2016-12-31, 15:54
I don't know if I'm ok here but I want to report a bug of crashing also. I have a clean laptop with W10 prof 32 bit. That's all. That means no programs installed. only W10x86. Ofcourse it's totally updated. So the latest W10 prof version. Then I installed Kodi. krypton. I started months ago with the beta versions and today I installed RC compiled on 30-12. I In all these versions the same issue happened:
I start kodi and do nothing (just let it stand there) and then it crashes overtime. if I watch a movie its oke. Movie is over, so I click stop button also the program crashes. windows gives an error popup. kodi crashed, we will let you know if we have a solution (or something like that). only thing I can do is click ok and it will kill kodi. So I have to restart it.Then I check the logs and it says:
Faulting application name: kodi.exe, version: 16.9.902.0, time stamp: 0x58668ee6
Faulting module name: ntdll.dll, version: 10.0.14393.479, time stamp: 0x58256cad
Exception code: 0xc0000005
Fault offset: 0x00056af8
Faulting process id: 0x1674
Faulting application start time: 0x01d263648b734c05
Faulting application path: C:\Program Files\Kodi\kodi.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: 06afd9ee-d357-4a94-a684-3392165d70a0
Faulting package full name:
Faulting package-relative application ID:
a little bit older:
Faulting process id: 0xcb8
Faulting application start time: 0x01d2635aa8ebbfa0
Report Id: b2f35301-64df-4e65-848d-2d8a510fd23c
So this keeps happening. Known issues? How can we solve this?
a little bit older:
