(2017-02-14, 18:32)jjd-uk Wrote: [ -> ]Go into My Addons ( NOT Install from repository) then Look and Feel -> Visualisation and they should be there but disabled.
Ahhh.. Many thanks. Found and enabled.
Now that I have them enabled.. they seem to have limited use in Estuary from what I can see? they only seem to play as a background behind track list in the default widelist view, and background of 'Info' view? I really miss the way music playback worked under Confluence..
(2017-04-02, 17:56)shmn Wrote: [ -> ]Tried this on 17.0 Git:a10c504 and it didn't work. Switched back to Confluence for now.
This should be fixed now in 17.1, i didn't need to modify "DialogSeekBar.xml" in this version.
The overlay should disappear after ~10 seconds
(2017-04-02, 18:04)vitorp07 Wrote: [ -> ] (2017-04-02, 17:56)shmn Wrote: [ -> ]Tried this on 17.0 Git:a10c504 and it didn't work. Switched back to Confluence for now.
Just updated to LibreELEC 8.0.1 which also updated Kodi to 17.1 and the problem is fixed.
Thanks for the heads up!
