Full Version: Music runs fast
Hella,
I have an Himedia Q10 pro with Android 7 and Kodi 17 RC2.
Before I had on this Player Android 5.1 and Kodi 16.1
The Problem was on both Versions. When I play music with Kodi MP3 or Wave ... the music runs a little bit to fast.
When I use the Media Player every thing is fine. In the Settings I use pass through.
What can I do to solve this Problem.
Watchhing a film every thing is ok.
best regards Olli
Strange one, never heard of that sorry! Maybe its specific to the android device?
(2017-01-01, 14:36)olli1967 Wrote: [ -> ]When I play music with Kodi MP3 or Wave ... the music runs a little bit to fast.
How can you tell?
But no I have not heard of anything like this either.
Probably a sampling rate issue, what is the Himedia connected to? an AVR? if so what make/model?
Please post a debug log_file (wiki) showing you playing a problem file.
You can also try and see if my hunch is right by setting Output Configuration to Fixed and try changing Limit Sampling Rate between 48.0 and 44.1
Hello,
I tryed your tips with the sampling rate but it don't work. Also I recocnized that the AV did not change to DTS sound.
I will try to send a logging file during the next days. What I don't understand si that my musich with the media center works well.
Also with mit Dune HD Base 3D I have no problems. I never had a problem like this.
Best regards
