17 T:2480 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
23:40:17 T:2480 DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
23:40:17 T:2480 NOTICE: Opening stream: 0 source: 256
23:40:17 T:2480 NOTICE: Creating video codec with codec id: 13
23:40:17 T:2480 DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:no MediaCodec:no DXVA:yes iMXVPU:no MMAL:no
23:40:17 T:2480 DEBUG: FactoryCodec - Video: - Opening
23:40:17 T:2480 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:40:17 T:2480 DEBUG: FactoryCodec - Video: ff-mpeg4 - Opened
23:40:17 T:2480 NOTICE: Creating video thread
23:40:17 T:2480 NOTICE: Opening stream: 1 source: 256
23:40:17 T:2480 NOTICE: Finding audio codec for: 86019
23:40:17 T:2480 DEBUG: FactoryCodec - Audio: passthrough - Opening
23:40:17 T:2480 DEBUG: FactoryCodec - Audio: passthrough - Failed
23:40:17 T:2480 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
23:40:17 T:3956 DEBUG: Thread DVDPlayerVideo start, auto delete: false
23:40:17 T:3956 NOTICE: running thread: video_thread
23:40:17 T:2480 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
23:40:17 T:2480 NOTICE: Creating audio thread
23:40:17 T:3956 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
23:40:17 T:2480 DEBUG: CEdl::ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:40:17 T:2480 DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
23:40:17 T:2480 DEBUG: CDVDPlayer::SetCaching - caching state 3
23:40:17 T:3088 DEBUG: Thread DVDPlayerAudio start, auto delete: false
23:40:17 T:3088 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
23:40:17 T:3088 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
23:40:17 T:3088 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
23:40:17 T:3088 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
23:40:17 T:3956 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
23:40:17 T:3956 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:40:17 T:3956 DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 2 threads
23:40:17 T:2804 INFO: CActiveAESink::OpenSink - initialize sink
23:40:17 T:2804 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
23:40:17 T:3956 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(40000.000000, 0)
23:40:17 T:2460 DEBUG: CApplication:TonguelayFile: OpenFile succeed, play state 2
23:40:17 T:2460 DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
23:40:18 T:1920 INFO: ffmpeg[780]: [mpeg4] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using the mpeg4_unpack_bframes bitstream filter without encoding but stream copy to fix it.
23:40:18 T:3956 DEBUG: ffmpeg[F74]: [src] w:576 h:432 pixfmt:yuv420p tb:1/25 fr:0/1 sar:1/1 sws_param:
23:40:18 T:3956 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
23:40:18 T:3956 DEBUG: Previous line repeats 1 times.
23:40:18 T:3956 NOTICE: fps: 25.000000, pwidth: 576, pheight: 432, dwidth: 576, dheight: 432
23:40:18 T:3956 DEBUG: CDVDPlayerVideo::OutputPicture - change configuration. 576x432. framerate: 25.00. format: YV12
23:40:18 T:3956 NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
23:40:18 T:3956 DEBUG: CWinRenderer::SelectRenderMethod: Requested render method: 0
23:40:18 T:3956 DEBUG: CWinRenderer::SelectRenderMethod: Selected render method 1: Pixel Shaders
23:40:18 T:3956 DEBUG: CXBMCRenderManager::Configure - 3
23:40:18 T:2460 DEBUG: created video buffer 0
23:40:18 T:2460 DEBUG: created video buffer 1
23:40:18 T:2460 DEBUG: created video buffer 2
23:40:18 T:3956 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
23:40:18 T:2480 DEBUG: CDVDPlayer::HandleMessages - player started 2
23:40:18 T:2460 DEBUG: CGUIInfoManager::SetCurrentMovie(C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi)
23:40:18 T:2460 DEBUG: CVideoDatabase::GetMovieId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMovie from movie where idFile=4
23:40:18 T:2460 DEBUG: CVideoDatabase::GetEpisodeId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idEpisode from episode where idFile=4
