2018-10-23, 01:41
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181
2018-10-23, 12:44
@Latts
I suggest you copy and paste the necessary code from Shelf 3D to Shelf 3D V2.
Shelf 3D displays the track names correctly.
Shelf 3D V2 seems to have problems with the large number of music files for that artist (219 dj sets). After 1 minute of scrolling or so, the list gets corrupted. Note the extra "0." in front of each track name. No idea where that comes from.
What xml contains the code for the watched status icon? I'll try a previous version.
2018-10-23, 16:59
(2018-10-22, 22:49)nomnom27 Wrote: [ -> ]I tried my best and it shows info. The only info accurate is imdb and tmdb. I can't figure out how to turn it into percent and whole numbers in rotten tomato critic rating, audience rating and metacritic.Congratulations, you're almost done with the implementation!
The conversion from decimal to percent must be additionally coded with a variable:
add to IncludesVariable.xml the following code.
After that replace the Variable names with the ListItem names in DialogVideoInfo.xml.
e.g.: $VAR[ratingtomatometerallcritics] instead of $INFO[ListItem.Ratings(tomatometerallcritics)]
Please give some reputation if the code helped you on the last step implementing extended kodi internal ratings.
<variable name="ratingmetacritic">
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.0)">0</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.1)">1</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.2)">2</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.3)">3</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.4)">4</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.5)">5</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.6)">6</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.7)">7</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.8)">8</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),0.9)">9</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.0)">10</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.1)">11</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.2)">12</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.3)">13</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.4)">14</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.5)">15</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.6)">16</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.7)">17</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.8)">18</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),1.9)">19</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.0)">20</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.1)">21</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.2)">22</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.3)">23</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.4)">24</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.5)">25</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.6)">26</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.7)">27</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.8)">28</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),2.9)">29</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.0)">30</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.1)">31</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.2)">32</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.3)">33</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.4)">34</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.5)">35</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.6)">36</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.7)">37</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.8)">38</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),3.9)">39</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.0)">40</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.1)">41</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.2)">42</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.3)">43</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.4)">44</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.5)">45</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.6)">46</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.7)">47</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.8)">48</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),4.9)">49</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.0)">50</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.1)">51</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.2)">52</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.3)">53</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.4)">54</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.5)">55</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.6)">56</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.7)">57</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.8)">58</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),5.9)">59</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.0)">60</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.1)">61</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.2)">62</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.3)">63</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.4)">64</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.5)">65</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.6)">66</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.7)">67</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.8)">68</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),6.9)">69</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.0)">70</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.1)">71</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.2)">72</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.3)">73</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.4)">74</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.5)">75</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.6)">76</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.7)">77</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.8)">78</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),7.9)">79</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.0)">80</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.1)">81</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.2)">82</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.3)">83</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.4)">84</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.5)">85</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.6)">86</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.7)">87</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.8)">88</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),8.9)">89</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.0)">90</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.1)">91</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.2)">92</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.3)">93</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.4)">94</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.5)">95</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.6)">96</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.7)">97</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.8)">98</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),9.9)">99</value>
<value condition="String.IsEqual(ListItem.Ratings(metacritic),10.0)">100</value>
</variable>
<variable name="ratingthemoviedb">
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.0)">0%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.1)">1%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.2)">2%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.3)">3%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.4)">4%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.5)">5%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.6)">6%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.7)">7%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.8)">8%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),0.9)">9%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.0)">10%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.1)">11%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.2)">12%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.3)">13%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.4)">14%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.5)">15%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.6)">16%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.7)">17%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.8)">18%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),1.9)">19%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.0)">20%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.1)">21%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.2)">22%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.3)">23%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.4)">24%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.5)">25%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.6)">26%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.7)">27%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.8)">28%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),2.9)">29%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.0)">30%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.1)">31%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.2)">32%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.3)">33%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.4)">34%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.5)">35%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.6)">36%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.7)">37%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.8)">38%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),3.9)">39%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.0)">40%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.1)">41%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.2)">42%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.3)">43%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.4)">44%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.5)">45%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.6)">46%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.7)">47%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.8)">48%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),4.9)">49%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.0)">50%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.1)">51%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.2)">52%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.3)">53%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.4)">54%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.5)">55%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.6)">56%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.7)">57%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.8)">58%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),5.9)">59%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.0)">60%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.1)">61%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.2)">62%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.3)">63%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.4)">64%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.5)">65%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.6)">66%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.7)">67%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.8)">68%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),6.9)">