Full Version: Actor Links
I recently updated to the Emby for Kodi plugin after installing a Emby Server back end.
The same day I noticed that in the KORE remote on the left page the actor links to IMDB went missing.
I assume there was an update to the remote removing this functionality...?
If not, I do not see how the Emby setup would remove features from the remote?
Any thoughts would be appreciated... thanks
That wasn't removed. If it isn't presenting the actor list, it's because that isn't being returned by Kodi for the media that you're watching.
I installed KORE on another SMART phone and it worked fine, so I will just reinstall on the phone with the issue.
Just something weird happened with the EMBY plugin install... no worries, just thought maybe someone else had seen it happen.
Thanks...
