2017-01-03, 11:28
Hello,
I currently have an android TV device with both KODI 17 RC 2 and the SPMC (fork version of KODI 16) installed.
Issue is happening on KODI 17, no on KODI 16 or the fork version based on KODI 16. The issue does not occur on the server neither.
I noticed that when switching channels, some HD channels stay in slow motion. I keep the channel on, but it doesn't change or fix itself. If I switch channels and go back, it sometimes fixes itself. No specific channel, happens to any HD channel at random.
All versions of KODI are using about the same amount of CPU and memory when browsing the KODI interface. I make sure to exit and reboot the android device between test.
I also tried the latest nightly of krypton for ARM v7.... kodi-20170102-ab7f182-Krypton-armeabi-v7a.apk
The NextPVR plugin is 2.4.10
The issue still occurs.