23:40:18 T:2460 DEBUG: CVideoDatabase::GetMusicVideoId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMVideo from musicvideo where idFile=4
23:40:18 T:2460 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
23:40:18 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
23:40:18 T:2460 DEBUG: Activating window ID: 12005
23:40:18 T:2460 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
23:40:18 T:2460 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
23:40:18 T:2460 DEBUG: CWinShader::LoadEffect - loading shader special://xbmc/system/shaders/yuv2rgb_d3d.fx
23:40:18 T:2804 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
23:40:18 T:2804 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 000E0196
23:40:18 T:2804 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
23:40:18 T:2804 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
23:40:18 T:2804 DEBUG: Audio Device : Lautsprecher (High Definition Audio-Gerät)
23:40:18 T:2804 DEBUG: Sample Rate : 48000
23:40:18 T:2804 DEBUG: Sample Format : AE_FMT_FLOAT
23:40:18 T:2804 DEBUG: Bits Per Sample : 32
23:40:18 T:2804 DEBUG: Valid Bits/Samp : 32
23:40:18 T:2804 DEBUG: Channel Count : 2
23:40:18 T:2804 DEBUG: Block Align : 8
23:40:18 T:2804 DEBUG: Avg. Bytes Sec : 384000
23:40:18 T:2804 DEBUG: Samples/Block : 32
23:40:18 T:2804 DEBUG: Format cBSize : 22
23:40:18 T:2804 DEBUG: Channel Layout : FL,FR
23:40:18 T:2804 DEBUG: Channel Mask : 3
23:40:18 T:2804 DEBUG: Frames : 720
23:40:18 T:2804 DEBUG: Frame Samples : 1440
23:40:18 T:2804 DEBUG: Frame Size : 8
23:40:18 T:2804 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
23:40:18 T:2804 DEBUG: Output Device : default
23:40:18 T:2804 DEBUG: Channel Layout: FL,FR
23:40:18 T:2160 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
23:40:18 T:2480 DEBUG: Previous line repeats 1 times.
23:40:18 T:2480 DEBUG: CDVDPlayer::HandleMessages - player started 1
23:40:18 T:2480 DEBUG: CDVDPlayer::SetCaching - caching state 0
23:40:18 T:3088 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(32000.000000, 1)
23:40:18 T:2804 DEBUG: Previous line repeats 3 times.
23:40:18 T:2804 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
23:40:18 T:3088 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
23:40:18 T:3088 NOTICE: Previous line repeats 4 times.
23:40:18 T:3088 DEBUG: CDVDPlayerAudio::HandleSyncError - average error -16256.402179 below threshold of 50000.000000
23:40:18 T:3088 DEBUG: CDVDClock:Big Griniscontinuity - CDVDPlayerAudio::HandleSyncError2 - was:204817.319665, should be:188563.477422, error:-16253.842243
23:40:25 T:3956 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
23:40:26 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:40:26 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is Fullscreen
23:40:26 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:40:26 T:2460 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
23:40:26 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:40:26 T:2460 DEBUG: ------ Window Init (MyVideoNav.xml) ------
23:40:26 T:2460 DEBUG: CGUIMediaWindow::GetDirectory (C:\Videos\Family Guy\Season 8\)
23:40:26 T:2460 DEBUG: ParentPath = [C:\Videos\Family Guy\Season 8\]
23:40:26 T:2460 DEBUG: CVideoDatabase::RunQuery took 1 ms for 10 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=5
23:40:26 T:3956 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
23:40:26 T:3244 DEBUG: Previous line repeats 1 times.
23:40:26 T:3244 DEBUG: Thread BackgroundLoader start, auto delete: false
23:40:27 T:3956 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
23:40:27 T:3244 DEBUG: Previous line repeats 8 times.
23:40:27 T:3244 DEBUG: Thread BackgroundLoader 3244 terminating
23:40:28 T:2460 DEBUG: Previous line repeats 5 times.
23:40:28 T:2460 DEBUG: ------ Window Init (Pointer.xml) ------
23:40:29 T:3956 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
23:40:29 T:2460 DEBUG: Previous line repeats 1 times.
