Full Version: Krypton Beta 7 IOS
Pages: 1 2 3
I tried Krypton Kodi betas on my iPad. All the m3u8 streams will not play. When I attempt to play an m3u8 stream on my iPad it will crash. If I disable the vtb decoder in kodi it will play the m3u8 stream but it studders bad. On Jarvis the m3u8 streams play perfect.
Which ios version
(2016-12-20, 08:32)Memphiz Wrote: [ -> ]Which ios version
http://mirrors.xbmc.org/nightlies/darwin...on-ios.deb
I asked for the ios version your device is running - not the kodi version...
(2016-12-20, 19:38)Memphiz Wrote: [ -> ]I asked for the ios version your device is running - not the kodi version...
Oh sorry misunderstood. I'm running 9.3.3 iPad Pro jailbroken.
Does it crash with other files too when vtb is enabled or only m3u8?
(2016-12-21, 08:43)Memphiz Wrote: [ -> ]Does it crash with other files too when vtb is enabled or only m3u8?
It will only crash trying to play m3u8 files when vtb is enabled other files play fine
So any idea how i could reproduce this in an essy way? (I have no m3u8 stuff)
(2016-12-22, 11:08)Memphiz Wrote: [ -> ]So any idea how i could reproduce this in an essy way? (I have no m3u8 stuff)
Download this m3u8 file and add it to video files in kyrpton kodi and try to play it
https://www.dropbox.com/s/uqiwugb8as6p5s...8.M3U?dl=0
(2016-12-22, 14:41)Workcress Wrote: [ -> ]
Any progress?
Still having the same issue with that latest nighty krypton build. Any news?
No time
I am with the same problem on my device. I am running ios 9.0.2 in a 32bits device.
All m3u8 files that I try to play result in a kodi crash.
@Workcress how do you disable vtb?
I'm having the same problem with krypton 17.1. I guess no one is working on Kodi iOS development anymore. If I disable vtb m3u8 will play but stutter bad.
This is the Kodi log. Hopefully it can help. VTB enabled. It tries to play the m3u8 and Kodi crashes
19:08:45.754 T:939016128 DEBUG: CWinSystemIOS::OnAppFocusChange: 1
19:08:45.761 T:423702528 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:08:45.761 T:423702528 NOTICE: -----------------------------------------------------------------------
19:08:45.761 T:423702528 NOTICE: Starting Kodi (17.1 Git:20170320-fc1619b). Platform: iOS ARM (Thumb) 32-bit
19:08:45.761 T:423702528 NOTICE: Using Release Kodi x32 build
19:08:45.761 T:423702528 NOTICE: Kodi compiled Mar 20 2017 by Clang 6.0 (clang-600.0.56) for iOS ARM (Thumb) 32-bit version 5.1.0 (50100)
19:08:45.762 T:423702528 NOTICE: Running on Apple Inc. iPad6,7 with iOS 10.2, kernel: Darwin ARM 64-bit version 16.3.0
19:08:45.764 T:423702528 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
19:08:45.764 T:423702528 NOTICE: Host CPU: arm64 v8, 2 cores available
19:08:45.766 T:423702528 NOTICE: ARM Features: Neon enabled
19:08:45.766 T:423702528 NOTICE: special://xbmc/ is mapped to: /private/var/containers/Bundle/Application/6FA75D72-CD4B-4048-8C78-B92F7294AB47/Kodi.app/AppData/AppHome
19:08:45.766 T:423702528 NOTICE: special://xbmcbin/ is mapped to: /private/var/containers/Bundle/Application/6FA75D72-CD4B-4048-8C78-B92F7294AB47/Kodi.app/AppData/AppHome
19:08:45.766 T:423702528 NOTICE: special://xbmcbinaddons/ is mapped to: /private/var/containers/Bundle/Application/6FA75D72-CD4B-4048-8C78-B92F7294AB47/Kodi.app/AppData/AppHome/addons
19:08:45.766 T:423702528 NOTICE: special://masterprofile/ is mapped to: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C/Documents/Kodi/userdata
19:08:45.766 T:423702528 NOTICE: special://envhome/ is mapped to: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C
19:08:45.766 T:423702528 NOTICE: special://home/ is mapped to: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C/Documents/Kodi
19:08:45.766 T:423702528 NOTICE: special://temp/ is mapped to: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C/Documents/Kodi/temp
19:08:45.766 T:423702528 NOTICE: special://logpath/ is mapped to: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C/Documents
19:08:45.766 T:423702528 NOTICE: special://frameworks/ is mapped to: /var/containers/Bundle/Application/6FA75D72-CD4B-4048-8C78-B92F7294AB47/Kodi.app/Frameworks
19:08:45.766 T:423702528 NOTICE: The executable running is: /var/containers/Bundle/Application/6FA75D72-CD4B-4048-8C78-B92F7294AB47/Kodi.app/Kodi
19:08:45.766 T:423702528 NOTICE: Local hostname: iPad
19:08:45.766 T:423702528 NOTICE: Log File is located: /private/var/mobile/Containers/Data/Application/27867F14-1902-4094-B404-DF059AB9198C/Documents//kodi.log
19:08:45.766 T:423702528 NOTICE: -----------------------------------------------------------------------
19:08:45.780 T:423702528 NOTICE: load settings...
