Full Version: Videolyrics for Aeon Nox 5 (Krypton) and Silvo mod
Pages: 1 2 3 4 5 6
hi i am using win 10 , kodi krypton 17rc with krypton Silvo mod Krypton 6.0.2 when i play the music i dont seem to see the lyrics from the song that i am playing i looked at the skin and there dont seem to be any visualilation so i am wondering if this is why i cannot seem to use this mod as i am overwritten the correct files from post 1
thanks for any advice
(2017-01-10, 17:30)flowerpot Wrote: [ -> ]hi i am using win 10 , kodi krypton 17rc with krypton Silvo mod Krypton 6.0.2 when i play the music i dont seem to see the lyrics from the song that i am playing i looked at the skin and there dont seem to be any visualilation so i am wondering if this is why i cannot seem to use this mod as i am overwritten the correct files from post 1
Can you see the lyrics in Estuary skin? Check that first...
hi thank you for your reply i have checked the music in the Estuary skin and no lyrics or visualilation thanks
(2017-01-10, 18:02)manfeed Wrote: [ -> ]
hi i have seem to got the lyrics to show but having problems with fanart i can get the artistslideshow to work and images appear but when i tell it to go to fanart no images appear only lyrics i have also found a music cd to troll but unable to see it when i play the album thanks for your advice
(2017-01-10, 22:42)flowerpot Wrote: [ -> ]
This is a thread for adding manfeeds lyrics mod to Aeon Nox and Silvo mod, not a general music viz support thread Smile Please ask your question in the skin support thread of your skin.
This is amazing - I LOVE it!
One small idea/request. Is it possible to make an option for the lyrics appear a fraction of a second earlier - to make it easier for the kids to sing along Smile
@martinconroy, press C, have option for manual sync, is perfect for it.
(2017-01-11, 16:17)Wanilton Wrote: [ -> ]@martinconroy, press C, have option for manual sync, is perfect for it.
@Wanilton - thanks - but I don't have a context menu for full screen music in Aeon Nox Silvo (that I can find) - so maybe it's skin specific?
Which skin is that BTW? Looks nice!
(2017-01-11, 16:21)martinconroy Wrote: [ -> ]I don't have a context menu for full screen music in Aeon Nox Silvo (that I can find) - so maybe it's skin specific?
You need the last version of cu-lrc lyrics script, not sure if it is already available or only in github for now...
(2017-01-11, 16:21)martinconroy Wrote: [ -> ]Which skin is that BTW? Looks nice!
Aeon MQ7
Get addon git
https://github.com/ronie/script.cu.lrclyrics
And I think have better option for all music, look script settings, it´s global.
(2017-01-11, 16:54)Wanilton Wrote: [ -> ]And I think have better option for all music, look script settings, it´s global.
Perfect! Thanks Wanilton
(2017-01-04, 01:08)_Andy_ Wrote: [ -> ]I just checked all again. I did a fresh install of Kodi 17 RC and downloaded the skin from github from mikesilvo164 (Madnox for Krypton).
After that i simple copied all the files and folders from the zip into the madnox folder. Clicked yes to overwrite.
I simple enabled the video lycris and played a song.
The lyrics looks fine as it should.
So i guess you are using the wrong Kodi or Skin or mabye you missed some files from the zip file.
Tried it on a clean kodi 17 install and it do work fine but, when I setup the skinsettings the way I want it the font stays in one size and from the now playing menu I cant go back without stopping the song.
skip songs, backspace etc dont work then. something breaks it and I cant seem to find out what the problem is. Tried redownloading both skin and mod but still the same result for me.
Hello...
Amazing ! simply wonderfull !
Can i integrate in my MetropolIcon skin ?
thanks
@manfeed the lyrics mod is now included in the Aeon Nox version in the repo. Thx again Smile
Pages: 1 2 3 4 5 6