23:40:29 T:2460 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
23:40:29 T:2460 DEBUG: Activating window ID: 12005
23:40:29 T:2460 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
23:40:29 T:2460 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
23:40:30 T:2460 DEBUG: ------ Window Init (VideoOSD.xml) ------
23:40:31 T:3956 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
23:40:32 T:2460 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
23:40:32 T:2460 NOTICE: CDVDPlayer::CloseFile()
23:40:32 T:2460 NOTICE: DVDPlayer: waiting for threads to exit
23:40:32 T:2480 NOTICE: CDVDPlayer::OnExit()
23:40:32 T:2480 NOTICE: Closing stream player 1
23:40:32 T:2480 NOTICE: Waiting for audio thread to exit
23:40:32 T:3088 NOTICE: thread end: CDVDPlayerAudio::OnExit()
23:40:32 T:3088 DEBUG: Thread DVDPlayerAudio 3088 terminating
23:40:32 T:2480 NOTICE: Closing audio device
23:40:32 T:2480 NOTICE: Deleting audio codec
23:40:32 T:2480 NOTICE: Closing stream player 2
23:40:32 T:2480 NOTICE: waiting for video thread to exit
23:40:32 T:2160 DEBUG: CActiveAE:Big GriniscardStream - audio stream deleted
23:40:32 T:2160 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
23:40:32 T:2804 DEBUG: Previous line repeats 1 times.
23:40:32 T:2804 INFO: CActiveAESink::OpenSink - initialize sink
23:40:32 T:2804 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
23:40:32 T:3956 NOTICE: thread end: video_thread
23:40:32 T:3956 DEBUG: Thread DVDPlayerVideo 3956 terminating
23:40:32 T:2480 NOTICE: deleting video codec
23:40:32 T:2480 DEBUG: CApplication::OnPlayBackStopped: play state was 2, starting 0
23:40:32 T:2480 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
23:40:32 T:2480 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
23:40:32 T:2460 NOTICE: DVDPlayer: finished waiting
23:40:32 T:2480 DEBUG: Thread DVDPlayer 2480 terminating
23:40:32 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:40:32 T:2460 DEBUG: ------ Window Deinit (VideoOSD.xml) ------
23:40:32 T:2460 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
23:40:32 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:40:32 T:2460 DEBUG: ------ Window Init (MyVideoNav.xml) ------
23:40:32 T:2460 DEBUG: CGUIMediaWindow::GetDirectory (C:\Videos\Family Guy\Season 8\)
23:40:32 T:2460 DEBUG: ParentPath = [C:\Videos\Family Guy\Season 8\]
23:40:32 T:2460 DEBUG: CVideoDatabase::RunQuery took 1 ms for 10 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=5
23:40:32 T:2460 DEBUG: Radio UECP (RDS) Processor - delete CDVDRadioRDSData::~CDVDRadioRDSData
23:40:32 T:2804 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
23:40:32 T:2188 DEBUG: Thread BackgroundLoader start, auto delete: false
23:40:32 T:2804 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 000E0196
23:40:32 T:2804 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
23:40:32 T:2804 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
23:40:32 T:2804 DEBUG: Audio Device : Lautsprecher (High Definition Audio-Gerät)
23:40:32 T:2804 DEBUG: Sample Rate : 44100
23:40:32 T:2804 DEBUG: Sample Format : AE_FMT_FLOAT
23:40:32 T:2804 DEBUG: Bits Per Sample : 32
23:40:32 T:2804 DEBUG: Valid Bits/Samp : 32
23:40:32 T:2804 DEBUG: Channel Count : 2
23:40:32 T:2804 DEBUG: Block Align : 8
23:40:32 T:2804 DEBUG: Avg. Bytes Sec : 352800
23:40:32 T:2804 DEBUG: Samples/Block : 32
23:40:32 T:2804 DEBUG: Format cBSize : 22
23:40:32 T:2804 DEBUG: Channel Layout : FL,FR
23:40:32 T:2804 DEBUG: Channel Mask : 3
23:40:32 T:2804 DEBUG: Frames : 661
23:40:32 T:2804 DEBUG: Frame Samples : 1322
23:40:32 T:2804 DEBUG: Frame Size : 8
23:40:32 T:2804 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
23:40:32 T:2804 DEBUG: Output Device : default
23:40:32 T:2804 DEBUG: Channel Layout: FL,FR
23:40:32 T:2188 DEBUG: Thread BackgroundLoader 2188 terminating
23:40:32 T:3656 DEBUG: CSaveFileStateJob:Big GrinoWork - Saving file state for video item C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:40:32 T:2804 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
23:40:37 T:2460 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:41:02 T:3656 DEBUG: Thread JobWorker 3656 terminating (autodelete)
23:41:15 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:41:15 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:41:15 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:41:16 T:2460 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
23:41:16 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:41:16 T:2460 DEBUG: ------ Window Init (Home.xml) ------
23:41:16 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:41:16 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:41:16 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:41:17 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:41:17 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:41:18 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:41:18 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:41:18 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:41:18 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:41:20 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:41:20 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:41:20 T:2460 DEBUG: Activating window ID: 10004
23:41:20 T:2460 DEBUG: ------ Window Deinit (Home.xml) ------
23:41:20 T:2460 DEBUG: ------ Window Init (Settings.xml) ------
23:41:20 T:2192 DEBUG: Thread JobWorker start, auto delete: true
