Update #48
KodiFlixTV
KodiFlixTV is now available for TV Shows! This View has a lot of options just like KodiFlix for Movies.
Record label fix
Another update to the record labels. They should now display when selecting playlists. Thanks to Dave.B for reporting the bug again.
Inactive radio button
I removed an inactive radio button from AddonBrowser.xml. Thanks to MB1968 for reporting the bug.
Hide Menu Bar option
The "Hide Menu Bar When Media is Playing" radio button was not working. For some reason my IncludesMainMenu.xml file was missing some code. I added an updated version of the file in case anyone else had the same problem.
Rating stars in Layout7
I made a few location tweaks to the rating stars for Layout7 in Music.
Rating stars in music widgets
Per Jumpy73's request, I changed the rating stars for music in widgets to display the user rating of 1-10.
Missing font in VideoLyrics
The font Exo2-BlackItalic will now display in VideoLyrics. I just noticed the problem when I was checking the log file for errors.
IMDb Top 250 in KodiFlix
I noticed there was some code for IMDb Top 250 info in KodiFlix that wasn't working. That info now displays under the focused movie.
Rating stars in KodiFlix
Some of the rating stars for KodiFlix weren't displaying the full star image.
Menu bar animations in Skin Settings "preview"
I added all the images and animations to the menu bars at the bottom of the Main Menu "preview" of Skin Settings. You can see this in action at the end of the KodiFlixTV video above.
Font shadow and glow in Skin Settings "preview"
I also added the font shadow and font glow to the Main Menu "preview" of Skin Settings. That can also be seen at the end of the KodiFlixTV video above.
Pulsing font glow
I added a new radio button to enable/disable a pulse to the font glow. Try making the font and glow color the same and stare at the font for a few seconds...argh.
Bug fixes for List3D and List3D v2
I made a few tweaks to List3D and List3D v2. The studio flags were being cut off at the bottom, so I moved all the flags up a bit. Also, the case for TV Shows was not displaying in List3D v2.
New Menu Bar Selector
I updated the Menu Bar Selector and moved it to the Main Menu Settings under the "Menu in Vertical Mode" radio button. There has always been a problem with this and I never fixed it. If you are using a horizontal menu bar and you switch to Vertical Mode, you have to manually select a Vertical Menu Bar. The selector will now switch between the Horizontal and Vertical Menu Bar list depending on whether or not you have Vertical Mode enabled. There is a new string that will get added to the MQ7's settings.xml file, so you'll need to manually set it the first time in order for the new selector to work. As an example, in Windows you'll need to edit the file C:\Users\USERNAME\AppData\Roaming\Kodi\userdata\addon_data\skin.aeonmq7.krypton.mod\settings.xml. Make sure Kodi is not running and look for the following setting...
<setting id="myverticalmenubar" type="string"></setting>
Change it to...
<setting id="myverticalmenubar" type="string">mq7menubarvertical</setting>
Open Kodi again and you should now be able to switch between all the vertical menu bars when you enable Vertical Mode.
Consolidated Skin Settings Menu
I combined Weather Effects, Holiday Effects and Star Wars Effects into one menu item named Visual Effects. Wanilton did this in his MQ 7 Krypton version, and I've been wanting to do something similar for a while.
This is a fairly hefty update. Make sure you get all the new files from the 1080i, language and media folders.
01-30-18 update
