Full Version: Fire TV Stick and MJPEG playback
Hello everybody,
I have problems playing some videos with Kodi 16.1 Jarvis on Fire TV Stick. This videos are from an older Canon Camera, which saves video in MJPEG format. These video seems not to be played at full speed on Kodi at Fire TV Stick and within the video playback there are some parts skipped. Also the audio somehow comes a little bit asynchronous.
While using Kodi or VLC Media Player at some other devices like my Windows 8.1 notebook these videos are played normal, so it seems to be a Fire TV or Android related problem.
As far I know, this codec saves every video frame in one JPG picture and there is no frame interleaving compression used. I read in an older thread that this format is/was quiet hardware intensive, so maybe the Fire TV Stick hardware is just too slow?
Chipset: Broadcom Capri 28155 2x1,2 GHz Cortex-A9
RAM: 1 GB LPDDR2, 533MHz
General
Complete name                            : C:\Users\Somebody\Desktop\MVI_1141.AVI
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 166 MiB
Duration                                 : 1 min 28 s
Overall bit rate                         : 15.6 Mb/s
Mastered date                            : 2016-08-30 14:08:52
Writing application                      : CanonMVI06
Video
Format                                   : JPEG
Codec ID                                 : MJPG
Bit rate                                 : 14.9 Mb/s
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Frame rate                               : 30.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:2
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 1.620
Stream size                              : 158 MiB (95%)
Audio
Format                                   : PCM
Format settings, Endianness              : Little
Format settings, Sign                    : Signed
Codec ID                                 : 1
Bit rate mode                            : Constant
Bit rate                                 : 705.6 kb/s
Channel(s)                               : 1 channel
Sampling rate                            : 44.1 kHz
Bit depth                                : 16 bits
Stream size                              : 7.48 MiB (5%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 1000  ms (29.99 video frames)
Interleave, preload duration             : 1000  ms