23:41:21 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:41:22 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:41:22 T:2460 DEBUG: Activating window ID: 10016
23:41:22 T:2460 DEBUG: ------ Window Deinit (Settings.xml) ------
23:41:22 T:2460 DEBUG: ------ Window Init (SettingsCategory.xml) ------
23:41:25 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:41:25 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:41:26 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:41:26 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:41:27 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:41:27 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:41:28 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:41:28 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:41:29 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:41:29 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:41:29 T:2460 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:41:29 T:2460 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
23:41:30 T:2460 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
23:41:30 T:2460 NOTICE: Enabled debug logging due to GUI setting. Level 2.
23:41:30 T:2460 DEBUG: ------ Window Init () ------
23:41:33 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:41:33 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:41:33 T:2460 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:41:33 T:2460 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
23:44:42 T:2460 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
23:44:42 T:2460 NOTICE: Enabled debug logging due to GUI setting. Level 2.
23:44:42 T:2460 DEBUG: ------ Window Init () ------
23:44:44 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:44:44 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:44:44 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:44:44 T:2460 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
23:44:44 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:44:44 T:2460 DEBUG: ------ Window Init (Settings.xml) ------
23:44:44 T:1216 DEBUG: Thread JobWorker start, auto delete: true
23:44:45 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:44:45 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:44:45 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:44:45 T:2460 DEBUG: ------ Window Deinit (Settings.xml) ------
23:44:45 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:44:45 T:2460 DEBUG: ------ Window Init (Home.xml) ------
23:44:46 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:44:46 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:44:46 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:44:47 T:2460 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
23:44:47 T:2460 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
23:44:48 T:2460 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
23:44:48 T:2460 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
23:44:48 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:44:48 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:44:50 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:44:50 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:44:50 T:2460 DEBUG: Activating window ID: 10025
23:44:50 T:2460 DEBUG: ------ Window Deinit (Home.xml) ------
23:44:50 T:2460 DEBUG: ------ Window Init (MyVideoNav.xml) ------
23:44:50 T:2460 DEBUG: CGUIMediaWindow::GetDirectory (C:\Videos\Family Guy\Season 8\)
23:44:50 T:2460 DEBUG: ParentPath = [C:\Videos\Family Guy\Season 8\]
23:44:50 T:2460 DEBUG: CVideoDatabase::RunQuery took 1 ms for 10 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=5
23:44:50 T:2496 DEBUG: Thread BackgroundLoader start, auto delete: false
23:44:50 T:2496 DEBUG: Thread BackgroundLoader 2496 terminating
23:44:51 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:44:51 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:44:51 T:2460 DEBUG: CGUIWindowVideoBase::OnPlayMedia C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:44:51 T:2460 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
23:44:51 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
23:44:51 T:2460 DEBUG: CVideoDatabase::GetMovieId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMovie from movie where idFile=4
23:44:51 T:2460 DEBUG: CVideoDatabase::GetEpisodeId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idEpisode from episode where idFile=4
23:44:51 T:2460 DEBUG: CVideoDatabase::GetMusicVideoId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMVideo from musicvideo where idFile=4
23:44:51 T:2460 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
23:44:51 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
23:44:51 T:2460 DEBUG: Loading settings for C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers(C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi)
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
23:44:51 T:2460 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
23:44:51 T:2460 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
23:44:51 T:2460 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData::CDVDRadioRDSData
23:44:51 T:2460 NOTICE: DVDPlayer: Opening: C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:44:51 T:2460 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
23:44:51 T:2460 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
23:44:51 T:1192 DEBUG: Thread DVDPlayer start, auto delete: false
23:44:51 T:1192 NOTICE: Creating InputStream
23:44:51 T:1192 DEBUG: CUtil::ScanForExternalSubtitles: Searching for subtitles...
