My blurays collection consists of the following formats:
Full
Full custom
Full custom (improved incluiding better audio or video)
Bluray remux
Bluray remux (improved better audio or video)
Jmbd
Jmbd (improved by the example incluiding better audio or video)
M2ts
I rename it nameoffilm (year) [Full custom +A DHMA 7.1).Bluray.iso[/align]
What field can I use to enter this information and then be able to list them according to the format?
Thanks in advance
use the tags:
first tag of the movie is your desired format string and then include the first tag into the renamer
(2017-01-10, 10:47)mlaggner Wrote: [ -> ]use the tags:
But I can only generically bluray. Could it include a field where you can put the exact format in which the movie is? Bdr, Jmbd, Full custom etc ...?
I do not see any other field where I can put that information.
Thanks in advance.
use the tags field (in addition to the edition field) - there you can put any string you want
(2017-01-10, 13:51)mlaggner Wrote: [ -> ]use the tags field (in addition to the edition field) - there you can put any string you want
Ok, but what token I use to renamer?
Thanks in advance.
omg you got me..
Looks like we discussed (internally) the tag token, but never implemented.
Just put it on our todo list for the next version - then you will be able to use it
(2017-01-10, 17:27)mlaggner Wrote: [ -> ]omg you got me..
If is possible add various tags because I use it to put editions also so the edition list haven`t all of my films.
Thanks a lot.
Is possible add in a nightly beta?
Thanks in advance.
(2017-01-10, 19:46)judocama Wrote: [ -> ] (2017-01-10, 17:27)mlaggner Wrote: [ -> ]omg you got me..
Thanks a lot.
Is possible in a future I can use various tag in renamer option?
Thanks in advance.
