Full Version: HDHomeRun View not working with latest Kodi Alpha
It appears some changes in the Kodi APIs require some matching changes in the HDHomeRun View addon.
Symptoms are logo and buffering bar not going away in live viewing, and if using with SD DVR, search page never populates. A busy indicate is present on live and dvr views and never goes away.
Is this the right place to ask about this? Thanks in advance...
Here is the proper place for the HDHomeRun View addon: http://forum.kodi.tv/forumdisplay.php?fid=154
Here is the SiliconDust forum for the addon: https://forum.silicondust.com/forum/viewforum.php?f=119
This forum is for the PVR addon, not the HDHR View video addon from SiliconDust.
Also 'latest' is not a version.
I am having the same issue with the progress bar loading using the HDhomeun add on. I am using Milhouse builds, and the issue starts on build #1213
1212b works
#1213 progress bar loops
I will cross post this to the silicondust forums
Try the SD forums. But this is not the correct Kodi forum.