23:44:51 T:1192 DEBUG: CUtil::ScanForExternalSubtitles: END (total time: 2 ms)
23:44:51 T:1192 NOTICE: Creating Demuxer
23:44:51 T:1192 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [avi]
23:44:51 T:1192 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
23:44:51 T:1192 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
23:44:51 T:1192 INFO: ffmpeg[4A8]: Input #0, avi, C:\Videos\Family Guy\Season 8\Family Guy S08E12.av':
23:44:51 T:1192 INFO: ffmpeg[4A8]: Metadata:
23:44:51 T:1192 INFO: ffmpeg[4A8]: encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
23:44:51 T:1192 INFO: ffmpeg[4A8]: Duration: 00:23:06.20, start: 0.000000, bitrate: 1062 kb/s
23:44:51 T:1192 INFO: ffmpeg[4A8]: Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 576x432 [SAR 1:1 DAR 4:3], 604 kb/s, 25 fps, 25 tbr, 25 tbn, 25 tbc
23:44:51 T:1192 INFO: ffmpeg[4A8]: Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), fltp, 448 kb/s
23:44:51 T:1192 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
23:44:51 T:1192 DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
23:44:51 T:1192 NOTICE: Opening stream: 0 source: 256
23:44:51 T:1192 NOTICE: Creating video codec with codec id: 13
23:44:51 T:1192 DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:no MediaCodec:no DXVA:yes iMXVPU:no MMAL:no
23:44:51 T:1192 DEBUG: FactoryCodec - Video: - Opening
23:44:51 T:1192 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:44:51 T:1192 DEBUG: FactoryCodec - Video: ff-mpeg4 - Opened
23:44:51 T:1192 NOTICE: Creating video thread
23:44:51 T:1192 NOTICE: Opening stream: 1 source: 256
23:44:51 T:1192 NOTICE: Finding audio codec for: 86019
23:44:51 T:1192 DEBUG: FactoryCodec - Audio: passthrough - Opening
23:44:51 T:1192 DEBUG: FactoryCodec - Audio: passthrough - Failed
23:44:51 T:1192 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
23:44:51 T:2820 DEBUG: Thread DVDPlayerVideo start, auto delete: false
23:44:51 T:2820 NOTICE: running thread: video_thread
23:44:51 T:1192 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
23:44:51 T:1192 NOTICE: Creating audio thread
23:44:51 T:2820 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
23:44:51 T:1192 DEBUG: CEdl::ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:44:51 T:1192 DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
23:44:51 T:1192 DEBUG: CDVDPlayer::SetCaching - caching state 3
23:44:51 T:2460 DEBUG: CApplication:TonguelayFile: OpenFile succeed, play state 2
23:44:51 T:2460 DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
23:44:51 T:2176 DEBUG: Thread DVDPlayerAudio start, auto delete: false
23:44:51 T:2176 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
23:44:51 T:2176 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
23:44:51 T:2176 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
23:44:51 T:2176 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
23:44:51 T:2820 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
23:44:51 T:2820 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
23:44:51 T:2820 DEBUG: CDVDVideoCodecFFmpeg - open frame threaded with 2 threads
23:44:51 T:2804 INFO: CActiveAESink::OpenSink - initialize sink
23:44:51 T:2804 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
23:44:51 T:2820 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(40000.000000, 0)
23:44:51 T:1192 DEBUG: CDVDPlayer::SetCaching - caching state 0
23:44:52 T:2820 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
23:44:52 T:2288 INFO: ffmpeg[8F0]: [mpeg4] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using the mpeg4_unpack_bframes bitstream filter without encoding but stream copy to fix it.
