nomnom27
I have a Patreon paid API key for OMDb, but I have read that a free key will work as well. Can anyone confirm this?
Once you have the key, go to System>Settings>Addons>Manage Dependencies>Metadata and Artwork Module>Configure>API Keys>Patreon API-Key for omdbapi.com.
I'll take a look at the detailed MPAA rating for Movies as well.
the_bo
Thanks bud. If you download this
update, the animated gif will be in the media folder. And yes, that's the code for it as well.
All, I have an update that fixes some recently found bugs. I've been working crazy hours as of late, so bear with me. I'll get the next update out as soon as I can.
nomnom27
My detailed MPAA rating is working for movies. I'm not sure why it won't display for you.
Also, after you enter your OMDb API key, you'll need to close KODI and remove the following file...
Kodi\userdata\addon_data\script.module.simplecache\simplecache.db
Restart KODI and you should see the rating info.
Hi latts
Thanks for the link and update. The addon_select gif doesnt really suit well with cases. Do you make the gif files yourself or do you find them somewhere. Would like to make a surround for the following case. I'm not much of a wizard at photoshop lol
Any tips?
the_bo
I made the animated gif for the focus surround. I can try to create an animated surround for that case.
(2018-02-14, 06:16)latts9923 Wrote: [ -> ]@the_bo
Thanks latts that be much appreciated
Theres no hurry take as long as you need.
Cheers
Hey latts, awesome update as usual. Quick question: the stars/rating on widgets - I'm not getting that on TV shows. Works fine on movies. Do I have to enable it it somewhere?
(2018-02-14, 23:03)RonnieG3 Wrote: [ -> ]Hey latts, awesome update as usual. Quick question: the stars/rating on widgets - I'm not getting that on TV shows. Works fine on movies. Do I have to enable it it somewhere?
Never mind. ID-10t error LOL. Needed to restart again.
I figured it out. there was a typo on my end. It's fixed. And also the omdb is working fine. Thanks for the help.
RonnieG3
Haha. I've done the same thing.
nomnom27
You bet! Glad you got it working.