69%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.0)">70%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.1)">71%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.2)">72%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.3)">73%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.4)">74%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.5)">75%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.6)">76%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.7)">77%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.8)">78%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),7.9)">79%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.0)">80%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.1)">81%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.2)">82%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.3)">83%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.4)">84%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.5)">85%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.6)">86%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.7)">87%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.8)">88%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),8.9)">89%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.0)">90%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.1)">91%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.2)">92%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.3)">93%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.4)">94%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.5)">95%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.6)">96%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.7)">97%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.8)">98%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),9.9)">99%</value>
<value condition="String.IsEqual(ListItem.Ratings(themoviedb),10.0)">100%</value>
</variable>
<variable name="ratingthetvdb">
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.0)">0%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.1)">1%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.2)">2%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.3)">3%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.4)">4%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.5)">5%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.6)">6%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.7)">7%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.8)">8%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),0.9)">9%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.0)">10%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.1)">11%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.2)">12%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.3)">13%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.4)">14%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.5)">15%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.6)">16%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.7)">17%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.8)">18%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),1.9)">19%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.0)">20%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.1)">21%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.2)">22%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.3)">23%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.4)">24%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.5)">25%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.6)">26%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.7)">27%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.8)">28%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),2.9)">29%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.0)">30%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.1)">31%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.2)">32%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.3)">33%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.4)">34%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.5)">35%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.6)">36%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.7)">37%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.8)">38%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),3.9)">39%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.0)">40%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.1)">41%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.2)">42%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.3)">43%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.4)">44%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.5)">45%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.6)">46%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.7)">47%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.8)">48%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),4.9)">49%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.0)">50%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.1)">51%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.2)">52%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.3)">53%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.4)">54%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.5)">55%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.6)">56%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.7)">57%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.8)">58%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),5.9)">59%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.0)">60%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.1)">61%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.2)">62%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.3)">63%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.4)">64%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.5)">65%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.6)">66%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.7)">67%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.8)">68%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),6.9)">69%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.0)">70%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.1)">71%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.2)">72%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.3)">73%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.4)">74%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.5)">75%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.6)">76%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.7)">77%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.8)">78%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),7.9)">79%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.0)">80%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.1)">81%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.2)">82%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.3)">83%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.4)">84%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.5)">85%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.6)">86%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.7)">87%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.8)">88%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),8.9)">89%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.0)">90%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.1)">91%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.2)">92%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.3)">93%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.4)">94%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.5)">95%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.6)">96%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.7)">97%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.8)">98%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),9.9)">99%</value>
<value condition="String.IsEqual(ListItem.Ratings(tvdb),10.0)">100%</value>
</variable>
<variable name="ratingtomatometerallcritics">
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.0)">0%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.1)">1%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.2)">2%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.3)">3%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.4)">4%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.5)">5%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.6)">6%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.7)">7%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.8)">8%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),0.9)">9%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.0)">10%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.1)">11%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.2)">12%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.3)">13%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.4)">14%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.5)">15%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.6)">16%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.7)">17%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.8)">18%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),1.9)">19%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.0)">20%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.1)">21%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.2)">22%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.3)">23%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.4)">24%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.5)">25%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.6)">26%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.7)">27%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.8)">28%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),2.9)">29%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.0)">30%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.1)">31%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.2)">32%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.3)">33%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.4)">34%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.5)">35%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.6)">36%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.7)">37%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.8)">38%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),3.9)">39%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.0)">40%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.1)">41%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.2)">42%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.3)">43%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.4)">44%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.5)">45%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.6)">46%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.7)">47%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.8)">48%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),4.9)">49%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.0)">50%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.1)">51%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.2)">52%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.3)">53%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.4)">54%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.5)">55%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.6)">56%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.7)">57%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.8)">58%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),5.9)">59%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.0)">60%