23:44:52 T:2820 DEBUG: ffmpeg[B04]: [src] w:576 h:432 pixfmt:yuv420p tb:1/25 fr:0/1 sar:1/1 sws_param:
23:44:52 T:2820 DEBUG: Previous line repeats 1 times.
23:44:52 T:2820 NOTICE: fps: 25.000000, pwidth: 576, pheight: 432, dwidth: 576, dheight: 432
23:44:52 T:2820 DEBUG: CDVDPlayerVideo::OutputPicture - change configuration. 576x432. framerate: 25.00. format: YV12
23:44:52 T:2820 NOTICE: Display resolution DESKTOP : [email protected] 60.00 - Full Screen (16)
23:44:52 T:2820 DEBUG: CWinRenderer::SelectRenderMethod: Requested render method: 0
23:44:52 T:2820 DEBUG: CWinRenderer::SelectRenderMethod: Selected render method 1: Pixel Shaders
23:44:52 T:2820 DEBUG: CXBMCRenderManager::Configure - 3
23:44:52 T:2460 DEBUG: created video buffer 0
23:44:52 T:2460 DEBUG: created video buffer 1
23:44:52 T:2460 DEBUG: created video buffer 2
23:44:52 T:2820 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
23:44:52 T:1192 DEBUG: Previous line repeats 1 times.
23:44:52 T:1192 DEBUG: CDVDPlayer::HandleMessages - player started 2
23:44:52 T:2460 DEBUG: CGUIInfoManager::SetCurrentMovie(C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi)
23:44:52 T:2460 DEBUG: CVideoDatabase::GetMovieId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMovie from movie where idFile=4
23:44:52 T:2460 DEBUG: CVideoDatabase::GetEpisodeId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idEpisode from episode where idFile=4
23:44:52 T:2460 DEBUG: CVideoDatabase::GetMusicVideoId (C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi), query = select idMVideo from musicvideo where idFile=4
23:44:52 T:2460 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
23:44:52 T:2460 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
23:44:52 T:2460 DEBUG: Activating window ID: 12005
23:44:52 T:2460 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
23:44:52 T:2460 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
23:44:52 T:2460 DEBUG: Previous line repeats 1 times.
23:44:52 T:2460 DEBUG: CWinShader::LoadEffect - loading shader special://xbmc/system/shaders/yuv2rgb_d3d.fx
23:44:52 T:2804 DEBUG: Previous line repeats 1 times.
23:44:52 T:2804 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
23:44:52 T:2804 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 000E0196
23:44:52 T:2804 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
23:44:52 T:2804 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
23:44:52 T:2804 DEBUG: Audio Device : Lautsprecher (High Definition Audio-Gerät)
23:44:52 T:2804 DEBUG: Sample Rate : 48000
23:44:52 T:2804 DEBUG: Sample Format : AE_FMT_FLOAT
23:44:52 T:2804 DEBUG: Bits Per Sample : 32
23:44:52 T:2804 DEBUG: Valid Bits/Samp : 32
23:44:52 T:2804 DEBUG: Channel Count : 2
23:44:52 T:2804 DEBUG: Block Align : 8
23:44:52 T:2804 DEBUG: Avg. Bytes Sec : 384000
23:44:52 T:2804 DEBUG: Samples/Block : 32
23:44:52 T:2804 DEBUG: Format cBSize : 22
23:44:52 T:2804 DEBUG: Channel Layout : FL,FR
23:44:52 T:2804 DEBUG: Channel Mask : 3
23:44:52 T:2804 DEBUG: Frames : 720
23:44:52 T:2804 DEBUG: Frame Samples : 1440
23:44:52 T:2804 DEBUG: Frame Size : 8
23:44:52 T:2804 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
23:44:52 T:2804 DEBUG: Output Device : default
23:44:52 T:2804 DEBUG: Channel Layout: FL,FR
23:44:52 T:2160 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
23:44:52 T:2176 DEBUG: Previous line repeats 1 times.
