(2017-06-01, 14:59)latts9923 Wrote: [ -> ]@ajerazzor
I'm away from my PC, but look at Font_timesmall, Font_time, Font_time_big, and Font_temp (if you're using the Multi-Mod) in Font.xml. There are instances of these names in Font.xml for every fontset.
Thats bang on thanks for that - what about when pausing a movie the OSD shows the times down the bottom (current time/time remaining etc) - I changed every font_time related item in fonts.xml but these must be something else.
ajerazzor
You bet. I believe the font in the progress bar is using the name Font_list.
rew88
I think I might have found a fix for you. Add the following code to advancedsettings.xml...
<musiclibrary>
<artistseparators> <!-- separator used for multiple artists. Note that spaces are used for some separators.-->
<separator>/</separator>
<separator> / </separator>
<separator>\</separator>
<separator> \ </separator>
<separator>&</separator>
<separator> & </separator>
<separator>;</separator>
<separator> ; </separator>
<separator>:</separator>
<separator> : </separator>
<separator>|</separator>
<separator> | </separator>
<separator> feat. </separator>
<separator> ft. </separator>
</artistseparators>
</musiclibrary>
If you already have entries for musiclibrary, add the artistseparators info to it.
I couldn't get an album to even import into my library using a "/" as the separator until I added the above code.
Hopefully this works for ya.
@latts I have tried this fix but unfortunately it doesn't seem to work with streaming radio
the artist logo still stalls out . however slideshow artist seems to like it
cheers rew88
rew88
Well crap...I thought I had it. This might be something that KODI has to fix. I'll keep digging.
(2017-06-02, 05:16)latts9923 Wrote: [ -> ]@rew88
I was thinking its in skin as this feature is not on any other skin, perhaps in the way it calls the logo
cheers rew88
rew88
When it's a dual artist song, which logo does it try to display...the first artist, or second?
@latts
normally if it doesn't stall immediately mostly the second artist
latts9923
Just notice that the buttons in the red square disappeared.
I think they were quiet useful.
any plans to put the back ?
[/img]
Dave.B
Go to Settings>Skin Settings>Main Menu and look for the setting "Show Zoom Window in Home Screen (Audio/Video)". If you turn that on it should show up.
BTW...I got the newest version of JB-SimilarArtist working. I made a few tweaks to Layout 7 as well. It will all be part of the next update.
(2017-06-02, 18:05)latts9923 Wrote: [ -> ]@Dave.B
Thank you so much, this is awesome[emoji7]
Awesome! Can you add vertical menu compatibility to the font effects next update?
Ruk12345
Roger that bro! It's done!
Coming soon to a Multi-Mod update near you...
- Newest version of JB-SimilarArtist with tweaks to the new Layout7.
- Vertical menu font shadow and font glow for all fonts.
- Tweaks to Weather Effects as well as subcontrols.
