I'm thinking about dropping support for Krypton unless there is still demand for it. Please post if you still use this version of the skin.
Hi Latts,
I'm still using Krypton and wish that you could continue to support it. I really appreciated all the work that you had put in to create and support this wonderful mod that I've loved and enjoyed using it everyday.
Thanks,
tad61
tad61
You're welcome! All I needed was one user to request continued support. The Krypton Mod lives on!
UPDATE #99 - This will update the skin to v2.0.3.4
Additions- I added the visual effects to Skin Settings. This allows you to preview the main menu as you activate the effects.
- I added three new videocodecs...hddvd, tv, and vhs. Using these extentions in your file names will display the icon in media flags. Thanks to Jumpy73 for the request!
- I added a new fanart option in the Top Menu for Artists named ARTWORK HELPER FANART. This works the same as it does in Movies/TV Shows. It will display fanart images in your Artist folder (fanart.jpg, fanart1.jpg, etc.).
- I added Shelf3D and Sheld3Dv2 Music Views to the SHOW ARTIST/ALBUM ART button in the Top Menu for Music. When the path for the Custom Music Logo is selected, the thumbnail window in the upper right of both views will display fanart images in the extrafanart folder if one exists for the Artist in the Custom Music Logo path.
- I added Sets media flags that will display the standard Movie media flags (clearlogo in place of the studio) for the first 8 Movies in a Set. The first 4 Movie's media flags will display first, then the next 4 Movies in sequence, and finally returns to the first 4 Movies. Thanks to Angelinas for the idea and fixing the aspectratio!
- I added the option to display the animatedkeyart if available for a Movie. There is a new button in the Top Menu named "CINEMAGRAPH ARTS - KEYART".I added the ability to display multiple animatedposter images for Movies if available in your library. If you have "CINEMAGRAPH ARTS - POSTER" enabled, and then select "CHARACTER ART POSTER" as the "CASE ART" in the Top Menu for the Right List view, it will cycle through all of your animated posters.
- I added the ability to display multiple animatedposter images for Movies if available in your library. If you have "CINEMAGRAPH ARTS - POSTER" enabled, and then select "CHARACTER ART POSTER" as the "CASE ART" in the Top Menu for the Right List view, it will cycle through all of your animated posters.
- I added the ability to display multiple animatedfanart images for Movies if available in your library. The images will display if "CINEMAGRAPH ARTS - FANART" and "EXTRA FANART" are enabled.
- I added default/colored Italian MPAA rating flags. The ratings are T, VM6, VM14 and VM18. You can also add "Rated" or "Rated:" as text (i.e. Rated T). Thanks to Jumpy73 for the request and providing the images!
Bug fixes- I fixed a problem with missing info for Episodes in Video Info if Detail View was selected for TV Shows. Thanks to Juan Mortyme for reporting the bug!
- I fixed a problem with Critics Consensus displaying twice in Video Info. Thanks to Shredder_guitar for reporting the bug!
Maintenance- I removed the "SHOW AUDIO LANGUAGE AND SUBTITLE FLAGS" button from Skin Settings. It did not control anything in the skin.
- I removed the code that makes multiple changes to the skin when selecting the Batman menu bar. This was causing problems for users. The only thing that changes now is the menu bar.
- I removed the "•YEAR•" label in KodiFlixTV from Seasons and added the "Premiered" label (same as the Right List view). I moved the new label up so that it is evenly spaced after Genre.
- I adjusted the height of the plot label for KodiFlixTV if Center List was enabled. The text was dropping below the floor in the view. Thanks to MB1968 for reporting this!
- I adjusted the width of the ratings and votes info in the Video Info screen. Some languages caused the info to scroll. Thanks to MB1968 for the request!
- I removed the TV Show title from the subtext in the focused Episode info for the Right List view. Thanks to MB1968 for the request!
Other updates- I uploaded a new version of Metadatautils to the repo. There is a fix for the aspecratio when viewing the new media flags for Sets.
- I uploaded a new version of Colored Media Icons, Colored Studios, and White Studios.
UPDATE #100 - This will update the skin to v2.0.3.5
Additions- I added a new button to the Top Menu named "SHOW DEFAULT FLAGS FOR SETS". It is located under "VIEW OPTIONS/CHANGE VIEW". This allows you to toggle between the default/new media flags for Sets. Thanks to Jumpy73 for the request!