19:08:45.793 T:423702528 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
19:08:45.795 T:423702528 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
19:08:45.798 T:423702528 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
19:08:45.798 T:423702528 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
19:08:45.801 T:423702528 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/darwin.xml
19:08:45.802 T:423702528 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/darwin_ios.xml
19:08:45.803 T:423702528 DEBUG: EnumerateDevicesBig Grinevice(default)
19:08:45.803 T:423702528 NOTICE: Found 1 Lists of Devices
19:08:45.803 T:423702528 NOTICE: Enumerated DARWINIOS devices:
19:08:45.803 T:423702528 NOTICE: Device 1
19:08:45.803 T:423702528 NOTICE: m_deviceName : default
19:08:45.803 T:423702528 NOTICE: m_displayName : Default
19:08:45.803 T:423702528 NOTICE: m_displayNameExtra:
19:08:45.803 T:423702528 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:08:45.803 T:423702528 NOTICE: m_channels : FL,FR
19:08:45.803 T:423702528 NOTICE: m_sampleRates : 44100,48000
19:08:45.803 T:423702528 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_FLOAT
19:08:45.803 T:423702528 NOTICE: m_streamTypes : No passthrough capabilities
19:08:45.804 T:423702528 DEBUG: CWebServer: increasing thread stack to 1048576
19:08:45.809 T:423702528 DEBUG: CSkinSettings: no <skinsettings> tag found
19:08:45.809 T:423702528 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:08:45.809 T:423702528 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:08:45.809 T:423702528 NOTICE: Default Video Player: VideoPlayer
19:08:45.809 T:423702528 NOTICE: Default Audio Player: paplayer
19:08:45.809 T:423702528 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:08:45.809 T:423702528 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:08:45.809 T:423702528 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:08:45.810 T:423702528 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:08:45.811 T:423702528 NOTICE: Loaded playercorefactory configuration
19:08:45.811 T:423702528 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:08:45.811 T:423702528 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:08:45.824 T:423702528 NOTICE: Running database version Addons27
19:08:45.975 T:423702528 NOTICE: ADDONS: Using repository repository.xbmc.org
19:08:46.011 T:427716608 NOTICE: void CAAudioUnitSink:ConfusedetCoreAudioPreferredSampleRate() requesting hw samplerate 44100.000000
19:08:46.012 T:427716608 NOTICE: void CAAudioUnitSink:ConfusedetCoreAudioBuffersize() setting buffer duration to 0.023220
19:08:46.013 T:427716608 NOTICE: bool CAAudioUnitSink:ConfusedetupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 32-bit Floating Point LE (44100Hz)
19:08:46.182 T:423702528 NOTICE: Found possible resolution for display 0 with 2048 x 1536
19:08:46.182 T:423702528 NOTICE: Checking resolution 16
19:08:46.182 T:423702528 NOTICE: GL_VENDOR = Apple Inc.