23:44:52 T:2176 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(32000.000000, 1)
23:44:52 T:1192 DEBUG: CDVDPlayer::HandleMessages - player started 1
23:44:52 T:2804 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
23:44:52 T:2176 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
23:44:52 T:2176 NOTICE: Previous line repeats 4 times.
23:44:52 T:2176 DEBUG: CDVDPlayerAudio::HandleSyncError - average error -30714.377819 below threshold of 50000.000000
23:44:52 T:2176 DEBUG: CDVDClock:Big Griniscontinuity - CDVDPlayerAudio::HandleSyncError2 - was:216336.394450, should be:185624.576567, error:-30711.817883
23:44:55 T:2460 DEBUG: ------ Window Init (Pointer.xml) ------
23:44:55 T:2460 DEBUG: ------ Window Init (VideoOSD.xml) ------
23:44:58 T:2820 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
23:44:59 T:2460 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
23:44:59 T:2460 NOTICE: CDVDPlayer::CloseFile()
23:44:59 T:2460 NOTICE: DVDPlayer: waiting for threads to exit
23:44:59 T:1192 NOTICE: CDVDPlayer::OnExit()
23:44:59 T:1192 NOTICE: Closing stream player 1
23:44:59 T:1192 NOTICE: Waiting for audio thread to exit
23:44:59 T:2176 NOTICE: thread end: CDVDPlayerAudio::OnExit()
23:44:59 T:2176 DEBUG: Thread DVDPlayerAudio 2176 terminating
23:44:59 T:1192 NOTICE: Closing audio device
23:44:59 T:2160 DEBUG: CActiveAE:Big GriniscardStream - audio stream deleted
23:44:59 T:2160 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
23:44:59 T:1192 NOTICE: Deleting audio codec
23:44:59 T:1192 NOTICE: Closing stream player 2
23:44:59 T:2804 INFO: CActiveAESink::OpenSink - initialize sink
23:44:59 T:1192 NOTICE: waiting for video thread to exit
23:44:59 T:2804 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
23:44:59 T:2820 NOTICE: thread end: video_thread
23:44:59 T:2820 DEBUG: Thread DVDPlayerVideo 2820 terminating
23:44:59 T:1192 NOTICE: deleting video codec
23:44:59 T:1192 DEBUG: CApplication::OnPlayBackStopped: play state was 2, starting 0
23:44:59 T:1192 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
23:44:59 T:1192 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
23:44:59 T:2460 NOTICE: DVDPlayer: finished waiting
23:44:59 T:1192 DEBUG: Thread DVDPlayer 1192 terminating
23:44:59 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:44:59 T:2460 DEBUG: ------ Window Deinit (VideoOSD.xml) ------
23:44:59 T:2460 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
23:44:59 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:44:59 T:2460 DEBUG: ------ Window Init (MyVideoNav.xml) ------
23:44:59 T:2460 DEBUG: CGUIMediaWindow::GetDirectory (C:\Videos\Family Guy\Season 8\)
23:44:59 T:2460 DEBUG: ParentPath = [C:\Videos\Family Guy\Season 8\]
23:44:59 T:2460 DEBUG: CVideoDatabase::RunQuery took 1 ms for 10 items query: SELECT files.strFilename, files.playCount, bookmark.timeInSeconds, bookmark.totalTimeInSeconds FROM files LEFT JOIN bookmark ON files.idFile = bookmark.idFile AND bookmark.type = 1 WHERE files.idPath=5
23:45:00 T:2804 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
23:45:00 T:1936 DEBUG: Thread BackgroundLoader start, auto delete: false
23:45:00 T:2804 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 000E0196
23:45:00 T:2804 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
23:45:00 T:2804 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
23:45:00 T:2804 DEBUG: Audio Device : Lautsprecher (High Definition Audio-Gerät)
23:45:00 T:2804 DEBUG: Sample Rate : 44100
23:45:00 T:2804 DEBUG: Sample Format : AE_FMT_FLOAT
23:45:00 T:2804 DEBUG: Bits Per Sample : 32
23:45:00 T:2804 DEBUG: Valid Bits/Samp : 32
23:45:00 T:2804 DEBUG: Channel Count : 2
23:45:00 T:2804 DEBUG: Block Align : 8
