any way to use this to have animated posters with confluence? I recently got MQ7 and like that feature, but my wife prefers confluence as shes been using it for a while and hates having to relearn where everything is.
use simple the gif file in confluence and all is fine.
(2017-01-02, 14:29)harryberlin Wrote: [ -> ]use simple the gif file in confluence and all is fine.
I see I can manually set it, but for example Aeon mq7 automatically grabs them. Any way to implement this in confluence?
why should it be automaticlly, if you want a custom background?
(2017-01-02, 20:09)harryberlin Wrote: [ -> ]why should it be automaticlly, if you want a custom background?
I dont want animated fanart/background. Just the movie poster.
where does it grab this posters.
otherwise:
check the source code from mq7 and implement it to confluence.
(2017-01-02, 23:38)harryberlin Wrote: [ -> ]where does it grab this posters.
otherwise:
according to wanilton the skin has to support the skin helper script
http://forums.kodi.tv/showthread.php?tid=215727&page=55
whats involved in modding confluence to support it, or is there a mod out there?
