Full Version: Programs menu
It could be that I am going brain dead, or maybe it's this damn head cold... but I cannot find a way to get into the 'Programs' menu using Estuary. I am using Kodi 17 RC2.
I want to be able to add a few of the Android add-ons as favorites to make them easier to access from within Kodi on my Shield TV. Using other skins I can enter the 'Programs' menu, go up one level in the tree, and choose Android Apps. From there I can long click on an Add-on and add to Favorites.
The Add-Ons menu shows me some, but not all, of the Android Add-ons on the system. Long clicking on these does nothing.
A work around I stumbled onto is to have the Library Node Editor installed, select it, and then go a level up in the tree, which brings you into the familiar Programs menu.
I am posting this in the Android section, as this only affects my desire to add Android apps to Favorites. I do not have any trouble with native Kodi add-ons.
This may be something totally ridiculous that I am missing - Any help is appreciated.
Moderator - Since I have not gotten a response here, can you please move this to the Estuary thread?
Moved.
(2016-12-31, 19:11)sdsnyr94 Wrote: [ -> ]It could be that I am going brain dead, or maybe it's this damn head cold... but I cannot find a way to get into the 'Programs' menu using Estuary. I am using Kodi 17 RC2.
Hi, Did you ever find a solution to this please. I've been trying all over the shop but so far am stumped.
Perhaps Android's version of Estuary is slightly different than windows. My set-up is Add-ons>My Add-ons>program add-ons>list of a bunch>context menu for favourites? This correct or are you missing a screen? (from the sounds of it Library Node Editor installed, select it, and then go a level up in the tree, which brings you into the familiar Programs menu.)
I was able to access the add favourites by going right down the menu tree as far as possible into android apps but previously I hadn't ever been there especially as all other sections I can do from higher up the menu tree .
tinwarble also gave another option here - http://forum.kodi.tv/showthread.php?tid=...pid2497656