19:08:46.182 T:423702528 NOTICE: GL_RENDERER = Apple A9X GPU
19:08:46.182 T:423702528 NOTICE: GL_VERSION = OpenGL ES 2.0 Metal - 38.3
19:08:46.182 T:423702528 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
19:08:46.182 T:423702528 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_discard_framebuffer GL_EXT_draw_instanced GL_EXT_instanced_arrays GL_EXT_map_buffer_range GL_EXT_occlusion_query_boolean GL_EXT_pvrtc_sRGB GL_EXT_read_format_bgra GL_EXT_separate_shader_objects GL_EXT_shader_framebuffer_fetch GL_EXT_shader_texture_lod GL_EXT_shadow_samplers GL_EXT_sRGB GL_EXT_texture_filter_anisotropic GL_EXT_texture_rg GL_EXT_texture_storage GL_APPLE_clip_distance GL_APPLE_color_buffer_packed_float GL_APPLE_copy_texture_levels GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_sync GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_APPLE_texture_packed_float GL_IMG_read_format GL_IMG_texture_compression_pvrtc
19:08:46.430 T:426569728 NOTICE: Running database version Addons27
19:08:46.431 T:426569728 NOTICE: Running database version ViewModes6
19:08:46.433 T:426569728 NOTICE: Running database version Textures13
19:08:46.435 T:426569728 NOTICE: Running database version MyMusic60
19:08:46.440 T:426569728 NOTICE: Running database version MyVideos107
19:08:46.441 T:426569728 NOTICE: Running database version TV29
19:08:46.443 T:426569728 NOTICE: Running database version Epg11
19:08:46.614 T:423702528 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:08:46.800 T:423702528 NOTICE: initialize done
19:08:46.800 T:423702528 NOTICE: Running the application...
19:08:46.801 T:423702528 NOTICE: starting zeroconf publishing
19:08:46.801 T:423702528 NOTICE: starting upnp client
19:08:46.805 T:1076015104 NOTICE: ES: Starting UDP Event server on port 9777
19:08:46.805 T:1076015104 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
19:08:54.160 T:428290048 WARNING: DARWINIOS: underflow (0 vs 8192 bytes)
19:09:38.107 T:939016128 ERROR: CZeroconfOSX::registerCallback returned (domain = 10, error = -72000)
19:09:40.382 T:423702528 ERROR: Previous line repeats 1 times.
19:09:40.382 T:423702528 NOTICE: VideoPlayer: Opening: http://dnordichlslive15-i.akamaihd.net/h...aster.m3u8
19:09:40.382 T:423702528 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
19:09:40.411 T:421408768 NOTICE: Creating InputStream
19:09:40.578 T:421408768 NOTICE: Creating Demuxer
19:09:47.929 T:421408768 NOTICE: Opening stream: 0 source: 256
19:09:47.929 T:421408768 NOTICE: Creating video codec with codec id: 28
19:09:47.929 T:421408768 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
19:09:47.930 T:421408768 NOTICE: Creating video thread
19:09:47.930 T:421408768 NOTICE: Opening stream: 1 source: 256
19:09:47.930 T:421408768 NOTICE: Finding audio codec for: 86018
19:09:47.932 T:426569728 NOTICE: running thread: video_thread
19:09:47.934 T:421408768 NOTICE: Creating audio thread
19:09:47.934 T:428290048 NOTICE: running thread: CVideoPlayerAudio:Tonguerocess()
19:09:47.947 T:428290048 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
19:09:47.986 T:427716608 NOTICE: void CAAudioUnitSink:ConfusedetCoreAudioPreferredSampleRate() requesting hw samplerate 48000.000000
19:09:47.987 T:427716608 NOTICE: bool CAAudioUnitSink:ConfusedetupAudio() couldn't set requested samplerate 48000, coreaudio will resample to 44100 instead
19:09:47.987 T:427716608 NOTICE: void CAAudioUnitSink:ConfusedetCoreAudioBuffersize() setting buffer duration to 0.021333
19:09:48.013 T:427716608 NOTICE: bool CAAudioUnitSink:ConfusedetupAudio() setup audio format: [lpcm] Mixable Interleaved 2 Channel 16-bit Signed Integer LE (48000Hz)
19:09:48.014 T:426569728 ERROR: Decode - avcodec_decode_video returned failure
Pages: 1 2 3
