Full Version: [WIP] Shortcut for switching Audio Output Device
Hi!
I had the issue that I wanted to bind a key on my remote to switching the audio output device (without having to click through the settings first). As I was not able to find such a plugin (I found one that automatically switches the output depending on the media) and I was suspicious in trying to write a Kodi add-on I did it myself.
So the add-on does nothing more than switching to the next audio output when executed.
Here's the code:
https://github.com/B-S-L/script.switch.audio.device.shortcut
(here a the addon in zip:
https://github.com/B-S-L/script.switch.a...master.zip
Maybe some people (those having their TV in a room where they sometimes have to switch to earphones for sake of peace Wink) can use it - or you may tell how this could have been done easier! (anyway - it was fun to try develoe it).
(2016-12-26, 13:19)B.S.L. Wrote: [ -> ]Hi!
Here's the code:
AWESOME!!
It just does what it's supposed to, simple and effective.
Thanks a lot!