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.1)">61%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.2)">62%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.3)">63%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.4)">64%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.5)">65%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.6)">66%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.7)">67%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.8)">68%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),6.9)">69%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.0)">70%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.1)">71%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.2)">72%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.3)">73%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.4)">74%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.5)">75%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.6)">76%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.7)">77%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.8)">78%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),7.9)">79%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.0)">80%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.1)">81%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.2)">82%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.3)">83%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.4)">84%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.5)">85%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.6)">86%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.7)">87%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.8)">88%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),8.9)">89%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.0)">90%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.1)">91%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.2)">92%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.3)">93%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.4)">94%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.5)">95%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.6)">96%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.7)">97%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.8)">98%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),9.9)">99%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallcritics),10.0)">100%</value>
</variable>
<variable name="ratingtomatometerallaudience">
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.0)">0%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.1)">1%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.2)">2%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.3)">3%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.4)">4%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.5)">5%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.6)">6%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.7)">7%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.8)">8%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),0.9)">9%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.0)">10%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.1)">11%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.2)">12%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.3)">13%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.4)">14%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.5)">15%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.6)">16%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.7)">17%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.8)">18%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),1.9)">19%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.0)">20%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.1)">21%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.2)">22%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.3)">23%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.4)">24%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.5)">25%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.6)">26%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.7)">27%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.8)">28%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),2.9)">29%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.0)">30%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.1)">31%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.2)">32%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.3)">33%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.4)">34%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.5)">35%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.6)">36%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.7)">37%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.8)">38%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),3.9)">39%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.0)">40%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.1)">41%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.2)">42%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.3)">43%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.4)">44%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.5)">45%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.6)">46%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.7)">47%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.8)">48%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),4.9)">49%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.0)">50%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.1)">51%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.2)">52%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.3)">53%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.4)">54%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.5)">55%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.6)">56%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.7)">57%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.8)">58%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),5.9)">59%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.0)">60%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.1)">61%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.2)">62%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.3)">63%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.4)">64%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.5)">65%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.6)">66%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.7)">67%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.8)">68%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),6.9)">69%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.0)">70%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.1)">71%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.2)">72%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.3)">73%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.4)">74%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.5)">75%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.6)">76%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.7)">77%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.8)">78%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),7.9)">79%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.0)">80%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.1)">81%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.2)">82%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.3)">83%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.4)">84%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.5)">85%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.6)">86%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.7)">87%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.8)">88%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),8.9)">89%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.0)">90%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.1)">91%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.2)">92%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.3)">93%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.4)">94%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.5)">95%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.6)">96%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.7)">97%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.8)">98%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),9.9)">99%</value>
<value condition="String.IsEqual(ListItem.Ratings(tomatometerallaudience),10.0)">100%</value>
</variable>
2018-10-23, 19:49
(2018-10-23, 16:59)chrissix Wrote: [ -> ]I Changed $INFO[ListItem.Ratings(tomatometerallcritics)] to $VAR[ratingtomatometerallcritics] in my DialogInfoVideo.xml file .(2018-10-22, 22:49)nomnom27 Wrote: [ -> ]I tried my best and it shows info. The only info accurate is imdb and tmdb. I can't figure out how to turn it into percent and whole numbers in rotten tomato critic rating, audience rating and metacritic.Congratulations, you're almost done with the implementation!
Code:<variable name="ratingmetacritic">
</variable>
</variable>
</variable>
</variable>
</variable>
And copied the code you provided me in my IncludesVariables.xml file but it made my ratings disappear.
I don't know if I'm doing something wrong or not. I'm stumped.
2018-10-23, 19:58
(2018-10-23, 19:49)nomnom27 Wrote: [ -> ]I don't know if I'm doing something wrong or not. I'm stumped.I think you still have problems with the .xml syntax.
Just write these lines from my current DialogVideoInfo.xml.
But don't copy it over and replace it, half of stuff will not be functional on your side.
https://drive.google.com/open?id=1G0ldIc...n-6zT-EUnI
EDIT: Please use notepad++ or better software for editing .xml's. notepad++ has also a "compare" plugin, very useful. try to play around .xml. Lot of stuff possible yourself.
2018-10-24, 00:09
Hi @latts9923
Thanks for trying to update widget views for watched movies...
Before update the watched flag style in skin colours settings wasn't used in widget view. After copying last version of your mod, the watched flag style is now no more displayed even if the movies have the right watched flag status displayed in other views (ex. right list view)
Can you reproduce the issue and try to solve it?
Regards
Regards
2018-10-24, 00:53
(2018-10-23, 19:58)chrissix Wrote: [ -> ]I think you still have problems with the .xml syntax.Thank you so much. I finally got it working.
Got any tips to make work here as well? It doesn't show any info.
2018-10-24, 14:17
2018-10-24, 21:27
2018-10-24, 21:42
(2018-10-24, 00:53)nomnom27 Wrote: [ -> ]it would be very usefull if ratings info could be grabbed from .nfo file, once the file is stored locally and, only if not available, going out to the internet. Afterwards, these info could be eventually updated through Light IMDb Ratings Update Addon or something like this.(2018-10-23, 19:58)chrissix Wrote: [ -> ]I think you still have problems with the .xml syntax.Thank you so much. I finally got it working.
I don't know how hard adding it to the next mod release could be (same reasoning applies on the different arts files possibly stored locally too)
Perhaps too much requests in the same evening... better if I go to sleep
2018-10-24, 22:15
2018-10-24, 23:19
@Latts, if you scroll 450 miles up you'll see my post #2102
2018-10-24, 23:38
@Jumpy73
The watched flag for widgets is working for me.
Also, I have a fix for the consensus textbox spilling over onto the imdb info.
2018-10-24, 23:42
@MB1968
LOL. I'll compare the code between Shelf3D and Shelf3D v2.
Remember, there is a new "SHOW FLAGS" radio button on the Top Menu that now controls the KodiFlix watched flag.
2018-10-25, 01:00
Thanks for the tip. Didn't know that.
