Love this skin. I'm happy with default widgets on the homescreen too except for one. Is it possible to replace Recently Added Episodes with Recently Aired Episodes?
Estuary by default doesn't offer that kind of customization. You're either going to have to find a skin that does or dig into the skin XML code and change it yourself.
Any idea what xml file I need to modify? I see that there's a smart playlist for TV Episodes - Date Added, but not able to figure out how to change that to Date Aired.
I think everything for the home screen (including the widgets) is in Home.xml.
I am having this problem too. Using xconfluence. For Jarvis I changed default.py from dateadded to year. It worked fine. Tried it with Krypton and works but after a while reverts back to original default so any new tv show added just overrides the recently aired ones.
