Full Version: Videolyrics for Aeon Nox 5 (Krypton) and Silvo mod
Pages: 1 2 3 4 5 6
@manfeed: Just wanted to say thanks for an absolutely amazing job. These animations really give a new depth to the lyrics. I've integrated it into my mod, and it's just perfect.
Hello manfeed,
Can you create an addon so all Kodi user can install it on each skin?
It will be great to use the new visualization of lyrics in Estuary or else..
I have no expierence in creating codes, just a question.
Claus
(2017-02-20, 22:19)Acubens Wrote: [ -> ]Hello manfeed,
Claus
That would be the perfect solution for all of us. Wink
I would also like to use your lyrics with default estuary and/or pkscout's estuary mod.
Claus
It can't be installed for a normal user, but there are already several skins that are using this, even one mod for Estuary. Having a look to the files provided in the first post it's very simple for a skinner to adapt it to their skin/mods. So up to them...
New videolyrics effects...
...Aeon Nox Spin is drawing close...Wink
Looking great!
Wow awesome!! thanks for this great effort, where is the download link?
(2017-02-23, 19:10)ferent Wrote: [ -> ]Wow awesome!! thanks for this great effort, where is the download link?
More information here:
http://forum.kodi.tv/showthread.php?tid=307094
Are you going to allow other skins uses your new lyrics effects?
(2017-02-25, 12:00)ferent Wrote: [ -> ]Are you going to allow other skins uses your new lyrics effects?
Yes, of course, I'm going to post a thread in the skinning section to explain the skinners how to adapt it...
It yould be great, if we could get the files for copying manually over Aeon Nox Silvo mod skin, before he make an updat with you new version.
I don't want to change the skin.
Is that possible?
manfeed amazing work indeed !
A suggestion to make it even more amazing!,would you consider to have an option to scrape the corresponding Music Video as fanart with artist fanart as fallback if no video found . or there could be button to include this as an option. Kinda like a Lyrics video e.g :
https://www.youtube.com/watch?v=PT2_F-1esPk
what do you think ?
(2017-02-28, 18:07)shaktoo Wrote: [ -> ]manfeed amazing work indeed !
what do you think ?
As far as I know, a video can't be reproduced while your music sounds, so if you play a song, it can't load a video for you in the background. What you can do is to download the video with the lyrics and reproduce it.
(2017-02-28, 18:42)ferent Wrote: [ -> ]
what do you think ?
I'm afraid both options are impossible right now...Sad It would be nice, though... You could ask ronie in the cu lrc lyrics thread, sometimes he makes wonders Wink
or this could be a separate addon / Functionality in itself. All the artists from the library could be scarped against youtube music for the relevant video's whilst your video lyrics could run on top of the video ?
Will sure drop a suggestion by way of Ronie..Cheers
Pages: 1 2 3 4 5 6
