2017-01-08, 19:56
2017-01-08, 20:47
(2017-01-08, 19:56)XsupergurkeX Wrote: [ -> ]Really nice skin. I love it !
Is there a featureintendend to add widgets to all and custom menu entries?
Thanks, all the widgets can be customised/changed. If your on the home screen just click on the home icon to bring up the widget selection. For all others (i.e. to customise your menu items) this can be done from the skin settings along with changing the widgets used by the movie/tv hub (which are enabled by default)
2017-01-09, 13:26
Thanks for the quick response.
I mean the widgets in the traditional homescreen. In a few entries you are able to set 3 custom widgets (movies or music for example) but theres no option like that for user created menu entries.
Edit: I have found a way, to add the widgets.
1st: Create a new entire point in the 'customize the Libary Menu'.
2nd: Create a new entire point with 'Add'.
3nd. Choose TV-Shows or another selection with widgets as 'item for menu'. (The option for the widgets is now activated)
4nd. Change the action and the label how you want.
5nd. Set the 3 custom widgets
But theres still one problem. The content specific widgets (For example 'categories' if you choose movies is still there :/
2017-01-10, 16:33
Can you add the option to increase number of widgets so there is more than 15 ?
2017-01-10, 17:01
(2017-01-09, 13:26)XsupergurkeX Wrote: [ -> ]Thanks for the quick response.
Ah yes I see what you mean, I need to create a generic sort of view for custom menu entries. I've done that in some of my other skins so will incorporate it here at some stage.
(2017-01-10, 16:33)makita86 Wrote: [ -> ]Can you add the option to increase number of widgets so there is more than 15 ?
Can you explain where exactly? I think the home screen has 11 which is already quite a lot....
2017-01-10, 18:21
I mean the number of pictures(tumbnails) of movies and tv shows that are showing on homescreen i have trakt collection of 40 titles and when i set the widget shortcut to it in displays only 15 titles on the homescreen?
2017-01-10, 20:32
Hello Guys,
I must say this is wonderful and beautiful skin for KODI17
But been wondering, do we really need these extra addons for example 'extended info' to gest skin running.
I have never been a fan of the above addon and been wondering if I have to install it or not.
Whenever I go to home screen, kodi asking me to install some extra addons which I finding annoying lol
2017-01-10, 20:36
The other question I forgot to mention.
The skin itself coming with pre prepare Home menu items for example :Movies, Tv shows etc and there is an option to add three widget option, however if I create an extra home menu item for example 'sport' the option for three extra widget is not included, why is that ? thanks
2017-01-11, 22:38
Hi I think I'm having some interface weirdness with this skin
The menu items don't look right - is it actually called customise power menu
http://pasteboard.co/kUIulDNlv.jpg
Here the Skin settings is labelled as none
http://pasteboard.co/kUFP7hsFO.jpg
Am I having issues or as this is still an early release is that just the state of play ?
2017-01-12, 20:36
Fantastic skin lad love it
2017-01-12, 22:33
There is no play button in extended info does it work?
2017-01-13, 19:24
(2017-01-11, 22:38)flipside101 Wrote: [ -> ]Hi I think I'm having some interface weirdness with this skin
Do you have Kodi 18? Or the required zips for Estuary Mod? (In particular, Skin Helper.)
If so, I'm pretty sure those cause issues. I have the same problem.
2017-01-13, 19:43
(2017-01-13, 19:24)gogorman Wrote: [ -> ]hi,(2017-01-11, 22:38)flipside101 Wrote: [ -> ]Hi I think I'm having some interface weirdness with this skin
im on the v17 rc3 release from the play store and estaury mod seems to work fine but i will tripple chech
Sent from my SGP512
2017-01-16, 20:32
Hi guys, glad you like it. I plan to add the default widget I mentioned for the "library mode" this weekend and to allow the menu on the home screen to be repositioned. If there's any other major issues/thoughts to improve let me know. Cheers
