(2017-01-09, 23:28)master-yoda Wrote: [ -> ]First off thanks for the Mod, I have a bit of a weird problem and I apologize if this has been asked/answered before.
Using widgets on the home screen movies/tv etc work great, I have a problem opening most programs or video add-ons from the widgets. A good example of this is using ADD-ONS - VIDEO with iPlayer or BOB if I click the on the widget nothing happens apart from the click sound yet if I use the ADD-ONS - AUDIO both the add-ons open to their respective add-ons, iPlayer to the radio section and BOB to it's menu.
With the ADD-ON - PROGRAMS widget most programs don't open although there are a couple such as Backup that do. I have re-installed Kodi and the skin a couple of times and always come across the same problem.
This is with Kodi 17 RC2 on windows 10
Part of the debug log with it working in ADD-ONS - AUDIO is:
20:38:52.780 T:916 DEBUG: Thread JobWorker start, auto delete: true
20:38:52.781 T:3008 DEBUG: Thread LanguageInvoker start, auto delete: false
20:38:52.782 T:3008 INFO: initializing python engine.
20:38:52.782 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): start processing
20:38:53.254 T:8672 DEBUG: ------ Window Init (DialogBusy.xml) ------
20:38:53.456 T:3008 DEBUG: -->Python Interpreter Initialized<--
20:38:53.456 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): the source file to load is "C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py"
20:38:53.457 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): setting the Python path to C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww;C:\Users\herei\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Program Files\Kodi\system\python\DLLs;C:\Program Files\Kodi\system\python\Lib;C:\Program Files\Kodi\python27.zip;C:\Program Files\Kodi\system\python\lib\plat-win;C:\Program Files\Kodi\system\python\lib\lib-tk;C:\Program Files\Kodi;C:\Program Files\Kodi\system\python;C:\Program Files\Kodi\system\python\lib\site-packages
20:38:53.457 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): entering source directory C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww
20:38:53.474 T:3008 DEBUG: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): instantiating addon using automatically obtained id of "plugin.video.iplayerwww" dependent on version 2.19.0 of the xbmc.python api
20:38:56.793 T:3008 INFO: CPythonInvoker(23, C:\Users\herei\AppData\Roaming\Kodi\addons\plugin.video.iplayerwww\default.py): script successfully run
20:38:56.819 T:6240 DEBUG: Thread BackgroundLoader start, auto delete: false
20:38:56.855 T:6240 DEBUG: Saving fileitems []
20:38:56.857 T:6240 DEBUG: Thread BackgroundLoader 6240 terminating
20:38:56.858 T:8672 DEBUG: RetrieveMusicInfo() took 40 msec
and part of the debug log where it fails with ADD-ONS - VIDEO is:
0:41:50.508 T:8672 DEBUG: CDirectoryProvider[]: refreshing..
20:41:50.634 T:8672 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
20:41:51.665 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:51.665 T:8672 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
20:41:51.669 T:8672 DEBUG: CDirectoryProvider[]: refreshing..
20:41:51.798 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:52.264 T:8672 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
20:41:52.264 T:8672 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
20:41:52.379 T:8672 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
20:41:53.329 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:53.330 T:8672 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
20:41:53.428 T:8672 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
20:41:54.328 T:8672 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
20:41:54.406 T:8672 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
20:41:54.407 T:8672 ERROR: Window Translator: Can't find window video
20:41:54.407 T:8672 ERROR: Activate/ReplaceWindow called with invalid destination window: video
20:41:54.407 T:8672 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
20:41:59.935 T:8672 DEBUG: CWinEventsWin32::WndProcWindow is active
Any help would be greatly appreciated, I have probably missed something but I do not have a clue what. Thanks in advance......
I ran into a similar issue after installing this outstanding and wonderful mod. What I did to fix it was go to the Customize Main Menu screen and replace the add-ons to "re-set" them so to speak. In your example, replace iPlayer with iPlayer, BOB with BOB, etc. I did that with mine and had no problem after.
Sorry I don't quite understand, under the Customize Main Menu screen I don't see an option to replace the addons, that is for setting the main menus and sub-menus, uninstalling and re-installing the addons makes no difference either,
I can create a Menu and sub-menu and the add-ons will open from that however I still cannot get them to open from the widgets
I think I finally have all the
Aeon MQ 7 Spin additions ported to the
AEON MQ7 KRYPTON Mod.
The download below will add the Shelf3D and List3D views for video, as well as the Shelf3D and Magazine3D views for Music. I included the fonts as well as a new Textures.xbt file that contains all the Spin fonts/images needed by these new views. If you are going to copy/paste this Mod, I have added
<!-- SPIN MOD --> markers to the new code added/modified. There are quite a few changes, so make sure you get them all.
Download - Spin Mod 3D Views
Also, I noticed that the
Videolyrics Mod was not working quite right. I forgot to include the updated IncludesVideoLyrics.xml file, so that download has been updated as well. I'll inlcude that download below as well.
Download - Videolyrics Mod
Finally, I updated the original
Multi-Mod addition with the new Spin Mod 3D Views and the Videolyrics Mod.
It all seems to be working just fine. The Multi-Mod addition is becoming quite large, so I was careful to make sure I included all the files necessary to get these Mods operational...but I could have missed something. Let me know if you have any problems.
