HI All,
I am looking for Ultra Blu-ray logo, I try to make one but I think the resolution and the size didn't come out good, I will appreciate if someone the talent can create one, below are a few examples.
No, I am looking the exact same logo on the UHD Blu-ray Disc.
Slightly bigger version here, really needs redrawing though
(2017-01-06, 18:21)docwra Wrote: [ -> ]Slightly bigger version here, really needs redrawing though
Isn't that the same one I posted?
Yep but its larger so people are able to trace the bitmap easier.
I gave it a quick go here, didn't have much time though.
It could be done nicer with metallic effects.
Looks good!!
Please add the metallic effects
It looks small compare to the other Logo
Whats the normal dimensions of these logos?
(2017-01-07, 16:54)docwra Wrote: [ -> ]Whats the normal dimensions of these logos?
I have feeling i need ask the Skin Mod for help with size, because logo dimension larger than the one i posted
movie78, don´t have only one size, to bluray art - size is 161 x 109 pixels.
(2017-01-07, 19:45)Wanilton Wrote: [ -> ]@movie78, don´t have only one size, to bluray art - size is 161 x 109 pixels.
Is there a way I can make logo look like what's on the Ultra Blu-ray Disc?
not to size... but hd quality (yes, I did these)
jpg:
png version:
What skin are you using?
How do you implement the logo on the movie cover template shown in your example images? is there a procedure through the skin?
The reason I ask is because I'm inclined to recreate the whole movie cover template ...sized from the skin in various other formats as well as the Ultra HD bluray IE: bluray3d, bluraydisk, etc.
Great job!!!
I use the Aeon MQ7 krypton skin, i extract the texture.xbt then i replace the logo with original.
no easy way to download that skin without signing up to a foreign site?
