Boy, you're confusing things...
lathie
I appreciate that, but I tend to agree with gotham_x.
I have to admit that the one time I tried to install this, I gave up in frustration (and was too embarrassed to ask for assistance
The link "Multi-Mod for Krypton Mod" is either dead or my browser won't allow me access
Karellen
Once you get MQ7 installed, all you have to do is copy the files from the Multi-Mod into the corresponding folders from the skin and you're ready to rock!
Thanks for posting about the main download link...it's been fixed. My SSL Certificate expired and I haven't had a chance to renew it.
Actually, emiralles discusses what you need to do before trying to install MQ 7 on his
Krypton Mod thread...
(2016-10-19, 18:34)emiralles Wrote: [ -> ]IMPORTANT NOTES: Do you need install Marcelveldt Repository ( Here ) from it install the new skin helper service and skin helper widgets too.
Once you install the Repo, download and install
v1.4.0.10 of MQ 7. Then download and copy all the files from the default
Multi-Mod.
It was all right there to download pretty easy to follow the only reason that link didn't work cause the SSL expired!
Hello @
latts9923
Thanks for the info. I'll have a play with it again shortly. Never tried again after that first time around a year ago
lathie
I'm not sure what to say...
Karellen Sorry i was talking to gotham not you
I wanted to give you guys a heads up on what's coming in the next update.
1. A handful of bug fixes.
2. Menu bar animations and font features added to Main Menu "preview" in Skin Settings.
3. New option for the font glow.
4. KodiFlix TV.
The KodiFlix TV View might take a while before it's ready for release. I'll get it out to you guys ASAP.
And you mange to do all of this while working on multi mod for Leia
Thanks Bro. looking forward for the update.
Dave.B
Yeah, and that's something I've had to start making myself pay attention to. I have to make sure and not get ahead of myself or I forget to make the same changes to Leia that I'm making to Krypton.
How to add this skin Aeon MQ 7 in the shutdown menu item "Reboot to Android" for LibreELEC
(2018-01-24, 17:38)vansai Wrote: [ -> ]How to add this skin Aeon MQ 7 in the shutdown menu item "Reboot to Android" for LibreELEC
Hi vansai
Heres how to to add reboot to internal button.
1. Winscp into your box.
2. Navigate to aeon mq 7 folder
.kodi/addons/aeonmq7.krypton.mod/1080i/
3. Double click the
DialogButtonMenu.xml to open file.
4. Search for the words
shutdown you should see code similiar to following
<item id="1">
<!-- Shutdown -->
<label>31144</label>
<onclick>ShutDown</onclick>
</item>
5. Above that paste the following to add the button.
<item>
<!-- Reboot to Internal -->
<label>Reboot to Internal</label>
<onclick>System.ExecWait("/usr/sbin/rebootfromnand")</onclick>
</item>
6. Save changes and reboot box
(or switch to another skin and switch back to mq7). Press letter
S on your keyboard to bring up the power menu. Hopefully Reboot to internal option should be listed. It may take a few seconds after you click it for the box to reboot into android. Hope this works for you