Enjoy!
(2017-01-10, 21:05)latts9923 Wrote: [ -> ]I think I finally have all the Aeon MQ 7 Spin additions ported to the AEON MQ7 KRYPTON Mod.
The download below will add the Shelf3D and List3D views for video, as well as the Shelf3D and Magazine3D views for Music. I included the fonts as well as a new Textures.xbt file that contains all the Spin fonts/images needed by these new views. If you are going to copy/paste this Mod, I have added <!-- SPIN MOD --> markers to the new code added/modified. There are quite a few changes, so make sure you get them all.
Also, I noticed that the Videolyrics Mod was not working quite right. I forgot to include the updated IncludesVideoLyrics.xml file, so that download has been updated as well. I'll inlcude that download below as well.
Finally, I updated the original Multi-Mod addition with the new Spin Mod 3D Views and the Videolyrics Mod.
Enjoy!
hi thankyou for doing this you are a genius it must have taken a while great work thanks again
Enjoy!
You always fulfill the users request
Great Job!
Thanks bro, only issue I have with it is this: double text upper right corner.
I also added the latest dialogseekbar.xml (that did fix my progress bar issue)
(2017-01-10, 21:51)flowerpot Wrote: [ -> ]hi thankyou for doing this you are a genius it must have taken a while great work thanks again
You're welcome! Thanks for the kind words. Yeah, this one took a while to get working.
(2017-01-10, 22:16)movie78 Wrote: [ -> ]You always fulfill the users request
Great Job!
Thanks man! I do what I can. Haha.
(2017-01-10, 23:50)Ruk12345 Wrote: [ -> ]Thanks bro, only issue I have with it is this: double text upper right corner.
I can reproduce this problem, but I have to add code to the file DialogSeekBar.xml to achieve it. It looks like you have the code for the subtitle entered twice.
Make sure you
do not have this code in the file...
<!-- Subtitulo filmes -->
<control type="label">
<left>45</left>
<top>82</top>
<width>1575</width>
<height>38</height>
<font>Font_subtitle</font>
<label>$VAR[value_videoosdtag]</label>
<textcolor>FFFFFAF0</textcolor>
<scroll>true</scroll>
<scrollout>false</scrollout>
<shadowcolor>grey</shadowcolor>
<visible>Skin.String(showhighposition,title) | String.IsEmpty(Control.GetLabel(10000)) | !Skin.HasSetting(change_pause_screen)</visible>
</control>
<left>45</left>
<top>182</top>
<width>1575</width>
<height>38</height>
<visible>!Skin.String(showhighposition,title) + !String.IsEmpty(Control.GetLabel(10000)) + Skin.HasSetting(change_pause_screen)</visible>
</control>
The Media Info Mod takes the place of this original code. If you see it, remove it. That should fix your problem.
(2017-01-11, 01:14)latts9923 Wrote: [ -> ] (2017-01-10, 23:50)Ruk12345 Wrote: [ -> ]Thanks bro, only issue I have with it is this: double text upper right corner.
Make sure you do not have this code in the file...
<left>45</left>
<top>82</top>
<width>1575</width>
<height>38</height>
</control>
<left>45</left>
<top>182</top>
<width>1575</width>
<height>38</height>
</control>
Thanks, I did a search for "sub" in my DialogSeekBar.xml and had no result. Seems I don't have this code at all
I am using the "
https://www.dropbox.com/s/55hwp8t6x82xm7...d.zip?dl=0 "
Pause screen fix version.
In the great scheme it's not a huge deal at all. Let me know if I should try anything else. If not it's cool. THANKS FOR the support.
(2017-01-11, 01:36)Ruk12345 Wrote: [ -> ]I am using the " https://www.dropbox.com/s/55hwp8t6x82xm7...d.zip?dl=0 "
If you're using this file, then that's your problem. Near the top you will see this code...
<!-- Titulo -->
<left>45</left>
<top>12</top>
<width>1605</width>
<height>60</height>
<font>Font_title</font>
<label>$VAR[value_videoosdtitle]</label>
</control>
<left>45</left>
<top>82</top>
<width>1575</width>
<height>38</height>
</control>
right below a
<!-- Media Info Mod --> marker. Remove that code and you should be good to go.
@latts9923 the video below starting from 8:44, is it possible to add the background for movie and TvShows soundtrack to your MOD?
(2017-01-11, 23:27)movie78 Wrote: [ -> ]@latts9923 the video below starting from 8:44, is it possible to add the background for movie and TvShows soundtrack to your MOD?
What font are you using in that video? I really like it!!
Any chance you can post the .ttf file for the "modern" font you switch too half way through the video?
I can't seem to find it included within the mod
If you mean the pyramid image, it is the image named tvshows.jpg in the Colours theme under resource.images.skinthemes.aeonmq.
(2017-01-11, 23:49)Ruk12345 Wrote: [ -> ] (2017-01-11, 23:27)movie78 Wrote: [ -> ]@latts9923 the video below starting from 8:44, is it possible to add the background for movie and TvShows soundtrack to your MOD?
This is the video from manfeed's
Aeon MQ 6 Spin Mod. If you download the mod, you can extract the modern fonts. I kind of like that font as well...I might have to make that part of this Multi-Mod. Haha.