- I added a new view for Movies/TV Shows/Music Videos named Modern List. I've wanted to add this view for some time, I just never got around to it until now. I've made some tweaks to the original version. You can select different case art just like the Right List view. There are two more controls for the view in the Top Menu (SHOW BANNER IN PLACE OF TITLE, SLIM LIST) located under "VIEW OPTIONS/CHANGE VIEW". Also, if you select right twice it will display a window with detailed info.
- I added the "ARTWORK HELPER FANART" option to the Top Menu for Music Videos. Thanks to Juan Mortyme for the request!
- I added custom Extended Info scripts to the skin for Video Info and Video List.
- I added Total Episodes to the info for TV Shows "Basic Info" in Video Info. Thanks to Angelinas for the idea!
- I added Instruments to the Music Info for Artists.
- I added more options to display the American TV MPAA ratings. For example, to display the TV-G rating you can now use the following in your filename...TV-G, TV G, US:TV-G, US:TV G, US: TV-G, and US: TV G. Thanks to Jumpy73 for the request!
- I added the TV-Y and TV-Y7 icons to the American TV MPAA media flags.
- I added more options to display the Italian and French MPAA icons. You can now use the following for Italy...T / IT: T / Rated T / Rated: T, VM6 / IT: VM6 / Rated VM6 / Rated: VM6, VM14 / IT: VM14 / Rated VM14 / Rated: VM14, VM18 / IT: VM18 / Rated VM18 / Rated: VM18. For France you can use...TP / FR: TP / FR:TP / France:TP / Rated TP / Rated: TP / U, FR: U / FR:U / France:U / Rated U / Rated: U, -10 / FR: -10 / FR:-10 / France:-10 / Rated 10 / Rated -10 / Rated: -10, -12 / FR: -12 / FR:-12 / France:-12 / Rated 12 / Rated -12 / Rated: -12, -16 / FR: -16 / FR:-16 / France:-16 / Rated 16 / Rated -16 / Rated: -16, -18 / FR: -18 / FR:-18 / France:-18 / Rated 18 / Rated -18 / Rated: -18. Thanks to Jumpy73 for the request!
- I added five new studios...EXA Entertainment, Fickle Fish, Nagoya TV, New Regency Productions, and Rizzoli Film. Thanks to Jumpy73 for the images!
Bug fixes- I fixed a problem with missing info for Music Videos in Video Info if Basic Info was selected for Movies/TV Shows.
- I fixed a problem with the audio label if "AUDIO AND SUBTITLE FLAGS" was set to "TEXT". The path to the audio flag was being displayed along with the text.
- I fixed a problem with Video Info where the Music Video title was not displaying if the setting "SHOW TITLE ON TOP AS:" was set to "LOGO".
- I fixed a problem with Video Info where the Music Video clearart was displaying behind the discart.
- I fixed a problem with the Country Flags. The flag was not displaying in the correct position when certain conditions were met.
- I updated the ARTWORK HELPER FANART code for Music to also display the default fanart image while browsing Albums or Songs. Thanks to Juan Mortyme for reporting the bug!
- I fixed a problem with the clearlogo in the jewel box of the Shelf3D view not updating when selecting a different Artist. Thanks to Shredder_guitar for reporting the bug!
- I fixed a problem with the video title not displaying in certain views when the Top Menu button "SHOW TITLE ON TOP AS:" is set to "LOGO" and either the clearlogo, clearart or banner is missing. Thanks to halidri for reporting the bug!
Maintenance- I removed the Last.fm Album label from the bottom of Music Info if Albums are being viewed.
Other updates- I uploaded a new version of Colored Media Icons, Colored Studios, and White Studios.
Coming in the next release...the new Metacritic Must-See icon for Movies with a Metascore of 81 or higher and a critics count of at least 15.
I pushed another update for Skin Helper Service (v1.1.35) to my repo. I forgot to remove some of the RT code. Thanks @
Uploadergt for letting me know!
UPDATE #104 - This will update the skin to v2.0.3.9
Additions- I added the mediatype (from MQ 8) to the media flags. The media flags will now display the mediatype (DVD, Blu-ray, etc.) based on the filename extension as well as the videocodec. Your existing filenames should not need to be altered if the mediatype was being displayed as the videocodec in previous versions. Thanks to Juan Mortyme for the request!
- I added a button to the KodiFlix Top Menu that allows you to switch between the default media flags and KodiFlix flags.
Maintenance- I adjusted the code for posters in widgets so that they all display the same aspect. I also adjusted the position of the watched flag. Thanks to loich67 for the request!
I think a lot of people are still using Krypton as its the last version with player support for madvr.
Really appreciate your ongoing development and support!
