Full Version: [Request] Daydream screensaver
As there are some screensavers for Android (called "Daydream" sometimes), it would be nice to just launch the assigned android screensaver.
Looks like SPMC is able to do it (there is a screensaver called "System" screensaver.xbmc.builtin.system; which does not work for me either).
I am wondering if it would be possible to release this (or a similar one) as standalone option? Any ideas? Or not possible due to system limitations?
I would like this as well. I used to use SPMC and the "system" screensaver worked great. Once I switched to Kodi, there was no option available to use this.
+1 for that
Currently, I have the Dim screensaver working and after 2 minutes the daydream system screensaver kicks in.
The problem is that to get back to Kodi (and stop the daydream screensaver) I have to use the device remote, can't use Yatse b/c it does not trigger a real physical key that terminates Daydream.
