I've just downloaded Kodi 17 just to give it a spin and apparently the MacOS mouse isn't supported.
MacBook Pro (Retina, 15-inch, Mid 2015)
OS version: 10.12.1
PS: It does work but it has that warning sign instead of the pointer and says to disable it.
Could you post a screenshot? Also what exactly do you mean by macos mouse - is this some extra hardware?
(2016-12-20, 19:40)Memphiz Wrote: [ -> ]Could you post a screenshot? Also what exactly do you mean by macos mouse - is this some extra hardware?
Ah it's my mistake
its a custom skin which is doing it: Arctic: Zephyr:
http://forum.kodi.tv/showthread.php?tid=217174 that has a warning for the mouse pointer on Kodi 17.
I have a macbook air with os sierra...... just updated jarvis to krypton latest beta... all fine so far.......just the touchpad pointer does not go further than 3/4 on the right part of the screen...... very strange then
anybody experiencing the same issue?
tks alot, ciao
andrea
tks alot for suggestion
i installed the "kodi test mouse bounds" and it is better now, even if sometimes the pointer disappear ...... but better than nothing
waiting for the next kodi release to try
tks alot
ps:
should i report the results in some other open topics (i.e. cant reproduce topic)? .....
(2016-12-24, 13:12)aurgolo Wrote: [ -> ]I have a macbook air with os sierra...... just updated jarvis to krypton latest beta... all fine so far.......just the touchpad pointer does not go further than 3/4 on the right part of the screen...... very strange then
tks alot, ciao
andrea
Yes, I do have the similar issue with my machbook pro OS-Sierra 10.12.2. Kodi 17-krypton(tried with 18 alpha1 as well,-issue remain the same). It wont't allow me to click OK after I entered my credentials of fillmontv with kodi to configure PVR client.
Appreciate help to resolve this.
cmty
I too have a MacBook Air that I installed Kodi 17 on and experienced same issue with mouse (moves over only 3/4 of screen) but I downloaded and installed mouse bounds and works now, although as Aurgolo stated, mouse still temporarily disappears - I too will await a fix. Thanks so much Memphiz for the link to fix.
