Full Version: Unable to skip forward using upnp
Hi, first time poster and user of Kodi.
I've got the Odroid C2 and got Kodi running on Android. When I run movies from the Odroid over UPnP to a windows 10 machine, I cant skip forward and fast forward occurs really slowly. The movie status bar seems to flicker. But when I run the same file on the device or an SD card, the movie status bar is normal and I am able to click a section ahead and skip forward normally.
I've also run Kodi on windows and when I run the same movie over UPnP I also have the same problem.
Some movies do enable me to skip forward over UPnP, but generally are lower quality SD files.
Would anyone know how to fix this? Is it a buffering issue? thnx.