23:45:00 T:2804 DEBUG: Avg. Bytes Sec : 352800
23:45:00 T:2804 DEBUG: Samples/Block : 32
23:45:00 T:2804 DEBUG: Format cBSize : 22
23:45:00 T:2804 DEBUG: Channel Layout : FL,FR
23:45:00 T:2804 DEBUG: Channel Mask : 3
23:45:00 T:2804 DEBUG: Frames : 661
23:45:00 T:2804 DEBUG: Frame Samples : 1322
23:45:00 T:2804 DEBUG: Frame Size : 8
23:45:00 T:2804 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
23:45:00 T:2804 DEBUG: Output Device : default
23:45:00 T:2804 DEBUG: Channel Layout: FL,FR
23:45:00 T:2160 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
23:45:00 T:2460 NOTICE: CDVDPlayer::CloseFile()
23:45:00 T:2460 NOTICE: DVDPlayer: waiting for threads to exit
23:45:00 T:2460 NOTICE: DVDPlayer: finished waiting
23:45:00 T:2460 DEBUG: Radio UECP (RDS) Processor - delete CDVDRadioRDSData::~CDVDRadioRDSData
23:45:00 T:1936 DEBUG: Thread BackgroundLoader 1936 terminating
23:45:00 T:2804 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
23:45:00 T:1216 DEBUG: CSaveFileStateJob:Big GrinoWork - Saving file state for video item C:\Videos\Family Guy\Season 8\Family Guy S08E12.avi
23:45:01 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:45:01 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:45:01 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:45:01 T:2460 DEBUG: ------ Window Deinit (Pointer.xml) ------
23:45:01 T:2460 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
23:45:01 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
23:45:01 T:2460 DEBUG: ------ Window Init (Home.xml) ------
23:45:02 T:2460 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
23:45:02 T:2460 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
23:45:02 T:2460 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
23:45:02 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:45:02 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:45:03 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:45:03 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:45:04 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:45:04 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:45:04 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:45:04 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:45:04 T:2460 DEBUG: Activating window ID: 10004
23:45:05 T:2460 DEBUG: ------ Window Deinit (Home.xml) ------
23:45:05 T:2460 DEBUG: ------ Window Init (Settings.xml) ------
23:45:06 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:45:06 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:45:06 T:2460 DEBUG: Activating window ID: 10016
23:45:06 T:2460 DEBUG: ------ Window Deinit (Settings.xml) ------
23:45:06 T:2460 DEBUG: ------ Window Init (SettingsCategory.xml) ------
23:45:07 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:45:07 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:45:08 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:45:08 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:45:09 T:2460 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
23:45:09 T:2460 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
23:45:10 T:2460 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
23:45:10 T:2460 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
23:45:11 T:2460 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
23:45:11 T:2460 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
23:45:11 T:2460 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:45:11 T:2460 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
Update:
Since I had nothing to lose I updated to 17 beta 6.
Same behaviour Confused
Please don't post full logs directly here. Remove the one above and post it to PasteBin.Com or similar and provide their link here instead.
